Question about Gateway Computers & Internet
Not able to get internet connection. I have 2 other computers in the House works fine. I have contacted my internet provider our IP is 169 I have manualy put in the system shows internet connection but still not able to get on the internet the error message is Internet explore cannot displat the web page.I have an emaching T3958. 340 omte; ce;erpm processor
    Problem Solver:
  • 9 Answers
Try changing your settings on your internet protocol to obtain an IP address automatically and obtain DNS server automatically.
Posted on Jul 28, 2008
MA073LL/A wifi but no internet
Thanks Habour castl for letting us and future people having a similar problem know that the firewall settings was the cause of the internet not working through your router.
May 17, 2017 | Apple AirPort Extreme Base (MA073LL/A)...
My wireless internet works in my hometown, but I go to college 2 hours away and plugged my Ethernet cord in. Everything says its connected, but the internet page will not load. I tried 2 of my friend's...
dont uninstall / reinstall anything on that laptop, will cause more trouble since it was working fine hours ago.
first check your ethernet properties
Aug 30, 2008 | Computers & Internet
Tip
Resolving 169.x.x.x IP address problems
This article outlines methods of resolving issues with a 169.x.x.x IP address. This address results from a built in feature of windows called automatic private IP address(APIPA). When your computer is unable to find a DHCP server the APIPA service will assign itself a 169.x.x.x IP address. According to Microsoft, the APIPA service checks for a DHCP server every five minutes.
Releasing the IP address
1. Click on Start and click Run.
2. Inside Run, type ipconfig /release to release the IP address.
3. Then after the IP address is released, type ipconfig /renew
Disabling the Ethernet Adapter
1. Click on Start and right click on My Computer. Then click on Manage.
2. Click on Device Manager and then Network Adapters
3. Under Network Adapters, right click on your Ethernet adapter and select Disable.
4. Wait approximately 5 seconds and right click on it and click Re-enable.
5. This restarts the DHCP client and tries to obtain an IP address from the Network.
Check the Ethernet cable
Sometimes a bad Ethernet cable can cause your system to receive a 169 IP address, try changing out the cable for a new one.
Disable antivirus and firewall applications
Disable/uninstall any external firewall, antivirus, or spyware programs (eg. Norton Internet Security, McAfee Security Center, Trend Micro 2007, Webroot).
Restarting the QoS packet scheduler Protocol
1. Click on Start and click Control Panel.
2. In Control Panel, double click on Network Connections and then Local Area Connection.
3. Click on Properties and uncheck QoS Packet Scheduler.
4. Click Ok and repeat the process.
Restarting the DHCP service
1. Click Start and select Run.
2. Type services.msc in Run and click Ok.
3. Find DHCP service and right click on it. Click on Stop.
4. Reboot the computer.
5. When the computer boots up, click Start and select Run
6. Inside Run, type the following: netsh int ip reset log.txt
7. Click Ok.
System Restore
1. Open Start and click on Programs and then Accessories.
2. Then click on System Tools.
3. Click on System Restore and select a restore point when you were not experiencing this problem.
4. Restore your system.
on Jun 14, 2010 | Computers & Internet
Cannot connect to the internet on the Toshiba Netbook. Has very strong network signal.
Troubleshoot the issue by identifying the ip address that your computer has. May it be wireless or local area connection. Check IP Address thru command prompt or DOS.
· press <windows key>+<R>
· type "cmd"
· press ok button. a black box will appear
· type "ipconfig /all" then press enter key
· locate wireless connection and local area connection group by scrolling up/down.
NOTE: ignore highlighted physical address.
If the ip address is 169.xxx.xxx.xxx, this is an invalid ip address. Contact Internet Service Provider. If the ip address is 192.xxx.xxx.xxx, click start and open control panel. then open internet options. click on connections tab. click on lan settings. Make sure no tick box checked. All set your anti virus' firewall settings to default. Then try browsing.
I hope this works for you. KINDLY REPLY IF FURTHER ASSISTANCE NEEDED. Good Luck!
Mongkey
"Understanding explains better..."
Jan 27, 2011 | Computers & Internet
Hello, my computer has an 169 ip address, i've tried to renew the ip it wont renew it, but other computer works fine on the same router, any suggestions how can i get rid of that 169 ip address? thanks
First make sure your network connection is plugged in and working (i.e. look where the cable goes into your computer and has a green light on near it). 169's a re the windows default when no connection is available.
Then, if the cable (or wireless connection?) is OK, click on start > control panel> Netwok and internet connections>
Click on your Lan (ow WLAN?) connection and hit properties.
Navigate down to the 4th (or 5th depending) in the top box to TCP/IP and highlight it, hit properties, and select "automatically configure" for both the IP adress and DNS Servers, hit Apply, then OK, wait a few seconds and you should be good (assuming it's not actually your router handing out the "169" adress.
If all is not well, try a different network cable or port on your router, or get back with more detail.
Dec 28, 2009 | Microsoft Windows XP Professional With...
Have already described this probelm four times and paid for premium assistance. Hello????
if you have problem sir/mam just contact me. Reggie is your best contact solution to your problems.. Thanks
Mar 27, 2008 | Computers & Internet
Internet hookup
This is not the manufacturer's site, but i will try to help.
Is it your own network?
You need to make sure that the network is not protected, or you'll need the password.
Go to Start>Control Panel on your computer
Then go to Network Connections
There should be an icon for your wireless connection.
Right-click -> select Properties
In the selectbox select 'Internet Protocol (TCP/IP)'
Click Properties
Check if 'Obtain an IP-address automatically' and 'Obtain DNS-server' are selected
If they were not, Press <Ok> two times and try to connect to the wireless network again.
Can you also tell what IP-address you get?
Find it by going to Start > Run
Type 'cmd' without the quotation marks and press <Ok>
you get a black command box
type 'ipconfig', again without the quotation marks and press <Enter>
Please tell me the IP-address it tells you...
Mar 27, 2008 | Averatec 3200 Notebook
Trying to hook up lap top to wireless internet. Comcast tech says there is problem with IP# 169 which preceeds other numbers and needs to be removed for hookup. How can I accomplish this? Model #3150H
Usually you will have an IP address starting with 169 if the adapter cannot get an ip address from anywhere, it is an autmoatic IP address.
What operating system (Windows XP or 2000 or Vista) are you using?
I.P Adress
your ip is provided by your ISP (internet service provider), if you have two accounts (two modems) then you probably have two ip numbers and if you use one account, even you have ten computers connected to the same modem, will be the same ip but shared.
hope it helps.
Dec 08, 2007 | Computers & Internet
Computers & Internet Logo
59 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
