Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Floormate Spinbrush The water comes out fine to clean but when I out it on the wet pickup setting, it piskc up in streaks and it has the most horrible sound while moving it around, like the rubber is going across the floor dry. Any solutions or anyone with similiar problems and a fix?
  • 24 Answers
Not sure if this will help but these machines are ment to be used in one direction not back and forth like a vacuum cleaner. You should start in one spot and pull towards you slowly with the trigger depressed it is designed to spray scrub and pick up the solution all in one pass by going back and forth you are pushing the rubber across dry parts of the floor and it will make noises. For any parts or cleaning solution you may need visit www.stevessewandvac.com
Posted on Aug 13, 2008
Hoover floormate h3000 w/spinbrush will not dispense the cleaning solution how can i fix
The hot glue trick will work; but what you probably need to do is gently push down on the black pin from inside the tank. This will lower the solution release mechanism and the solution will dispense. I found this solution on this website and it took 10 seconds and worked well.
Mar 31, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate does not disperse wet cleaning solution on the floor. brushes and vacuum pickup all work
First check to see that the wheel assembly is not broken. The assembly must move correctly to allow the fluid to be dispensed. Check for breakage at the rear of the wheel assembly where it attaches to the base. If this is not the problem, you may have a defective soap tank.
Jan 22, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate will not **** dirty water.
Check the hose coming out of the floor assembly. It tends to split, keeping it from picking up the water
Apr 20, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Wet pickup has no suction. Dirty water stays on floor. I tipped it over and held a tissue in front of the wheels to see if the Floormate had any suction whatsoever; it does not. What now?
Okay, I too had the same problem with the water. I read that darn manual again and realized that I hadn't clicked the filter cover on tight. Wallla! The tank fits better and it works like a charm! Who knew?
Nov 30, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
DOES NOT VACUUM NOW
Several possible problems:
1) Did you clean the blue lower pickup container (dirty water) before putting it away?
Take out the pickup container and open it up, check the filter (under the little blue piece on top) and also open up the container itself and clean under the flapper on the "screen".
2) Look inside the housing and check the vac hose that goes from the front of the unit up to the rubber grommet where it goes into the lower pickup container. Is it clogged? If yes, take off the front pickup (the part the runs along the floor in front of the rotating brushes) and run a very narrow lint pickup brush (like for cleaning dryer vents) and clean out the hose. It works great.
3) Check the front pickup for clogs and clean
4) If you are trying to pick up water, make sure the setting is set to wet. If you are trying to use it as a vacuum, set it to dry.
Hope this helps.
Nov 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate won't dispense clean solution
The tank sits on what is called a reservior asm, that may have gone bad. Does the water flow out of the tank when you push in the valve at the bottom?
May 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate
The tank sits on what is called the reservior asm. it is actuated by the control rod inside the handle. With the tank off, watch and see if you can see that rod hitting the reservior asm when you squeeze the trigger. If it is moving up and down on it, then the resorvior asm may be bad. Also check the valve at the bottom of the tank, manually push it in and see if it releases water.
Feb 18, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate plus model #H3010
It seems to be a common problem with this series of floormate... some home quickfixes (a hassle, i kno) but put downward pressure while using the solution.... Check your warranty that came with it, and how long you purchased the floormate... Alot of vaccuums come with 30-90 warranties, I'd recommend having it checked out. That, or if u bought it recent enough,take it back... like i said, these models are unfortunately known to have this problem... Some people have ones that operate normally, but alot do not. >.<
Jan 09, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover floormate
Dec 15, 2007 | Hoover H3030 FloorMate SpinScrub 500...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
124 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
