Question about RCA 27R411T 27" TV
RCA --- two year old set.
Hoirizontal black and white lines which move vertically. get a picture but after some time picture becomes black and white. and changing channels will often create the black and white scenario. now I have lost sound on some but not all channels. my question is if it is worthwhile to repair because other wise picture is fine.
Re-solder the tuner ground plane. Open up the tuner and solder the egdes where the pcb meets the metal enclosure. Make sure to re-solder all of the points of contact between the enclosure and the pcb.
Posted on Jun 01, 2009
    Problem Solver:
Chris suggested I buy a new set rather than spend bucks on repairs and parts.
Posted on Jul 29, 2008
Two inch horizonal (black and white) line move from botton of screen slowly up the screen. Each line is about 24 inches apart. Also at times the picture will become dark with muted our of focus images. ...
The best way to determine what is at fault is to disconnect the Denon tuner and run the signal straight to the TV. If the problem goes away, the Denon is at fault.
May 17, 2011 | Hitachi 51F500 51" Rear Projection...
I am repairing my sister TV {Toshiba TN61X81}. The original was no picture and with sound. Upon troubleshooting the vertical deflection, ihad move the screen control for all 3 crts to see the horinzontal...
The easiest way I have found to set the screen controls is to tune into an old black and white show, turn the green up until you see retrace then slowly turn it down until it just dissapears then adjust the blue and red for a true black and white picture.
Sep 08, 2009 | Toshiba TN61X81 61" Rear Projection...
Picture has white horizonal line accross it
You have a vertical collapse. Not sure if its worth fixing because i don't know what type of set it is or how old. But vertical is not usually expensive to fix. Possibly just replace vertical ic
Apr 22, 2009 | Televison & Video
Toshiba 61H70
Does it look like a 3D image?
Would you be able to post a picture of the TV with the mention lines?
Aug 16, 2008 | Toshiba 61H70 61" Rear Projection...
WHITE LINES
Hi kmb0516.
Depends how old the set is, if it is more than 5 years old, time to tell it goodbye, if it is less, might be worth fixing.
I believe the problem is in the vertical output section, it sounds like the picture has shrunk.
Hope this helps, Greg.
Aug 13, 2008 | Sylvania SRT2232S 32" TV
JVC TV - BLACK HORIZONAL LINE ACROSS THE TOP OF TV
The vertical circuit is not pulling the top of the picture to the top of the screen (CRT) correctly. Its possible you have a loose wire or device ( after moving ) . If you have vertical agustments on the back , you may be able to adjust the picture taller; if the picture becomes stretched ( non - linear ) then you definately have tv tech only problems. At that point I'd really think twice about a repair and consider a new DTV or HDTV set. If the unit was damaged by a mover , then you may have a claim against them .
Apr 30, 2008 | JVC AV-27D305 27" TV
Vertical black lines rear projection
Please provide exact model from back of tv........
Possible vertical IC circuit problem===bad caps? IC?
...........T.
Nov 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
Horizontal line in my TV.
"Guest" obviously has no idea what he is talking about. There is no such thing as "frame section" and if the vertical IC, ramp generator or vertical hold circuits were bad, you would have no vertical at all. If you mean that there are thin white lines at the top 3 inches of the picture, and the top of the picture seems folded back on itself, it means that the pump-up capacitor is going bad in the vertical output circuit. This is a very easy thing to correct but should be done by a qualified tech.
Sep 01, 2007 | Televison & Video
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
Picture went black
The good thing is you see something in the screen,with age the set has developed loose conections in a few different places,my suggesion is to call professional for service now and the repair will not as expensive,if the picture quality is good is worth it.
Sep 22, 2006 | Sony KV-32V26 32" TV
RCA 27R411T 27" TV Logo
108 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
