The
Canon G9 has a design defect, two screws fall out inside the camera and
short out the fuse. If you've never had it fixed for no power before
this is most likely what has happened to your camera.
Do a Google
search for "canon g9 no power repair" and you will see a full repair
service including return shipping of your camera for just $85.
Hope this helps!
Thomas
Owner, Darntoothysam.com Digital Camera Repair
SOURCE: canon sd1000 camera won't turn on. battery is fully charged.
Make sure or Check out following thing :-
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
SOURCE: camera will not turn on
clean the bazttery comparment,contact points,if u fail to get on the camera,then it is problem of power section,so contact canon service station
SOURCE: Olympus 770 SW waterproof etc camera doesnt work -
Hello :
I advice you to replace the battery with brand new one . I think that the battery is dead . A dead battery may appear recharging but it could be fake display .
good luck .
please don't forget to rate !
Testimonial: "thanks for your advice will give it a go!!"
