Question about Brother MFC 420CN All-In-One InkJet Printer
Control center I have to constantly reinstall the control center on my MFC420CN. It doesn't make any difference whether I do a clean install (after removing all Brother files) or a repair installation, I have to repeat it in a couple of days. Please advise. Thanks
  • dmaire Jul 28, 2008
    I am on XP the error message says "Failed to start. The required registry informtion is missing Reinstall MFL- Pro suite CC025
  • Brother Master
  • 19,396 Answers
Try saving settings.
What kind of error message do you get?
Posted on Jul 28, 2008
  • 1 more comment
  • Ginko
    Ginko Jul 28, 2008
    and also what operative system do you use (Vista, xp, MAC etc.)?
  • Ginko
    Ginko Jul 28, 2008
    This kind of problem may also be caused by ald software versions
    Download latest software from Brother here
  • Ginko
    Ginko Jul 28, 2008
    Yes, it is a software problem, if reinstall from Brother did not fix it, then the problem is with windows, in this last case you will need to reinstall windows.
Cursor freezing
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it.
Remove the trackball inside the mouse.
Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring.
Clean the outside of the mouse with rubbing alcohol and a cotton ball.
For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth.
Solve Hardware Problems
Make sure the mouse is connected properly.
The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction.
Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer.
Connect the mouse to another computer, then reboot the PC.
If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system.
Also, try a different mouse on your computer.
If there is no PC freeze, your mouse is probably malfunctioning.
Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub.
Connect the mouse directly to one of the USB ports on your PC.
Try different ports until you find one that works.
Replace the batteries.
If you have a wireless mouse, replace the batteries with fresh ones.
Also, try using a different kind of mouse pad.
Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse.
Install more RAM or memory.
If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs.
Installing more RAM will help your PC run more efficiently.
Solve Software Problems
Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse.
Remove any new hardware and drivers you may have installed, then reboot the computer.
Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System."
Select the "Device Manager" tab, then scroll to and select your mouse.
Uninstall any drivers that are listed.
Unplug the mouse and reboot the PC.
Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted.
Remove viruses.
PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours.
Also make sure the virus definitions are updated regularly.
Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze.
Go to "Control Panel," then click "Display," and then "Change Display Settings."
Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot.
Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
hope this helps
Oct 09, 2012 | Sony Vaio VGN NS20E Laptop Car- Air DC...
Volvo s90 cruise control doesn't run at a constant speed
You may have a failing Cruise Control Servo. Have the servo tested by a Volvo or other qualified service center.
Apr 22, 2012 | 1998 Volvo S90
Blinking lights
Power off printer, remove power plug from printer, remove usb cable from printer, pull out paper and check for jams, check toner cartridge, clean area underneath the toner cartridge head, uninstall printer from windows control panel, reboot computer, plug-in printer with a different working usb cable, plug in power to printer, power on printer, reinstall printer driver. All in those steps exactly. If that doesn't work I would say you have a bad printer on your hands.
Nov 16, 2011 | Dell 1110 Laser Printer
Cant get sound
This can often be as simple as the speakers being unplugged, plugged into the wrong jacks, or powered off, so don't overlook the obvious and check to be sure. Also check the volume controls in Windows or your application to see that they are turned up and not muted. When you are sure the volume is turned up, the speakers have power and are plugged in, and the speaker configuration is correctly identified in Windows (some audio hardware uses a proprietary mixer control for this job), you need to verify whether the problem is with the speakers or the sound card. Connect different known-good speakers and see whether they work. If they don't, the issue is in the sound card-possibly the configuration of the card is incorrect or the card itself is defective. The first thing to try is clearing the ESCD in the BIOS Setup. This essentially forces the plug-and-play routines to reconfigure the system, which can resolve any conflicts. If this doesn't help, try removing and reinstalling the sound card drivers. Finally, if that doesn't help, physically remove and replace the card from the system. You might try replacing it first in the same slot and then in a different slot because timing issues can sometimes exist from one slot to the next. If that doesn't work, you must try replacing the card. If the sound "card" really isn't a card but is integrated into the motherboard, first try the ESCD reset and driver re installation. Then, if that doesn't work, you have to try disabling the integrated sound and perhaps installing a replacement card.
I hope one of these solutions help.
Sep 05, 2011 | Systemax AOL Optimized PC (100607) PC...
How do I re-install Vista Home Basic that has been upgraded to SP2 through Windows Update? Some of my system files got corrupted and I want to figure out whether Vista SP2 has to uninstalled prior to doing...
Just reinstall vista from the CD which came with your PC, when complete, Boot up and connect to the internet. Windows will want to update automatically, during this process, the later service packs (SP) will be downloaded and installed.
Jul 04, 2011 | Dell Computers & Internet
My brand new cruzer 8gb is not working...I have just purchased it and i popped in into my usb drive but im getting nothing no acknowledgment of anything from my pc...The only feedback im getting is a...
If you are getting a red light from your usb drive
then there seems to be a problem with the usb drives from the device
On your computer does it reflect the device
Please check in device manager> under universal serial bus controllers is there any symbols like ! or ?
if there are any symbols then you need to reinstall the usb drivers
> if you have recvd the driver cd you can go a head and install them else
you can go to control panel add hardware and follow the screen
else
Mar 03, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Brother mfc420cn flushing box
The Brother part number is
LF4818001
Try an online search for that number, or go to Brother's website to look up a local service center. The part is cheap, but kind of hard to get to.
Feb 09, 2010 | Brother MFC 420CN All-In-One InkJet...
Reinstall the scanner
The printer my have corrupt the setup of your scanner. So try and uninstall the setup properly and install it again.
How to unistall go to your control panel-Double click on Add or remove programs-then click on the scanner's setup then click on remove or change.
LATEEF FOR FIXYA
May 14, 2009 | Fujitsu fi-5110C ScanMaker Scanner
Error message
It seems that the adapter is not installed properly ..... uninstall the adapter from control panel >> Add & remove programs Reinstall the adapter again by using it on different port .....
thus says linksys...
May 08, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Brother MFC 420CN All-In-One InkJet Printer Logo
62 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
