Question about RCA D52W19 52" Rear Projection Television
Channels wont come in
Hi There
i am unable to bring channels 2-6 i can get all of the other channels up intil 28. can you please help?
  • trevhunt Jul 29, 2008
    Son i'm not the only one! Hi there I have also lost channels I have lost 1 to 47. At first i thought the it was the amp. for the cable but when i plug in the small tv it works fine.
  • brook6 Aug 17, 2008
    I am having same problem...channels 2-6
    Sometimes the channels will come in - with vertical lines tracking across and picture is jumpy. It will be poor quality for a while and then go black. Other times it just goes black immediately and sound is still there.
    I called cable company because I thought it was their signal. They said something about something in the TV that translates the signal for those channels is not working right. Said, even though the TV is always on channel 3, there is something being lost in the translation.
    TV is fine on other channels, so wish I could find how to fix this.
Sounds like the tuner is shot...mine is. easy cheap solution is to use either a cable box or a vcr as your tuner (hook it up to the a/v input if channels 3 and 4 are currently affected)
Posted on Aug 17, 2008
My Seiko 28" wont show some of the freeview channels i.e.channel 2 plus several more. Any ideas
If it won't show the channel then the channel is not available, period.
Jun 08, 2017 | Televison & Video
I have a brand new technika tv 216/54g. It has freeview built in. I have a brand new indoor digital amplified aerial also technika but I cant get it to pick up any stations. Do I need anything else? please...
You don't necessarily need anything else, but you may not have a strong enough signal to pick up the digital/freeview channels using an indoor aerial. It could also be that the indoor aerial is not correctly aligned.
If the signal strength is lower than approx. 50%, the TV may detect them during the automatic channel scan but it wont store them. When the signal strength for any digital channel is 50% or lower it's more or less unwatchable - the picture would be constantly breaking-up or freezing and the audio drops out continually. Trying to scan for channels using an indoor aerial is rather hit and miss. Numerous attempts may be necessary before you get any channels.
Assuming you have a roof aerial, it is far easier to temporarily connect the TV to a fixed aerial point while you run the automatic channel scan. The TV will store all the channels and you can then move it to it's permanent location and connect the indoor aerial. You can then adjust the indoor aerial with the channels already stored until you find a location for the aerial where you have a good signal.
Doing it this way also eliminates the possibility of a fault with the TV and confirms that you are performing the channel scan correctly. If the TV is connected to a fixed aerial point and you are still unable to receive or store any channels, then it's likely that you are performing the channel scan incorrectly or there is a fault with the TV.
Please try scanning your channels using a known working fixed aerial point. If you are still unable
to receive any channels - or you don't have any fixed aerial points - please post back for further assistance.
Hope this helps.
Regards,
BElectric
Feb 28, 2011 | Televison & Video
Have no tv remote for durabrand tv - nr 28 t 67-wm is there any way to switch to av without remote?
Hi there
For many brands the way to find the a/v input is to use the channels buttons and go below channel 2 or above 125.
Or you might find it in the menu if you can access it.
Hope this help. Merry christmas
P.s please do not rate this answer (unless it helps) as it is only a suggestion.
Dec 16, 2009 | Durabrand DWT1905 TV
Hi.i have the box and all my channels are fine except sky movies channels and mtv channels. i tried everything but i just cant bring them back. please somebody help its been 2 days and im about to...
Try Menu-Installation-Manual Scan-Down Frequency 000000-
Network Scan Enable (change with R/L arrows on remote)
Wait a moment press OK, and they should be at the end of your list.
hope that works.
Oct 08, 2009 | StarTech.com StarView SV211K 2-port KVM...
Hi.i have lost sky sports and setanta sports
Just updated using below, have got all back
have u tried a factory reset 0000 to delete,power off at back/on and autoscan ur provider,and emu to on,usually brings them back,do not scan thru splitters as u will lose channels.
Jun 10, 2009 | StarTech.com StarView SV211K 2-port KVM...
New code for starview box
worked for me, got the rugby on
sometimes channels change frequency so they dont work,have u tried a factory reset 0000 to delete,power off at back/on and autoscan ur provider,and emu to on,usually brings them back,do not scan thru splitters as u will lose channels.
Jun 09, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Cannot tune analog channels on Bush 32'' LCD TV
Hi I am Vortash not a set I have worked on but suggest that the solution will be in the user manual , if you have no user manual try this site http://www.safemanuals.com some of the downloads by adobe pdf file are free others reasonably priced I hope this is of help Regards Vortash
Apr 06, 2009 | Bush WS6671 28" TV
Unable to get digivox-t to find channels on chorus.
chorus 00:CE 19 2E 87 80 61 74 90 01:62 FA D9 F3 CE 05 FA 79 new codes
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
New codes
3e d1 42 35 42 e2 45 ee
40 c0 b5 7f a2 28 a9 ec
both new lines gd
Aug 07, 2008 | StarTech.com StarView SV211K 2-port KVM...
Wharfedale LCD3210AF Television- Digital problems!
Well there is still a problem with the TV. I found that by unplugging the power cable that the digital channels worked. But, when I turned the TV on today the problem had returned, I had to take out the power cable again!
Feb 11, 2008 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
23 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
