2002 Jaguar X-Type Logo
Posted on Feb 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
O2 jaguar x-type can you replace bulb in headlight assembly or do you replace assembly
Anonymous
Level 2:
New Friend:
  • Expert 50 Answers
  • Posted on Feb 23, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
50
Questions
0
Helped
25620
Points
153
You only need to replace the bulb, they can be hard to get to sometimes. here is the link
http://www.racepages.com/products/?N=4294962489&Ntt=Jaguar+X+Type+Headlight
How do you repair a headlight assembly?
you may have dislodged the reflector from the unit housing. retaining fixings remove the lamp assembely and remove the bulbs then try and refit the reflector back in to the retainers by pulling them back through the bulb holder holes
How to change headlight 2003the x type Jaguar
look inside owners manual in glove compartment look up bulb replacement in the back index it will show and tell you how to replace headlight bulbs. be sure to wear clean gloves, because headlight bulbs or halogen type bulbs, if oil from hands or skin touch the halogen bulb it will cause halogen light bulb overheat and blow out.you can go by auto parts store when you buy new headlight bulb the salesperson will go out to vechicle and replace headlight bulb for you wont charge you any thing.just charge you for the headlight bulb.
I have a 2003 Jaguar X Type 2.5L automatic. One of the options is Auto Leveling Headlights and HID headlamps. My problem is it seem the auto level is not working properly. They do cycle when I turn them on...
These are a real pain in the rear. The headlight assembly that makes them move is plastic and breaks easily. I've spent 1200.00 replacing one only to have both go out in 6 months. Hitting a pot hole will break them. They sell the whole assembly. I ended up finding a fix online with a 2.00 screw to hold them in the proper place and had a local body shop do the fix for me. They agreed that it was a huge waste of money to buy the whole assembly only for it to break again. There is a positioning port at the top of them, but you have to have a Jag dealer adjust it or it will strip out if you try using just a screw driver.
2answers
2002 Jaguar x-type 2.5 headlight bulb part number?
All Jaguar X type headlight bulbs are H-1. Any auto parts store will carry it. No matter the quality, just ask for H-1. What you want to spend depends on you.
I need to replace bulbs in my 1995 Vanden Plas, Can anyone send me the removal instructions for the instrument cluster?? It would be muich appreciated
1. Locate the bolts holding the bumper cover in place. Use a socket wrench to remove the bolts, allowing you to pull the cover down. Then take off the bolts securing the headlight assembly and pull out the entire assembly from the car.
2. Squeeze the retaining clip on the washer hose with a pair of pliers and pull it back, then pull the hose off. Next, unplug the electrical connector.
3.Unbolt the headlight washer motor with your socket wrench to gain access to the bulb. Pull the bulb straight out and take it to a Jaguar dealer or the local auto-parts shop to purchase a replacement bulb.
4.Reassemble the light assembly in the reverse order. Plug in the new bulb, re-bolt the washer motor, plug in the electrical cord and reattach the hose and retaining clip. Finally, re-bolt the headlight assembly and the bumper cover.
5.Turn the car on and switch the lights on to test the newly installed bulb.
2answers
I have a 2002 x-type jaguar,i need to replace the front lights that are burn out.do i need to take the hole front bumper off? how?
Inspect/Replace-I don't think that removing the bumper is necessary. There can be slight variations in procedure from one model to another when replacing headlights. For instance, on some models the turn signal light assembly must be removed before the headlight can be replaced. Overall, however, the procedure does not differ much from the following typical instructions.
Make sure the replacement bulb is the same type and part number as the one that is being replaced.
f19-22.jpg Comparing the old and ther replacement headlamps. To Replace:
  • Remove the headlight bezel retaining screws. Remove the bezel. If necessary, disconnect the turn signal lamp wires.
  • Remove the retaining ring screws from one or both lights.
  • Remove the retaining rings.
  • Remove the light from the housing. Disconnect the wiring connector from the back of the light.
  • Push the wiring connector onto the prongs at the rear of the new light.
  • Place the new light in the headlight housing. Position it so the embossed number in the light lens is on the top.
  • Place the retaining ring over the light and install the retaining ring screws. Tighten them slightly.
  • Check the aim of the headlight and adjust it, if necessary.
  • Install the headlight bezel. Secure it with the retaining screws.
  • Connect the turn signal lamp wiring (if it was disconnected).
1helpful
Need a quick breakdown on how to replace a headlight bulb on a 2004 Jaguar x-type, 6 cyl., 3.0
do you know what H type of bulbs you have?
some are just a twist other have a clip that needs to be pressed and let fold down to allow bulb removal.
in the engine comartment behind where the headlight are there are either rubber boots or clips that need to be removed to expose the back on the buld.
remove the retaining clip as mentioned above or gently twist he bulb to remove it. now remove the old bulb from its holding wire.
when inserting the new bulb do not touch the glass as oil from the skin and disrupt its performance.
reverse the removal process and do the same on the other side.
NOTE: the new bulbs elements are in a slightly different postion in the bulb than the old ones (no two bulbs are exactly alike) for best visibilty have you headlight realligned after bulb replacement.
2helpful
Changing the low beam headlights on a 2004 Jaguar X type
there are to metal clamps on the back of the headlamp assembly and remove the cover
1helpful
Headlight assembly.
Hello
Unfortunately yes
Top Jaguar Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Jaguar Expert? Answer questions, earn points and help others
