Question about Goldstar Heating & Cooling
Air condictioner help
Wather is leakling out of the front of my air condictioner
    Problem Solver:
  • 8 Answers
Turn it off. Remove the filter . Clean the filter. When filter is out look to see if there is ice behind where the filter was. If so, let it melt. With the filter removed you should be able to at least see a little of the drain pan...which could be blocked up.If blocked, unblock it. When done, place filter back in unit, turn on, observe.
I'm assuming it is a window unit and not central air.
I hope you don't need anyone to tell you that it can't be pitched towards the inside of the house ;)
that would do it too.
Posted on Jul 28, 2008
It runs but rough idel and wants to die in gear. Cleaned the mass air flow. And troutle body.
Year/make/model didn't post? Possible vacuum leak ( loose/cracked hoses/intake gasket). Possible stuck open EGR valve. CHeck engine light on? If so, scan for codes that may point you in the right direction
Feb 07, 2016 | Cars & Trucks
How long does it take for your phone to dry
well anyway you must find a cell phone repairing station. they cay fix your phone. you cannot just dry it up as easy as drying up clothes.
Oct 13, 2014 | LG Metro Pcs Optimu Ms690 Touch Screen...
Had heater core replaced now heater only blows out defrost vents
Check all vacuum lines that goto the heater control under the right side of the dash.....also check for any connector that are disconnected. Good Luck
Nov 18, 2012 | 1997 Ford F150 Regular Cab
BIG PROBLEMS WITH MY JEEP SAHARA, I BOUHT IT NEW IN MEXICO CITY, STEAL GUARANTEE HAS 6000 KMTS, AND 5 MONTHS. ALL TIME IN REANING SEASON LEAKING WATHER INSIDE THE VEHICULE, 3 TIME IN THE WORKSHOP AND STEAL...
Hello Sofia
Does the radiator lose water? Or is it just when you turn on the air conditioner ?
mecanica03@hotmail.com , @mecanicasesoria
do you speak Spanish?
Jul 06, 2017 | Jeep Cars & Trucks
Sometimes the air condictioner will not ture on
It sounds like you might have a bad switch.
Aug 21, 2011 | 2002 Pontiac Sunfire
Can't find instructions for discovery kids animated jellyfish lamp
hi i have the discovery kids animated jellyfish lamp. only put wather in the fish tank until the filter line, when you turned the fish inside the tank the air move the wather and jelly. good look
Jan 16, 2011 | Toys
The dishwater is not draining when the washer is running. What should be checked to help resolve this problem?
is wather filter dirty, or defective/stucked wather pump.
check the water filter, and listen if any strange noise on wather hose output. it requires a some handwork. is several metalic covers it needs to be opened.
post for extra indications
Jan 29, 2010 | Dishwashers
I have a 1996 volkswagon jetta and I removed the thermostat but the temperature guage is still going pass half. Is there anyway to get the air out of the system and solve this overheating problem?
hallo
without termostat, start the car. in one minute ideling, both hoses from cooller should be warm.
If only top one is warm, check if the hose from front wather cooller to expansion tank is blocked (small one on top). usualy it is blocked on wather cooller itself .if OK, change wather pump.
also check if presure is bildinh inside wather sistem. that indicate head gasket or head itself should be checked
If you had remove the termostat, there can be no air inside the engine (if wather is inside).Even with termostat present, VW has no problem with air pockets.If your temp.go pass half when car is standing still, that is ok, but when driving must drop down.
Marko
Sep 23, 2009 | 1996 Volkswagen Jetta
Intermitant mis now full time
intake gaskets may be bad vacume leakl.
Mar 10, 2009 | 1993 Toyota T100
Heating & Cooling Logo
50 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
