Question about Samsung PCN5425R 54" Rear Projection Television
Turn on and turn off
I have bought this tv been almost 4 year ..
i try to turn on the tv and goes off automatily and the timer light goes on
  • platinumspor Aug 21, 2008
    Also have same problem, with the same model. Any help would be appreciated!!
  • ursillytoo Aug 26, 2008
    Me too!!! Anyone find out how to fix it? We've had the tv for 5 yrs. All of a sudden it won't turn on but the timer light flashes until you hit the power button again. What do I do?
My tv wont' turn on also light blinks 10 times
Posted on Oct 19, 2008
I have completed the setup of my Day-Timer Mwave Tx12626x Timex Electronic 7 Day Timer. I turned on my television, then plugged it from the outlet, then plugged it into the timer. The TV will not turn on...
Open following link to identify your timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
1) Don't expect the timer to turn on the TV picture.
I have my TV plugged into power strip.
Each night the power strip is off. When power strip resumes next day, the TV is READY to be turned on with the remote control. The picture does not pop up when the power strip goes on.
Same is true for timer.
Try your power strip and see if picture turns on after power strip is turned off-on.
Timer will work same as on-off switch on power strip.
2) Is the power strip interfering with timer?
Plug timer directly into wall outlet and see what happens.
Add a comment and let others know what happened.
3) Battery: Timer requires 2-hours for initial battery charge.
Battery back-up protects programs when power is off.
I don't know if battery is made for repeated on-offs if you turn off power strip each night.
These batteries are not replaceable however timer has 1 year limited warranty.
4) Plug lamp into timer and see if timer operates lamp. This will say if TV electronics are interfering with timer operation.
5) Load: This timer says it is for appliances, which implies it should be rated typical 15A 1800 watt
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 04, 2011 | Day-Timer Mwave Tx12626x Timex Electronic...
I bought a mitsubishi wd 52327 new several years ago. I've replaced the lamp once and it worked fine but now it needs to be replaced again. We bought a lamp off EBay w/housing. I installed it but the tv...
Hi Brent, Mitsubishi's have a problem with the power supply and the Light Engine which incorporates the Digital Module of which it has to be purchased as a complete assembly. I sincerely believe you should not put that kind of money into a dlp set. The cost of the light engine is in the area of $1100.00. Your last idea is the best one.
Mar 09, 2011 | Mitsubishi WD-52327 52" Rear Projection...
Turn on tv...green lamp blinks several times.lights up but no picture...press any remote button timer in green blinks...tv turns off and goes to standby
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
Nov 17, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
JVC TV AV-32870 will not turn on. blinking timer light
Worth taking it in since it is hard to find a new TV for less than $300. I have a 32 inch JVC iart that for about 2 years would turn itself off and the timer light would blink. Only thing that worked would be to disconnect and turn back on. Eventually, the tv "popped" I could smell something that burned out and within 3 weeks tv went "dead" Took it to a tv repair place and replaced power unit for $150. I had similar problem with a 19 inch Philips and that tv has been going strong for 4 years since repair.
Good Luck
Oct 17, 2008 | JVC AV-32820 32" TV
Sony KV-27S42
If the screen won't come on then the diagnostic will never show. The 4 blinks is an error code. If the set is older than 12 years then it doesn't owe you anything, you got your money's worth out of it. Average life of any tv from that genre is 8-12 years. It's time for a new set, or take it in for an expensive repair ( pending parts availability).
C-Dog
Feb 10, 2008 | Sony KV-27S42 27" TV
TV wont turn on power button flashes and record timer comes on.
For ANYONE to claim a TV will last for 20 years is outrageous! I don't care if it cost 10,000 dollars that is the wrong thing to say. Plasma TV's do generate a lot of heat and heat is the enemy of electronics. I would shop around for a repair because to quote $700 without looking at it is also outrageous. Then again it is well below the cost of a replacement Pioneer plasma.
Apr 20, 2007 | Pioneer PureVision PDP-4340HD 43 in....
T.V. turns itself off
before any attempt to deep cause of problem, unsolder first all the tack switches in the front panel of tv.then turn on the tv using remote control observe? cuz maybe one of the switches is stock.if not,proceed to eeprom servicing which is u have to look for service mode of ur tv model to unlock it and reset it to factory value.
Sep 12, 2006 | Philips 32RF50S 32" TV
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
142 people viewed this question
Henry  Thomas
Henry Thomas
