Question about KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher
Over running The dishwasher cycle has been running longer than average, sometimes 3 hours. Is there an adjustment or something that needs to be replaced? I will be looking forward to your reply. Thank you
  • 163 Answers
If it continually washes there is a problem with the timer unit. The best choice is to replace the timer. MM85
Posted on Jul 27, 2008
My 17352 Kenmore dishwasher runs for an hour or more. Can this be adjusted?
There are wash, rinse, and dry cycles that all take time. Cycle settings allow you to vary this. For example, potscrubber mode will take longer than normal wash. You can opt for no heat drying to shorten the cycle, but then the dishes will be wet and can have possible spotting. Experiment with the controls and find the settings that give you the results you want in the least amount of time. But just FYI, an hour isn't that long for a dishwasher to cycle - many run longer than that.
Nov 03, 2016 | Kenmore Dishwashers
Bosch Dishwasher, SHU 5300 - Cycle stuck on 2H cycle
yes it needs a new control and its pretty easy to replace..
Dec 13, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Model FDB1100.......brand new Dishwasher stays in wash cycle for hour and a half........any suggestions??
Hello, Thank You for using FixYa. I will be helping you today.This is normal for new dishwashers to run this long. Heavy duty cycles with options selected can run well over two hours. Your machine is ok..This is our number one service call for new dishwashers. One hour to an hour and a half if average.
Thank You and please rate my answer if it was helpful..
Jun 20, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
The dishwasher continues on the wash cycle for hours, even when I choose the "light" wash cycle
Hello, Thank You for using FixYa. I will be helping you today.Normal cycles on new dishwashers is an average of two hours and opening the door makes it longer.Also if the water temp coming into the unit is not hot enough it takes even longer because now it has to heat the water.Yes new dishwashers can take a very long time to run a cycle.
Jun 16, 2011 | Whirlpool Dishwashers
I have model #FGBD243KF1, Gallery 24" stainless. The wash cycle is taking almost 2 hours. Should it take this long? Also, when switching cycles during the wash time the motor whines a bit. Is this...
these units are pre programmed they can wash that longer and sometimes up to two hours and fourty five minutes. there are alot of factors involved.your unit sounds like it is running normally. at this time
Mar 27, 2011 | Frigidaire Dishwashers
Our dishwasher takes about 3-4 hours to run a cycle. My brother has the same model and it takes about an hour. Is there an adjustment that we can make to correct this? Thanks, Karla
make sure that your filter in the bottom is clean and if you are using the automatic wash cycle, it will wash until the water is clean. Sometimes it will take an hour, sometimes it will take close to 2 depending upon the level of dirty dishes in the dishwasher. And don't rinse! They work better on dirty dishes.
Jan 05, 2011 | Bosch 24 in. SHX46A05UC Built-In...
It keeps on running for over an hour
The average dishwasher cycle is 2 hours. If it is equipped with turbidity sensors it could run longer.
Aug 21, 2009 | Kenmore Dishwashers
LG LDF6810ST Stainless Built In Dishwasher
It is very common that high eficiency, low water using dishwashers take longer to finish all cycles. The best way to "hurry" the washing is to make sure that the water heater is providing hot water of at least 120 degrees. But no hotter then 140 degrees.
If the dishwasher runs even longer, check to see is the dishwasher is actually connected to the cold water line. This dishwasher can be run from cold water but the water heating phase in the cycles will add much time ti the entire cycle.
This unit has a sensor that detects the detects the water clarity towards the end of the wash cycle. Rinsing the dishes may speed the load a little, but encourage not to go crazy on the rinsing because the dishwasher actually counts on the food particles to help clean the dishes.
Also, note that the final (third) blinking light means drying. You can simply open the door anytime after the final draining and power off the dishwasher, allowing the hot dishes to air dry.
Hope this helps. Please resply with your findings. Thanks!
Sep 16, 2008 | LG LDF6810ST Stainless Steel Built-in...
KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher Logo
241 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
