Question about SanDisk Sansa e250 MP3 Player
It wont turn on
Sansa (pink) sandisk 1.0 gb
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Aug 14, 2008
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
Sansa 1 gb
On your sansa, go to "Settings" then System Settings" then "USB Mode," then change it to MSC, if that does not work, try the other modes, just in case.
Hope this helps!
Feb 01, 2009 | SanDisk Sansa Clip MP3 Player
My sansa turns on then off
Do a firmware upgrade, but it sounds like the hardware is probably faulty. The firmware upgrade is available from Sandisks' website. Unfortunately, if that fails it may be repalcement time.
Here is some addl info:
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
If that fails, unplug the Sansa from the computer. Uninstall all the Sansa software in the add/remove programs section of Control Panel. Reinstall the clean version of the software from Sandisk’s website – make sure you get the files for the c200 series. Then replug the Sansa and try again. The root of the problem is that Sansa has one set of drivers and Windows has another. If you plug the mp3 player into the computer before installing the Sansa drivers, the Windows drivers will trump the Sansa’s.
Here is a helpful link from Sandisk on the problem with extra information on Vista operating systems:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=42&p_created=1221328944&p_sid=8VPwlRmj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzQsNzQmcF9wcm9kcz00JnBfY2F0cz0mcF9wdj0xLjQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jMjAw&p_li=&p_topview=1
-Tha Mp3 Doctor
Dec 11, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa express 1 gb
There is a power button on the side of the player
The user manual is available from Sandisk's website:
http://www.sandisk.com/Assets/File/downloads/user-guides/express-userguide-en.pdf
-Tha Mp3 Doctor
Dec 08, 2008 | SanDisk Sansa e250 MP3 Player
Pc software from internet
u can get driver from the site http://www.sandisk.com/sansa/ where u can search out for the driver after mentioning ur mp3 model... secondly, u dont need driver.. download real media player it 'll automatically sync ur mp3 with it.. and itz easy to use like apple i- tunes for i- pod
Aug 17, 2008 | SanDisk Sansa Clip MP3 Player
MP3 SANDISK SANSA
does your computer recognize it when you plug it in?
May 20, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa e200 4 gb wont turn on
1-866-726-3475 Sandisk Customer Support
www.sandisk.com
click on support at the top; click on MP3 players,
find your Sansa and click on it there’s a lot of info
Mar 09, 2008 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa c200 2Gb won't turn on
It sounds your device batteries is bad...what I will recommend you to do is to contact sandisk to see if they can RMA the device for you...Sandisk number is 1-866-726-3475..
I hope this helps...
Please rate accordingly
Thank You
Computerrep
Feb 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa c250 not working at all!
2 Suggestions: 1) It may be that the battery isnt charged, let the unit charge fully 2) If that doesnt work, its probably time to send the unit back to sandisk
Jul 23, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa e250 MP3 Player Logo
61 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
