Question about GE MiniCam Pro HO98756 Webcam
Fuzzy is there anyway i can make the picture quality less fuzzy. adn also my voice doesnt match up 2 my lips moving.
    Genius:
  • 1,689 Answers
Have you tried updating the software fo your device?
Posted on Jul 27, 2008
The voice is not matching the the picture...lip sync issue.. what to do?
Make sure that the audio out is coming from the television and not the same source that is sending picture to the television. this will fix the problem for you.
Jan 31, 2011 | Harman Kardon AVR 35 Receiver
Print head is not printing seems to be clogged from non-use. Have tried test printing through several new cartridges and still not working. Can the old - dryed ink be cleaned off of the print heads?
Hi, below is from the brother website for your model. Very common for the ink heads to become clogged /dry out. You probably have done this but here it is anyway. your print head is part of the machine, so it will need to be disassembled to clean it, That can be very difficult. Try the following anyway, it might help you. also, you could try using a Q-Tip wet with vinegar water to get under to the bottom of the print heads, if you can get the head to move off its dock and then unplug it when its moved over. anyway here is the Brother link info (without pictures-see the link above if you need the pictures)
  • Print a Print Quality Check Sheet.
    1. ress the Ink or Ink Management key on the control panel of the machine.
    2. Press the up or down arrow key to choose Test Print and press OK.
    3. Press the up or down arrow key to choose Print Quality and press OK.
    4. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
  1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
  2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
    (A) One or more complete blocks of colors are missing:
    (B) Most of the short diagonal lines are missing from one or more color blocks:
    (C)Some parts of the short diagonal lines are missing from one or more color blocks:
  3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to chooseNo for black with the problem.
  4. The display will then ask you if the print quality is OK for Color. Press down the arrow key or 2 or "-" to chooseNo for color with the problem.
  5. The display will then show Start Cleaning? Yes No.
    Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
  6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
  7. Repeat the cleaning and the quality check process following the Step 4-7.
  8. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
    • If the print quality on the first Check Sheet matched Example (A) or (B) and you do not see any improvement on the second or third Check Sheet
    • If the print quality on the first Check Sheet matched Example (A) or (B) and you see some improvement on the second or third Check Sheet but it's not perfect, repeat the cleaning and the quality check process three more times (totally five times).
    • If the print quality on the first Check Sheet matched Example (C) and you do not see any improvement on the second or third Check Sheet, repeat the cleaning and the quality check process three more times (totally five times).
    Press Stop/Exit.
Aug 29, 2010 | Brother MFC-5460CN InkJet Printer
I have a JVC G40 DVD home theater system and when I play DVD's the voice and picture don't match up. Specifically, Peoples lips move and then a second later what they say is heard...how do I fix this?
When viewing on Digital TV:-
Sometimes Audio and Video signal can not be transmitted simultaneously due to additional process time for the video signal compared to that of the audio signal.
Often video signal takes more time than the audio signal to convert from analogue signal to digital signal in the Digital TV.
It may result in mismatch of the picture and sound.
In the TH-G30/40's HD AV Sync menu, you can adjust the audio signal delay for simultaneous AV signal transmission
1. Delay time can be varied in 10msec steps.(0 to 300ms)
2. Delay time is different between TV Brands.
So you need to adjust the delay time for correct lip-sync.
The adjustment is listed in the instruction book page12
Jun 26, 2010 | JVC TH-G30 Theater System
The picture is very fuzzy (pixelated) when you first turn power o
this problem occurs usually in the power supply change or check the power supply borad
Dec 18, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Sound doesnt match lips
Hi
Theirs no doubt you have a software problem with this set,happens a lot on the sharp range too,the software will need upgrading to the latest one for that model.Go to manufacturers website they may have it their with a "how to"note
Jun 04, 2009 | Soyo DYLT032D 32 in. LCD Television
Just purchased tv and the quality of the picture is still fuzzy tried to mess around with the resolution but it still isnt very sharp at all
The TVs produce picture using entirely different methods. Usually the colors and especially level of black color are better on plasma, LCD will have some trouble various shades of gray and black especially shading on peoples faces etc.. This is not a defect in the LCD just a limitation in current technology.
Apr 26, 2009 | Televison & Video
Web camera is not a clear picture
is it because its dark? for this webcam and alot of other webcams, the lighting of the room is a kep factor for the quality of your picture =]
i think the reason the picture sucks and its fuzzy and the playback is slow is because its dark, in your room... theres like a funnel looking thing infront of your lens, try to keep the funnel thing from keeping a shadow.. if you see in the daylight with the windows open or open lighting from the sun, the quality of your picture is bomb =] if this doesnt work, im sorry =]
Jan 17, 2009 | HP EW192AA Webcam
Sound Issues
when the voices start lagging behind hit stop and then play and they will be fixed!
Sep 06, 2008 | GPX D1816 DVD Player
Bad signal on my sms 2
i had the same problem, don't use rf, use an ave cable you can find them on ebay
Apr 03, 2008 | Sega Master System Console
Fuzzy, cloudy pictures
As basic as it sounds, is the lens dirty? The tiny surfaces of digital cameras' lenses really affect image quality. Also check the image quality setting to ensure you're shooting at a high quality setting.
Dec 31, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
GE MiniCam Pro HO98756 Webcam Logo
66 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
