Question about IBM Corded Phone IBM412CID
NO SOUND WHEN PLUGGED IN JACKs
Have already replaced 3 of the original 5 phones.. Three are working now but cannot get the other 2 to co-operate. I no longer have 4 lines into my home;only 2. Can't get a dialtone or sound when plugged into jacks but phones can be programed for correct ext.,date,etc. . I have changed connection lines from jacks to phones using muti lines or singles, NOTHING works. HELP
  • janousfarms Jul 28, 2008
    I have read and re-read all manuals.
  • 300 Answers
Have you verified that the jacks affected have DT on them with another single line phone? If it doesn't, it could be a wiring issue between the NID (Network Interface Device) where you service comes from the pole to the house. This could especially be the issue since you have recently had lines DC.
Most NID's have a service jack where you can plug a phone in from the NID. This will bypass all possible inside wiring issues that may exist.
I would start from there and if you have dial tone at the NID. Then verify that you have jacks wired the same as the NID.
Thanks
Posted on Jul 28, 2008
  • 818 Answers
  • IBM Master
  • 19,396 Answers
Try disconnecting all phones from power, if it is a setting problem this will reset the system
Posted on Jul 27, 2008
  • Ginko
    Ginko Jul 27, 2008
    Try disconnecting all phones from power, and also disconnect the data jacks if it is a setting problem this will reset the system
    I donot know if I understood, What is the problem? do you lose dial tone when you plug data jacks in?
    Here is user manual for reference,
  • Ginko
    Ginko Jul 28, 2008
    I assumed you have the manual already if you have 5 phones, I posted the manual so we can have a reference.
    About phones, if you simply do not have dial tones on two on five phones, try first a different wall plug and phone cables (sure you did this already), just in case.
    Then make sure the line connection on the non working phones is programmed ON, if they had OFF in this memory setting, they won't connect to phone line.
    If this is not the problem, the phones are faulty " line connection " is the only setting that can cut off phone line.
Front 4 usb ports and microphone and headphone jacks don't work but the rear usb and speaker jacks do work. I've had the computer new since 2009 and they have never worked.
it sounds to me like the wires from the front panel connectors are not connected to the motherboard inside the computer case, open the case up find the front connectors wires inside and find out if there are any connectors on the motherboard to plug them into.
the reason the rear ones work is because they are soldered directly to the motherboard.
good luck.
Jun 28, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
All three were working but 2 of them quit suddenly and say "Check Tel Line". The one that still works is plugged directly into modem. The 2 that say check tel line will work if i plug them into modem just...
This phone system should only have one physical phone jack connection as all the handsets are wireless. It sounds like you may be getting your phone service via your Internet Service Provider. It would help to know how you are connecting your home telephone wiring to your equipment.
Oct 29, 2013 | Uniden DECT1560-3 DECT 6.0 Expandable...
Why aren't my speakers producing sound?
click start control panel hardware and sound manage audio devices playback you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list also right click on the speaker select properties you should see a few tabs general levels enhancement and advanced you might find you need to select a different option possibly stereo or dvd or studio quality windows7
hope it helps
Mar 02, 2012 | Audio Players & Recorders
Three speakers stopped working. all plugged in. why?
could be anything, check the speaker jacks for power with a multimeter, set to ohms, 5-10, or so.
Mar 13, 2011 | LG LHB335 Theater System
RECEIVING THE CALL IS VERY SLOW,SOME TIMES IT IS RINGING SOMETIMES NOT (MAXIMUM TIME CALL RECEIVED WITHOUT RING TONE) OVER ALL OPERATION OF THE PHONE IS VERY SLOW
1. Make sure your phone is fully charged.
2.
Backup your contacts list and personal files to MMC memory card (if possible).
3.
Switch on your phone.
4.
Press and hold these three keys together:
* Red dial key,
* Sharp key (#)
* One key (1)
5.
5
Press the power on/off to swtich off the S60 phone. Do not let go the three keys until you see the "formatting" screen displayed
6.
6
Wait a few minutes until the format is complete. Your phone will now be at its original factory settings
Method 2
1.
Before you format your phone, make sure you back up all your ringtones, SMS and picture messages and most importantly yout contacts. You can use the Nokia PC Suite to do this.
2.
Press Red key, select disconnect.
3.
Once you've done this, key in *#7370# *#7780# . It will immediately prompt you to restart your phone.
4.
Select 'Yes' and the phone will restart after formatting. It takes about 2 to 3 minutes to complete the process. Also ensure that your phone is well charged before you format.
5.
5
Now restore all your ringtones, messages and contacts and you once again have a fresh OS.
Dec 02, 2010 | Nokia N73 Cellular Phone
No sound at all. all drivers are good, all volumes are good but no sound.no even system sounds.please help
Bad News boy, Since you already checked the drivers and teh volume option. which makes it eaasy for us to identify the root cause of the problem.
So try these steps.
1. Check in sound and audio device properties in control pannel, if you have the correct audio device listed. also check if nothing is on mute in volume control.
2. if its not the correct one. i suggest remove the existing driver from add and remove program and then try reinstalling it.
3. If thats the correct one, then Check if the external speakers / head phones produce sound.
4. if yes, then everything is fine in the computer, Don not do anything as all the software is fine.
5. If no, then the internal speakers have gone bad, which is ver rare, but it may happen.
Consider replacing the internal speakers,
I am sure this will help you.
Best of Luck!
Please rate this solution, if you find it helpful. :)
Thanks.
Aug 20, 2010 | Toshiba Satellite A105 Notebook
I have 2 models # TM3111-2 One is plugged in to the phone line and to a power oulet. They both show charging but I don't get a dial tone when I pick up the reciever. My desk phone is plugged into the...
There is a solution which is easily implemented if you have discontinued phone service from your landline carrier.
1. Find the "block" where the landline enters your home and disconnect the wire which enters the block from the phone co.
2. At this point the wires in your home are "dead". If you had a dial tone before, you should no longer.
3. From your t-mobile@home router connect the phone line output to one of the regular phone jacks in the wall.
4. You should be able to now connect your vtechs to any outlet in your home --- regardless of the distance from the router.
5. You also can use your old regular wired phones if you wish to.
Aug 12, 2008 | Vtech Lands Phones
Speaker hook up
Shari,
It is my hope that I can help. This applies to the type of sound card on your PC.
- If you have a 2-channel sound card: Select 2 on the source selector switch on the subwoofer. Connect the green plug from the audio input cable to tyhe front jack on your PC sound card. With this input setting, your speakers will upmix the 4-channel signal and create a center signal for your speakers.
- If you have a 4-channel sound card: Select '4' on the source selector switch on the subwoofer. Connect the colored jacks on the audio input cable to the jacks on your PC sound card, making sure to match the colors.
- If you have a '6'-channel sound card: Select '5-1' on the source selector switch on the subwoofer. Connect the colored jacks on the audio input cable to the jacks on your PC sound card, making sure to match the colors.
Your sound card is located on the back of your PC Tower.
Good luck
Jun 24, 2008 | Logitech Z-5300 Computer Speakers
Two lines stay lit
I suspect someone disabled lines 3 and 4 on these phones.
To re-enable these lines:
1. Press PROGRAM
2. Press *
3. Press #.
4. Enter one digit on the keypad for the line number.
2=L2
3=L3
4=L4
5. Press 0 to turn the line off, or 1 to turn the line on.
6. Press Trnsfer. You will hear a confirmation ring if you entered the data correctly.
Alternately, you may have only plugged the line into the L1/L2 jack on the back. This phone does not take a 4-line jack, but instead takes two 2-line jacks.
May 19, 2008 | AT&T 954 Corded Phone
IBM Corded Phone IBM412CID Logo
74 people viewed this question
Top IBM Lands Phones Experts
Computer Repairing
Computer Repairing
Auntie Nerd
Level 1 Expert
Are you an IBM Lands Phone Expert? Answer questions, earn points and help others
