Samsung LCD LN52A750 picture too big
I have a Samsung LN52A750R1FXZA LCD flatscreen. The picture in the wide screen mode is too large for the screen. How do I shrink the top and bottom so that it fits the screen? I found where I can take the picture up and down, but I lose either the top or bottom depending on whicj way I go.
  • Anonymous Jan 12, 2009
    Picture is too big. When watching football games, the scores on top and bottom are cut off and can not be seen completely.
Coldcut
  • 1554 Answers
SOURCE: Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Posted on Mar 08, 2008
SOURCE: ilo lcd tv..picture too large??
I had the same problem and tried everything with the tv to get it back to normal. I would look for what was suggested by tvtek, but also look on your cable remote or box for an "aspect" button. That fixed my problem. If your problem occurs with DVDs as well then you may have another issue, but if it is with cable only, try this. When I called our cable company the tech said alot of people this button without even knowing it.
Posted on Mar 22, 2008
SOURCE: Picture is too big for screen
Go into the setup menu of the TV, and you'll find a category called DISPLAY or ZOOM. That's where you can change the aspect ratio so that it fits on the screen. You'll probably get a gray band on the top and bottom of the screen due to the re-sizing.
Posted on Dec 20, 2008
  • 15 Answers
SOURCE: Picture Is Too Big for Screen
Sounds like your cable box is zoomed in, I run into this a lot when running service calls. On most cable provider's remotes there is an 'aspect' button next to or around the '0'. Try that and see if it helps you out at all :)
Posted on Feb 24, 2010
SOURCE: Wide screen mode won't go back to "normal".
Was exactly what you said. The cable box settings were in wide mode. Couldn't figure it out at all. Funny thing was too.. on my cable box remote, the button under the #9 button is the # button.. it doesn't say zoom at all.. but it totally controls the zoom.
So thanks for that.. AND thanks for saying "under the #9 on the cable remote" instead of just saying .. the zoom button.
Thanks again!!!
Posted on Apr 06, 2010
Samsung ln52a750
there are several things that can cause this, is the screen blue? white? Colored lines?
May 05, 2013 | Samsung LN52A750 52" HDTV LCD TV
Sony bravia picture to large for screen
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
  • Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
  • 4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
  • Wide- Display wide screen 16:9 broadcast in the correct proportions.
  • Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
  • 14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
Sep 27, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
We recently bought a Samsung 500 Series 46" LCD
make sure you have the aspect ratio set at 16:9.
Mar 23, 2011 | Samsung Televison & Video
I have a LN46A550 flatscreen...the picture is now only in the upper left hand part of the screen. It's basically 1/6 of the screen. I have tried to pull up the PIP function on the remote and it will not...
there should be a ratio button on the remote if not its deffinitly in the main menu click on 16/9 wide screen you seem to have the veiw secound channel working on you set but were is the big picture of the current show? anyhow try that and let me know how you went
merry christmas
Dec 22, 2010 | Samsung LN46A550 LCD TV
Feb 24, 2010 | Samsung LN55B650 55 in. LCD HDTV
The picture is too big for the screen
sounds like your either in "cinema mode" or "zoom mode". does it do it on all inputs
Jul 06, 2009 | LG 37LG50 37 in. LCD HDTV
54" Sony Wega made a loud popping sound and now has Black lines
When I got my new LCD big screen, it had a black line across the entire width. It looked like the screen was pinched.
They claim that it can be repaired but that repair costs as much as a new tv.
My tv was replaced. Hopefully your warranty is still in place to get the unit replaced.
Mar 26, 2017 | Sony KDF-E50A10 50 in. LCD HDTV
The writing on the screen is stretched beyond the width of the screen and I lose script on either side - I have checked the fine tuner on the remote but it doesn't seem to have the ability to fix the...
if you have a wide flatscreen tv it could be that the picture size is in the wrong mode. under the mode button on your tv remote should be two buttons labeled wide and zoom. try pushing these buttons to adjust the tv screen size.
May 02, 2008 | Televison & Video
Picture Size problem with Samsung Flat panel LN-T3253H
You should contact Samsung service to know if the internal setup for the picture sizing was not adjusted properly at the factory.
Take care that some of these sets have a user zoom mode. Maybe it is in the zoom mode. Check in your instruction manual before calling for service support.
Jerry G.
Apr 12, 2008 | Samsung LN-T3253H 32 in. LCD Television
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
