Question about Toshiba SD-4700 DVD Player
DVD display says no and TV screen says not allowed at this time
My DVD display says no and the screen says not allowed at this time
  • 2 more comments
  • Anonymous Jul 28, 2008
    Media Man,
    Nope, I have tried it with several different DVD's. Have other people had this problem??
  • dvddaddy Jul 28, 2008
    ccvvvvc
    Nope, I have tried it on several dvds, had anyone else had this problem???
  • Tomas MacDonnall Nov 10, 2008
    My TOSHIBA DVD player, Model SD-K760SU, worked for 18 months; then rejected ALL DVD's and CD's with a "NO" response. The cable is firmly in place but kinked 90 degrees in one location. Any suggestions? homefixer
  • 163 Answers
If this is after inserting a DVD you may have an unreadable disc or a region code conflict. Please explain a little more. Does it play ANY DVD? Probs on Just this DVD? MM85
Posted on Jul 27, 2008
  • John Byse
    John Byse Jul 28, 2008
    I had a similar problem on my Sony Burner. All I did was remove the covers and made sure the lens could "home" properly. Basically, gently moved it in and out on the track. Haven't had a problem since.
    MM85
How do I go from TV mode to the DVD screen with my remote
My TV remote has a 'TV/Video' button that when pressed, toggles the TV's screen back n' forth between watching TV or viewing your DVD/VHS. Pressing the button once displays a video-1 screen, twice, a video-2 screen, and third, back to watching TV programs (having two video option screens allows for another DVD or VHS player to be assessed, as long as the TV has another rear connection for a second unit). As long as the DVD player is plugged into the back of the TV, the TV's remote (not the DVD's remote) should accomplish the function.
Nov 11, 2016 | Televison & Video
Tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
My 9" Broksonic TV/DVD player
Will tries go into the tv screen menu again tries see if u can locate and functions like TEXT ON/OFF TEXT 1,2,3..Tries to off all that.The Close Captioning 1,2,3.. and TEXT 1,2,3..are same functions as TEXT 123 3..funsctions have a permanation of a big black box on the tv screen as Close Captioning functions writting without the big black box on the tv screen.
Aug 18, 2011 | Broksonic TV
There are marks on my LCD 42" TV ,its on the screen itself.It looks like water marks.It started of small marks and it then it getting bigger.
Things You'll Need:
  • Burn-In Reduction Screen Saver DVD
  • DVD Player
  1. Instructions
    • 1 Plug DVD player into your TV and power on. Make sure you plug the right component cables into their corresponding inputs on the back of the TV. This is usually done by simply matching the colors of ends of the cables with the colors of the input holes on the back of the TV.
    • 2 Turn TV to the proper input to display the DVD. Make sure there is not a DVD in the player.
    • 3 Place burn-in reduction screen saver DVD in the player. Allow a few seconds for the DVD to start playing. A pattern of white "video snow" will appear on your screen. The entire screen should be taken up with this patterm.
    • 4 Run the DVD for at least several hours; this will help wear the TVs phosphors evenly. Depending on how long the image has been burned into the screen, the amount of time you should play the DVD varies a lot. A good rule to follow would be to play the DVD at least four times the period the image has been displayed. If you have an image that has been on the screen two hours a day for a whole month, run the screen saver for at least 240 hours
Jan 17, 2011 | Televison & Video
Sony dvp-ns425 player has the word VIDEO in upper right corner appear and disappear every 20 seconds or so. It is in the same green block letters as all the menu/control titles so I know it is from the dvd...
That word Video in green color could be TV's on-screen display as DVP-NS425 has another kind of on-screen display that has track info, time info etc in display.
Please press Display on TV remote to turn off that green color Video on-screen display at top right corner.
Thanks.
Sep 13, 2009 | Sony DVP-NS425P DVD Player
My dvd player doesn't fill the screen on my Sharp
There are settings on most DVD players as well as TV's that allow you to adjust the type of display you want. Make sure both the DVD and TV are set to the same display type (usually either 16:9 for your type of TV). If that still does not fill the screen you will have to use the Zoom function on either your DVD or TV. This will cut off part of your movie, but should allow you to fill the screen. Most DVD movies will also allow you to choose widescreen or normal viewing from their menu. Again, you will lose a small part of either side of the movie, but at least you will fill your screen.
Jul 07, 2009 | Sharp Aquos LC37D44U 37 in. LCD HDTV
How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
May 06, 2009 | Televison & Video
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
shaun
Mar 06, 2017 | Zenith SY2569X TV
Which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
Oct 11, 2008 | HP Pavilion dv1000 Notebook
Durabrand DV 1002
on your remote there should be a display button push it and it should tell you how long into the movie you are
Feb 11, 2008 | Durabrand DVD-1002 DVD Player
Toshiba SD-4700 DVD Player Logo
97 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
