Question about GE Dryers
Squeaks it still works very well, except for the ungodly squeaks. How do I lubricate them before they break?
    Problem Solver:
  • 14 Answers
The most common problems for squeaks on a GE is the idler pulley or (belt tension pulley). There is a teflon bearing in the rear that can cause this as well. you will have to remove the front panel and remove the drum to repair both. you can see if the rear bearing is gone or if the grease is dryed out.http://www.repairclinic.com/0100_20.asp. Good luck
Posted on Jul 27, 2008
Why does my 1991 subaru squeaks then cuts out for a sec.
If it's happening while driving and no brakes applied it's probably a belt causing the noise. There's a product available in most local auto shops that you can use to lubricate the belt. I think the actual name is "stop squeak" but I'm not positive.
If it's squeaking while breaking you may need new breaks or your breaks may be too tight. Another product exists for breaking squeals available in your local auto shop
Aug 27, 2014 | 1991 Subaru Legacy
2001 hyundai sonata sub frame squeaking where can I lubricate under car
have some expert look at this subframe, it does not sound good, and there is not lubrication for it, recomended by Hyndai that is.
Nov 09, 2013 | 2001 Hyundai Sonata
My Dell 5210n printer has a very loud squeak in the back. How do open the printer to lubricate the bearings?
Usually you don't lubricate. It is probably the fuser assembly wearing. How is the print quality? Have you ran a test page, ran a supply status page? Checked the error log?
Jan 17, 2013 | Dell 5210n Laser Printer
I have a squeaking noise coming from the rear of my 06 range rover hse what could it be
Rear suspension bushings will squeak, Dealers will want to replace them all, Give them a good soaking with a rubber lubricant and they will stop making noise, I use Ruglyde, it is a rubber lubricant for mounting tires and works very well for this squeak
Dec 11, 2012 | Land Rover Range Rover Cars & Trucks
Left side its sqeak when i peddle
My Precor EFX 546 elliptical trainer began squeaking when my weight was on the pedals. I thoroughly cleaned the track and wheels with Windex and then used my finger to apply a thin coat of teflon based lubricant (Tri-Flow brand) to the outer surface of the wheels. After 2 applications of lubricant, the squeaking has been eliminated completely. Hope this helps!
Sep 24, 2012 | Exercise & Fitness
What does squeaking sound during breaking mean?
Hi Chery, squeaking from the brakes isn't at all uncommon. The simplest and most likely cause is dust in the braking system. This gets between the fristion material and the disc or drum, heats up and creates the sound. Going beyond that, it might be a lack of lubricant (special grease) bwtween the disc pad (or brake-shoe) and the actuator/s. Worse still it's possible it's indicative of worn out brake friction material in which case it could well be the base of the pad or the brake shoe rubbing against the disc or drum. This last will entail a brake overhaul - fitting replacement pads and/or shoes, and if this has caused disc or drum wear, their repplacement too. Good luck!
Jun 10, 2012 | 2006 Honda Accord
Squeaky steering wheel?
Try using some type of lubricant on the pass through on the fire wall. If you look down under the dash by the break peddle you will see where the steering shaft goes through the firewall. Get a litium grease to spray between the shaft and the rubber groumet that it goes through. Not a whole bunch but enough. spray it a little then trun the wheel back and forth then do it again.
This should solve the problem, If it's the noise that I have been encountering lots at work.
Oct 23, 2009 | 2008 Chevrolet Malibu
Severe squeaking noise coming from the undercarraige....shocks? bushings?
Both the shocks and bushings can cause the squeaking noise. It is very common in those vehicles, and the best bet for figuring out which one is this: put some brake fluid in a squirt bottle, and put a small amount(don't get overzealous with it, as it will remove paint) on all the rubber bushings, and drive it around a little to get it worked into the joints. Brake fluid is designed to work as a lubricant in brakes without degrading the rubber parts, so it is excellent in lubricating the rubber suspension parts. If your squeaking remains, then it is probably the shock. This diagnosis, of course depends on if the squeak is that really obnoxious rubber squeak noise that comes when you push down on the front end and make the suspension travel. If the squeak is the high-pitched one that is constant when driving, and doesn't change except with speed, then it is your brakes telling you that they need new pads.
Oct 21, 2009 | 2001 Chevrolet Blazer
I have a 2001 pt cruiser limited edition, during the winter my door locks started making a noise, not a grinding type noise, kind of like a sqeel. all the doors lock except for the drivers side.
You can get lock lubricate from an auto parts store. Work it into all locks. The driver side is not squeaking because you use that lock regularly so no corrosion.
May 02, 2009 | Chrysler PT Cruiser Cars & Trucks
Cluncking noise when in reverse gear, also squeaking from breaks when not pressed
aftermarket brake and rotors ,also calipers that temporarly stick causes this squeking problem,replace if worn and use special lubrication for these parts including the shims
Oct 16, 2008 | 2002 Volvo S60
Dryers Logo
100 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
