Panasonic dvd/vhs player/recorder will not power on. disc is inside and will not open. display screen shows "F60".
I have the same problem and I can offer a solution only to get your disk back but not the error code thing. unplug the unit and all video/audio cords. Remove the 3 screws in the back and 2 along each side. Remove top. Remove3 screws holding DVD player in place. Remove and turn over DVD Player. See the motor in the bottom near the ejection door, under the sheet metal with the lopsided "Keyhole" in it. Just to the rear of that there is a piece of plastic (mine is white) with a tab and some tracks in it. in a moment you will apply pressure to the tab will slide it to the right. (if the ejection door is nearest to you and the pcboard attached to the bottom of the DVD player is furthest from you.) But before you do this you may want to turn the DVD player correct side up. This will alloy gravity to hold the disk in the tray when the tray is ejected. Now you can slide the tab to the right (or left if the DVD player is correct side up) Use some force on the tab. you are attempting to ramp up the speed on the ejection motor and still have some momentum built up after you reach the end of travel for the tab. If you have done every thing I have instructed then the ejection door should have opened and the tray should be partially exposed. Simply gently pull on the tray and then remove your disk. Now if you flip the DVD player back over, plug in the power cord, and hit the little "Reset" button, after a few moments the DVD will retract the tray. At this point unplug the power and reassembly the machine in reverse order as disassembly. Or simply throw the unit out because according to other posts on this and other sights, if you are getting the F60 or U99 error codes then it would appear that you have a bad Video board which is no longer available.... anyway I may have saved you $139.00 (At Panasonic) to extract your $20.00 video.
Posted on Feb 28, 2009
Can I record DVDs from a Sharp 13VT-N100? The only connection source is the coaxial antennae port. There are "In" sources so I can watch DVDs from a DVD player but how can I reverse that so I...
Recorded from tv shows to DVD Disc have to hookup AV RCA component cables to both to Tv and DVD recordable player model connections together.Yes,u will able to recordable VHS tapes to DVD Discs.But ur DVD player model u have it is must be a recorderable DVD player model?Not just a DVD Discs and VHS tapes player only model.Check ur owner manual all are in there.
Aug 20, 2011 | Sharp 13VT-N100 Combo
I am trying to copy a VHS to DVD from a VHS player. I have a Sony VRD-MC6 multi-function DVD Recorder. I am using the A/V cable and have verified that they are correctly placed. The Sony player will...
Is it possible the VHS you're trying to copy is copy-protected? Apparently, the MC6 displays "waiting for signal" when you're attempting to copy a copy-protected (commercial) video. I had success converting my own homemade VHS tapes. I just bought my MC6, and thought I'd pass along some tips I got from others: You know you're recording when a red ring around the large Record button lights up and it actually says "recording" on screen, and adjust HQ to SP to get 2-plus hours of video on the DVD.
Jan 24, 2011 | Sony VRDMC10 DVD Recorder
My Panasonic dvd-rv32 player (8 years old) functioned perfectly for last 8 years and I cannot get it to PLAY again. I inserted another DVD tonight (actually 3 DVD'S in case the DVD's were defective) and...
Spindle motor/laser assembly is faulty. This part is not repairable - it has to be replaced by an authorised service centre. It may not be economical via this route, since the unit is not a DVD recorder. H07 is an indication of the above issue. Cheaper to buy a new DVD player or recorder than trying to get the faulty one repaired outside warranty.
Jan 19, 2011 | Panasonic DVD-RV32 DVD Player
DMR-es40v f60 error
Problem for Panasonic DMR-ES40V DVD-Video Recorder with Built-in... Maching displays F60 as soon as it's turned on and
Nov 13, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
1. On your remote, find the record mode button; it is near the bottom on the left side. This button sets
the recording speed for the DVR. Faster recording speeds provide higher quality recordings.
2. Look at the display on the front of the machine: it should say XP ( records 1 hour on the disc,)
SP ( 2 hours, ) LP ( 4 hours, ) or EP ( 6 hours. ) You can also set it to record 8 hours on a disc,
but the quality of the recording will be poor.
3 Press the record mode button until the screen displays the recording speed that you want.
4 Note: if the powers fails or the Machine is unplugged, the machine will automatically reset itself to
SP mode.
Apr 29, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
F60 Error message on DMR-ES40V unit
Unplug the unit.
Plug back in and wait till you see 000000.
Press and hold the power button in at least ten seconds or until the clock shows up.
This worked to fix mine.
Jan 05, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic Double feature DVD/VHS deck. DVD player not working. Inserted disc, pressed play. Says, "Reading" then cuts to blue screen.
We could not turn on the Panasonic Double Feature by remote or by manual. It is dead no power going in. What is the problem and how can we fix it?
Oct 12, 2008 | Televison & Video
Help w/ panasonic burner
I own one and it is a pain to work. Put in the disc and vhs tape and hit the bottom right button, I believe it says DVD and above it says dubbing. Hold it for a few seconds and the screen will come up and the system will do the rest recording from your VHS tape to the disc. You MUST finalize the disc after you are finished if you want to watch it in another DVD players if not it will only work on the Panasonic. Hope this helps. If not here is the site for the owners matual
Dec 06, 2007 | Panasonic DMR-E75V DVD Player/VCR
Televison & Video Logo
361 people viewed this question
Top Televison & Video Experts
