Question about Toshiba 55H70 55" Rear Projection Television
Way out on convergence/none at all
Also pulled pb3366-2 and pb3366-1 / can see the ic's on pb3366-2 have been replaced. one of the 1 amp fuses are blown.upon fuse replacement ,the picture flashes as a horizonal colapse,but not completely. I disconected the new fuse until I have an ideal what to do .the chips with the big heat sinks are cold.stk392-020's
  • 3130 Answers
SOURCE: Location of the STK392-110
The convergence IC's are large 2x3 inch(about) black in color IC's that stand up against a metal heatsink on the main printed circuit board. They will have white lettering on them that will plain as day when you see them. Make sure you replace these IC's with the manufacturers replacements and not some cheap copy, if the IC's cost less the 15 bucks a pop, they are cheap subs. Also do not forget the heatsink compound on the back of the new replacement IC's before you reinstall them. Good Luck
Posted on Mar 20, 2007
SOURCE: Tosiba TZ55V61 Convergence IC 150?s vs 110?s
STK392-150 can be replacement for 110's no other resister values need to be changed, however be sure bad resisters are replaced and check all the resisters (6) have been taken out of circuit and checked. also check for solder cracks and cold solder joints.
Posted on Dec 02, 2007
SOURCE: Convergence IC STK392-110 vs STK392-110T
If you are removing a defective chip, can you just cut the pins carefully with a wire cutter and later apply heat to pull them off?
Posted on Jan 29, 2008
  • 8617 Answers
SOURCE: 42H83 Convergence
Yes the convergence ICs need to be replaced, however so dont the six 1.8 ohm 1watt resistors as Toshiba recomends replacing those six resistors when the ICs are changed. You can get the 50H71 / 50H82 Convergence repair kit as the 42H83 is identical to the 50H71 series, so the kit will work for your model. Heres the link where you can get the kit.
Posted on Aug 10, 2008
  • 788 Answers
SOURCE: I am getting ready to replace the 2 STK392-110 IC
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try , they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
I am doing this for free.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
Posted on Jan 30, 2010
Convergence problem
Usually what happens is that the convergence IC goes bad or the fuse going to the convergence ic goes bad. Pico fuses they are called sometimes open up. You may want to open it up and pull the board out and check the solder connections on the convergence IC. Sometimes these get fractured or cold soldered and aren't making connection to the PC board.
Let me know if you feel comfortable with pulling TV chassis out or pulling the board that has the convergence IC on it out. Then you can resolder convergence IC OR replace it.First thing i would do is check to make sure there is between 22vdc and 25vdc on the fuse or the convergence IC. Let me know if this helps out any.... Sincerely HDTV GURU JAY
Mar 17, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
Double picture out of alignment
Your problem is its time to replace the convergence IC's. Replace both of them as if one has failed depending on which color is out of convergence the other is not far behind. They are the two large black IC's mounted on a large metal heatsink, also while replaceing them check the small yellow or green micro fuses underneath the IC's to make sure none of them have opened from the result of the IC failing.
Apr 30, 2010 | Sony KP-57WS500 57" Rear Projection...
Installed new 393-110 and still does not work
did you replace both of the 5 amp pico fuses F9A04 and F9A05? They will usually blow when the old IC fails
May 05, 2009 | Mitsubishi WS-65511 65" Rear Projection...
KP-51HW40 Convergence Problem
actually your model should only need two STK392-560 Convergence ICs and six 3.5 amp pico fuses. You can get the replacement ICs and pico fuses at the following link with free installation instructions. Heres the link.
Sep 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Samsung HCN4226 Convergence IC Problem.
The problem is likely to be the digital convergence board that generates the convergence signal that is amplified by the output ICs.
Jun 22, 2008 | Samsung HC-R4755W 47" HDTV
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
Sony Convergence
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
Can not convergence
Check for poor solder connections on both StK392-570 convergence Ics (Mitsubishi p/n # 267p150010) If there are none you may have to replace the amps - but that should restore normal convergence..
Dec 08, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Convergence problem
One or both of the convergence IC's are bad and has blown one or both of the fuses. Pull off the front speaker grill and remove the cover, loosen 2 brass scews holding the aluminum frame work, lift it up and out. Inspect The convergence IC's and the soldered connections to the board, check the fuses on the board. Replace both IC's and the fuses.
Nov 27, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Amps replaced...still getting 3D pix. The amps are not getting power. HELP!
Hi Brulia
There should be approximately 8 to 10 fuseable resistors around those convergence ics. They should stand out as they are a bright yellow colour. You should measure a short over them. If none of these are faulty I would leave the supply to the convergence alone and rather check the +5V / -5V and +12V supplies used by the convergence logic ICS. A common problem is the - 5V supply also used for your HT-protection cct op-amps. These ics goes short and pulls the supply to ground. There is no protection on these before mentioned supplies and therefore the set is still switching on but with a convergence problem.
Hope this helps.
Oct 31, 2007 | Sony KP-57WS500 57" Rear Projection...
sone tv's have fuses on the convergance ic's so if the ic fails the fuse goes also. the fuse or fuses can be near the ic, or can be located also in the power supply. I have seen that most times the fuse does not look like your normal fuse. they call them pico fuses. the look like small like resistors. i have seen them all white, all yellow, & all green. if you find them they are usually marke in amps, so replace with the same amp pico fuse. good luck
Jan 09, 2007 | Panasonic PT-51G44 51" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
