Linksys Wireless-G Range Expander WRE54G does not work
I sent the wrong Linksys...this is the one that is broken. Can I call Linksys about this model.
Thank you I appreciate your input...
  • 1 more comment
  • JetfireK Jul 27, 2008
    The blue light does not light. The Linksys Wireless-G Range Expander WRE54G has no response and looks the same plugged or unplugged. NOTHING....
  • catgirlbjh Sep 13, 2008
    Range Expander lights went out and will not come back on.
  • milton191 Apr 10, 2009
    will not turn on no red & no blueLynsys wireless wireless-g range rxpades will no rest
  • 928 Answers
Yes you can call Linksys about it if it is under warranty. Warranty is 3 years. Most likely just a configuration problem. Just give Linksys a call and they should be able to get you up and running
Posted on Jul 28, 2008
What range expander should I use with a Linksys Dual Band Wireless-N Router Model WRT 320N?
For this router you can use the Linksys range expander model WRE54G v3 take not of the version number that is important since the older range expander don;t work on all routers.
Feb 13, 2011 | Linksys WRT320N Wireless Kit
Hi, I just got Linksys WRE54G V.3 and was trying to install the CD. But I keep getting "Site Survey fail" message. My house is using a router made by Apple, and does not have extra space to...
The range expander helps to extend the range of wireless network...
Anyhow the range expander has to be placed withing the range of your Apple "wireless" router (Make sure your apple router is wireless router, if it is a wired router, then there is no use of range expander...! U need to buy an Access Point instead)...
your range expander must be connected to the computer(using an ethernet cable) from which you are trying to configure...
Site survey searches for the available wireless networks in range...
It should show your existing wireless network...
You need to select your appropriate network and you need to configure the Range expander wireless settings according to the Apple router's wireless settings...
exactly the same SSID(Network name), Security type and encryption technique, password PSK (security key) has to be selected on your range expander as in the APPLE wireless router...
Thats it...
You are done...
Your wireless network range would have extended now....
Dec 09, 2010 | Linksys Wireless-G Range Expander (WRE54G)
Linksys range expander?
you can find the ip address of you ranfe at the back of your wireless router
Mar 03, 2010 | Linksys Wireless-G Range Expander (WRE54G)
Link light on (blue), activity light off (neither blue nor red)
Press the RESET button on the back of the unit and reconfigure the settings.
Sep 11, 2009 | Linksys Wireless-G Range Expander (WRE54G)
Linksys WRE54G WIRELESS 802.11G RANGE EXPANDER Range
The actual max distance of the range expander is about 50 feet, and sorry to say but it cannot bounce the wireless signal from it on a wall....
Jan 25, 2009 | Linksys Wireless-G Range Expander (WRE54G)
Wireless g range extender
Hi there ....
before anything else, can you please what is the version of range expander is is wre54g v1,v2,v3?
1) either which, please do verify your wireless settings of your DLINK router
-- the network name or ssid
-- security if you enabled any on your router
-- wireless channel
-- please check the default gateway of your router if it is 192.168.1.1
** please take note also that the best location for your expander would be inbetween your router and your computers
2) once you have gathered the wireless settings
-- you would need to manually configure your expander coz it didnt work .. Please remember that the LINKsys expander is designed to work with linksys routers, so it may or may not work.. I just need to set your expectations on this ...
3) once you have verfied the default gateway of your DLink router ... please reply to this thread and let us proceed in configuring your wre...
Thanks and good luck!
Oct 31, 2008 | Linksys : WRE54G Wireless Range Extender...
I just bought a Wireless G Range Expander and when I try to set it up, I continually get the "Site Survey Failed". What am I doing wrong?
I believe your using a WRE54G, but which version? The latest version has ethernet port so you can connect it directly to a pc to set it up.
Try to access the expander's set up page by typing its address of 192.168.1.240 and you will be able to configure it from there.
Jun 25, 2008 | Linksys Wireless-G Range Expander (WRE54G)
No Power
Before you plug it in the wall, insert the installation disc and go through their tutorial. When you do that you'll plug in your range expander, press the auto configuration button on the side and wait for both lights to turn up blue. Then you can unplug the range expander and put it else where.
Aug 08, 2007 | Linksys Wireless-G Range Expander (WRE54G)
Computers & Internet Logo
1,666 people viewed this question
David Payne
David Payne
