I dont know which hole to refill 32 cartridge on lexmark x5450..it looks hard???
You have to remove the sticker on the front of the cartridge. Under the sticker (upper left under the sticker when looking at it correctly) is a very small hole. Put you needle into that hole, which you might have to rout open a bit, for injecting your ink. I did it and it works great. Just be sure and put a piece of tape or sticker of some sort over the hole after filling.
Posted on Dec 14, 2008
Instructions for refilling cartridges on a Lexmark Prevail Pro705 printer
Please note that Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. You might not get the print quality you expect from the ink that is specially formulated by Lexmark.
Feb 19, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
I took cartridge 31 off the printer (lexmark X5450)
The microchip in the cartridge has alerted that the cartridge has run out of ink. Only way to fix it is replace the 31 cartridge with a new one (I know that is a bummer, but it is what needs to be done)
Dec 06, 2009 | Office Equipment & Supplies
Where do i inject the ink in my cartridges on a lexmark printer. i need to refill both cartridges. i have the black and coloured ink, and the syringe, however i dont know where to inject.
Usually the refill kits come with instructions that cover many cartridges.
A lot of the lexmark's use HP style cartridges and those often you lift the label to access the fill holes.
FILL SLOWLY and do not over fill. Usually the cartriges hold so many ml and youcan measure that on your syringe. Knock off a few ml from what they say the cartridge takes.
Nov 11, 2009 | Lexmark X2500 All-In-One Printer
Installeds a refilled colour cartridge and will work but printer says empt..may do damage. Lexmark x5450 colour cartridge # 33.
Using a refill for this printer will not "do damage." The damage they are referring to is if you continue printing with an empty cartridge you can damage the print head on the cartridge. Since you replace the print head every time you replace the cartridge, you never damage your printer.
Nov 03, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x5450 gets an error 1203 message. how do i correct?
Ok this some times works.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 24, 2009 | Lexmark X5450 All-In-One InkJet Printer
IBM Infoprint1120 and Lexmark T520 toner cartridges.
You cannot use Lexmark toner cartridges in IBM models and vice-versa because the toner carts have a smartchip that identifies the toner to the printer. IBM printers expect to see IBM toners and Lexmark machines expect to see Lexmark toners. If you put the wrong cartridge in you will get '32' Unsupported print cartridge error.
Some refillers may swap the smartchip when they refill cartridges and this would be the only reason why you may have seen it done before.. IS your current toner a refilled one? It's technically possible to make an IBM printer into a Lexmark printer to accept Lexmark toners by replacing the System Board... but why would you bother doing that...just use the right toner.
May 19, 2009 | IBM Infoprint 1120 Laser Printer
RResetting Cartridges after refilling
Can't be reset. The Lexmark 32 & 33 (and porbably som others) contain a low ink sensor in the cartridge that once activated can NOT be reset. The key would be you have to refill before the low ink sensor gets activated. Don't know at what ink level that is, probably around 1/4 remaining.
Apr 15, 2009 | Lexmark X5250 All-In-One InkJet Printer
My lexmark will not work with refilled ink cartridges.
Lexmark is one of the best printers, Look to see if the heads on the printer are clean. Unlike most printers Lexmark cartridges dont do the controling, the printer does. My son replaces the cartridges, he doesn't refill because of the problem simular to yours.
Mar 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
Is there a code needed to replace a refilled ink cartrige?
No code....try removing all cartridges, powering down the printer, disconnect the power, let sit 5 minutes, then hook back up and reinstall the carts......lexmark and dell will usually continually give a :"cartridge empty" error with refilled carts, just go to the printer properties, go to supplies, and uncheck the ink level indicator to get rid of the error display.
Mar 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
X5470 Lexmark printer
i refilled my lexmark 24 color cartrgide but now the printer does not want to read the cartridge, any help on resetting the thing before i chuck it trew the window
Nov 12, 2007 | Lexmark X5470 All-In-One InkJet Printer
k24674
jasbo
jasbo
