Just got comcast internet, and i dont have a computer but i have ps3 and wanna play online? Will i need anything else or all the wires and stuff included in the internet package that will go to my ps3?
Ok first off create a psn account online via computer, this is free of charge. Then after that connect your ps3 via cable to your modem. turn it on and access network settings. Then select internet connection settings, select easy. After it is finished select test connection. Should this time out it means you have a faulty connector somewhere, try checking your cables and the ports on the ps3 and modem. But if it states connected, back out and go to network via your ps3 dashboard then select sign in and enter your account info from your psn account.
20GB for just playing online is way too much. Are you using wireless or wired internet? Maybe someone is leeching your internet connection and downloading stuff without your knowledge. Normal online play woulnd't consume such huge amounts of bandwidth. I recommend you change your wireless password.
1, wireless, make sure that you have an internet connection first with a computer and that you know your network name and password (if you have one set up). Go into the PS3 menu and scroll to the network config section, and set up a new network, where it says SSID this is the name of your network, for example SKY1234. Then it will ask you for a encryption type, for example WPA or WEP and then your password, input your password and let the PS3 do the rest, if there is anything wrong it will tell you.
2, wired through an ethernet cable, again go to the network config section in the PS3's menu and set a wired connection, it will not ask you for your SSID or password as its a wired connection.
If you need anymore help or advice please feel free to post back.
If your PS3 is Networked upto Your PC to use the internet connection, You have to allow the PC to share its Internet connection with yout PC, Do this By going into Network settings, Checking the properties of your LAN card in your PC. and clicking on, "share my internet". This should alleviate that problem..
Or.
If your PS3's Wired connection isnt working. but your PC one is, Try moving your PS3 Lan cable into one of the other Free LAN Ports (if available) or Try Switching the PC cable over to the PS3's Port in the Router, and Visa-Versa !
I once had the same problem. What i did is that i booted the modem and the Ps3 (turned both off) and then turned them on. Then i went to the internet settings on the Ps3 and tried the internet connection check and it worked! I hope you have some help of this.
first you will need dsl if you have this go to network settings then go to internet connection settings Choose either wired or wireless connection. Then when you are in address settings select easy you server should find all the information Then you must sign up for the playstation network once you are done you can play games online. It doesn't cost any money but it will ask for credit card info incase you want to download stuff.
