Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Frigidaire frontloading washer won't spin at all
The washer stopped draining and the final spin last night. I took it apart the drain hose and found a sock that was clogging it. Put everything back together and now the tub will not spin at all but it drains water. Last night it would at least wash the clothes it would just not go into the final spin, any suggestions would be greatly appreciated. my front load washer won't spin dry
  • 3 Answers
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Posted on Jul 28, 2008
2 Suggested Answers
SOURCE: washer won't spin
Where is the outlet filter?
Posted on Dec 18, 2007
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
My duet whirlpool stops at the rinse or spin cyle and gives error code F02. I cleaned out the drain pump strainer twice and got much out of it. It still errors. I took th epum completely apart last...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLTF2940FS...does not do a final spin/clothes wet
If water remains in the drum the unit will not go into the final spin.There may be a couple of reasons for your problem.
1.) A coin or other foreign object is blocking the drain hose. Check the drain hose for foreign objects impeding the exit of the water.
2.) The Drain hose is not raised above the machine outlet to create a siphon effect. See your manual for proper hose positioning.
3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch after the diaphragm of the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. I believe the pump is about $60.00 and is accessible after removing the front panel under the door.
Sep 10, 2009 | Frigidaire GLTF2940ES Front Load Washer
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
My Bosch 2060 Front end loader will not drain/spin
Get the pennies or dimes out of the accordian style black hose at the bottom of the washer. You will need to lay the washer against something so you can get in from underneath. Take a plyers and squeeze the medal clamp so the hose can slip off. I found 3 dimes that acted like washers. The machine will drain.
Jul 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore 41729042990 Front loading washing machine
you can take the pump apart by removing the 3 screws that hold it together. take it apart to make sure there nothing in it that could be blocking the impellar. if theres nothing in there, replace the pump
Nov 26, 2007 | Kenmore 44042 Front Load Washer
Washer won't spin
Maybe when you were behind the machine, you did not refit the outlet pipe at the correct height; this is a height approx. 3 feet from the ground or more. Your pump pumps the water OVER this height.
You said it does not spin; you shd check out your outlet filter and clean it. If this is clogged the machine will not spin. All the best!
Nov 06, 2007 | Frigidaire GLTF1040A Front Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
718 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
