Question about HP LaserJet 6L Printer
Trying to install laser 6l on windows xp
It says spooler service is not running???
My printer is hp Laserjet 6L pro
is not running properly in window xp
Posted on Nov 25, 2008
Keeps on printing test page
In this case what i would request u to do is:
1. Let the Printer be Connected to the Computer......
2. Click on start then Click on Run or If Windows Vista Type Services.msc Under the Run Window if XP,Under Start Search if Vista.......
3. On that Services Local Window u need to find Print Spooler just Double Click on that and Click on Stop..........
4. Now let that Window still be Open now click on that start Menu Click on Run If XP........
Type in "Spool" and Click Ok...........
5. Double Click on Printers and Delete Each and Every File Inside the Printers Folder...........
6. Now Close this Window and now u will be back to the Print Spooler Window now u can click on Start under the Print Spooler....
Now Try to Print Will Work Fine....................
Good Luck :)
Nov 09, 2012 | Lexmark E120 Laser Printer
I need Hp laser jet 6L gold driver for windows xp
you can install built in xp hp laserjet driver for hp laser 6l gold
Aug 08, 2011 | HP LaserJet 6L Printer
I can not print any documents from my laptop and when i try to look at my printer properties or any of the options it gives me when i right click my default printer it says printer spooler not running. how...
I'm assuming you're using Windows here.
In XP:
Click the Start button
Click Run
Type "services.msc" (without the quotes)
Click OK
In Vista/Windows 7:
Click the Windows Orb
Press Enter
In the resulting Services window scroll down to Print Spooler.
Right-click on the Print Spooler then click Start.
Mar 12, 2011 | Brother MFC-8480DN All-In-One Laser...
Printing doesnt take place
Check in the different port. Install the drivers properly and uninstall and reinstall the drivers from the Website and also need to check the print spooler services for that type services.msc in RUN. And start the Print spooler services while choosing the Automatic option.
Nov 19, 2009 | Samsung ML-1640 Monochrome Laser Printer
Not find print spooler in my service
Try going to start-->run and type cmd to get to command prompt
From there type:
net stop spooler
net start spooler
Close the window and see if it will install then
Jul 11, 2009 | Microsoft Windows XP Professional
Spooler services not runing, printer can not be uninstalled.
go to start>Run>type services.msc
then restart printer spooler service ...
Feb 14, 2009 | Canon LBP 1120 Laser Printer
Trying to install the HP Deskjet F2210 printer onto my Dell with windows XP everything loads except the printer spool. What do I do?
Restart the Print Spooler:
start-> run-> type services.msc-> scroll down to the print spooler service n hit start.
Verify that that the Print Spooler service, and all the services that it depends on, are correctly installed and running.
  • Open the Services Management Console (click Start, Run and enter services.msc).
  • Double-click the Print Spooler service to open its Properties window.
  • On the General tab, check that Startup type is Automatic.
  • Select the Dependencies tab.
  • Note all of the dependent services listed, then close the Print Spooler Properties window.
  • Repeat the above steps for the dependent services noted.
If any of the dependent services are missing or cannot be started, try uninstalling all installed printer drivers and then reinstalling them.
If this method cannot be completed or does not resolve the problem, try Method 2.
Method 2
Remove all Print Spooler service dependencies other than the Remote Procedure Call service.
  • Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print Spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 11, 2009 | HP PSC 2210 All-In-One InkJet Printer
Pentium4 computer
To start print spooler service, go to start > run > services.msc then press enter. scroll down the list to find print spooler, then right-click then click on start. You need to have it automatically start in the future, so you have to right-click > properties > startup type > change to automatic. Then try reinstalling your printer if necessary.
Sep 06, 2008 | Microsoft Windows XP Professional With...
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP LaserJet 6L Printer Logo
93 people viewed this question
Seeker5211
Seeker5211
