Question about Mitsubishi WS-55859 55" Rear Projection Television
Timer light flashing dont trun on, can you bypass the boards and run it like a monitor
  • udoka33 Jul 29, 2008
    The same problem...timer blinking on and off with no pics/sound. I have tried unplugging and reseting but that did not help.
  • Mitsubishi Master
  • 8,617 Answers
You need the DM repair kit called the V21 / v19 DM repair kit which contains the parts and step by stepp instructions with pictures to repair the most likely cuase for that symptom, and its less than a service manual cost and they include the service manual for free as a bonus on the instructional CD. Heres the link its under their repair kit section
Posted on Jul 28, 2008
My laptop trun on but dont display
Try hooking up an external monitor if that turns on then you need to replace your display. If not then your mother board may have died and the fans and lights are just working. The hot keys to switch to external display is different per model but they are usually one of these Fn + F3, F4, F5, F8, or F9
Feb 06, 2014 | Computers & Internet
Does not trun on led flashing plasma tv p50h401
Bad power supply or another board---parts are not sold only boards for these sets. Best suggestion is have it taken to the shop and get an estimate for repair.
Apr 22, 2012 | Hitachi P50H401 50 in. Plasma HDTV
The power button on my monitor flashes but will not trun on
There is a chance that you may have a couple bad capacitors on the power-inverter board but more than likely the problem will be a shorted out transistor. There are 4 on the inverter side of the board and one set may have gone bad. Capacitor problems may have caused the transistors to fail. Transistors are probably c5706 or c5707 and are black with 3 legs going though the board.
You would have to open it up to check and would need an ohm meter to verify if the transistors are shorted out.
Aug 18, 2010 | Dell 1703FPt 17" TFT LCD Flat Panel...
Power up show the pc name and then it trun it self off trun it back on and I cant even get the meun to show up
need to replace two capacitors on the ccfl side of the main power board. CCFL is where 4 plugs from the lights in the LCD plug in. You will see brown or burned capacitors, which were probably blue. One on each side of the board. The replacement part is Digi-Key Part Number P9643-N. This is a known issue with gateway monitors.
May 23, 2010 | Gateway FPD2275W LCD Monitor
LCD Screen blank
The picture board on your monitor is bad, since the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 25, 2010 | Acer AL2416WBSD 24" Monitor
Red LED lights
power supply shot ... sometimes x board or y board
Oct 02, 2009 | Pioneer PureVision PDP-5030HD 50 in....
Heatpump defrost board
REPLACE THE BOARD IS BAD ALSO CHECK FOR 24 VOLTS FROM COMMON AND RED TO MAKE SURE THE BOARD HAS 24 VOLTS.
Jul 01, 2009 | Icm 302c 302 Heat Pump Defrost Timer...
ViewSonic VX910 monitor appears to have power supply issue. The power light comes on for less than 1/2 sec, then goes off for about 1 sec, then just flashes green. If you play with the switch and the A/C...
try running the self test on the monitor
Self Test:
turn off the system disconnect the data cable from the tower and connect only the power cable to the monitor and trun on the monitor if you see colour full bars then the monitor is ok then try to go BIOS and see if the monitor is working
Jul 01, 2009 | ViewSonic VX910 19" LCD Monitor
INDESIT WI101
hiya
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
Pc wont turn on
removed hard drive, floppys , extra memory all pc cards
everything you can and try it again
Jan 18, 2008 | Antec TruePower Trio 550 (TP3550) 550-Watt...
Mitsubishi WS-55859 55" Rear Projection Television Logo
94 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
