Question about Canon EOS Rebel GII with 35-80 lens 35mm Film Camera
Not able to take photos
Having a problem with my camera and not sure why. added new batteries and it still will not work
  • Robert Kilbourn
    Robert Kilbourn May 11, 2010
    What is the camera doing? Does it turn on at all? Does it focus? I'd be glad to help if you could give me a little more info!
    CameraRepairs
Working fine and now i can't take pictures with my Canon Rebel GII it won't do anything.
Posted on Sep 23, 2008
How do i stop my moultrie camera from taking multiple photos per minute? I have 2 and they both take 3 pics every minute of every day.
not sure if you formatted on computer or camera, you should always format on camera, also delete pics on camera, after you copy them to laptop.
Sep 11, 2014 | Moultrie MFHDGSD50 Game Spy Camera D50
Little power
What d you mean with batteries are added?
When you use batteries, always make sure all four are from the same brand, quality, capacity and if possible, from the same batch. Never use different batteries in one camera.
lways charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some (most) cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera.
Always be sure the battery is charged and suited for your camera.
Check contacts of the battery and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the battery before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Jan 22, 2014 | Fuji FinePix S8000fd Digital Camera
Picture display freezes and can't none of features work
PLEASE see the test and fix it. God bless you
1. Camera won't record photos. Make sure you've selected a photography mode with your camera, rather than a playback mode or a video mode. If your camera's battery power is low, the camera might not be able to record photos.
Additionally, if your camera's internal memory area or your Memory card is full, the camera won't record any more photos.
With some cameras, the internal software only allows a certain number of photos to be recorded on a single memory card because of how the software numbers each photo. Once the camera hits its limit, it won't save any more photos. (This problem is more likely to occur when an older camera is paired with a new, large memory card.)
The battery is the root of most common digital camera issues. Though battery life has been extended as battery and digital camera technologies evolve, no battery lasts forever. When your batteries begin to run out, sometimes your camera responds in wacky ways that may not seem connected. The flash may not come on, the autofocus won't engage as quickly as it did before or the LCD screen will power off intermittently. All of your camera's responsiveness is linked to its battery strength. Change batteries and try to recreate a problem; odds are you won't be able to. It's a good idea to carry a backup battery for cameras that use lithium-ion cells or a pack of spares for cameras that use AA. Watch your battery icon for a general idea of
Nov 09, 2013 | Nikon COOLPIX S9300
I have a Sanyo digital camera but the batteries only last about 15 photos and then I get the battery low message or it switches off. If I take the batteries out and insert them again and get another 4/5...
My best guess is that you need new batteries. Even rechargeable batteries need to be replaced sometimes. I am pretty sure if you purchase new batteries for this, you will be just fine!
Hope this helps!
Jul 26, 2011 | Sanyo S870 Digital Camera
Olympus C-765 - won't take photos anymore. Memory card is fine and camera has worked perfectly for the past two years. Does anybody have a solution? The camera seems to function as normal, but when I press...
Reset the menus to default or factory settings.
Then test the camera again.
Make sure that the battery is fully charged or new.
You might consider to buy a new battery (Ebay is a good place) for this camera. Then test.
Problems like this can show up when the battery is weak or not fully charged.
You may try to remove the battery for 24 hours and then after try it again.
Apr 15, 2010 | Olympus Camedia C-765 Digital Camera
My camera won't turn on either....
Either the lens is out of alignment, or the CCD or worse has gone defective. Either way it sounds like it may be worth it to just purchase a new camera. You do always have the option of repair as well.
Thanks,
Lee
Jul 11, 2009 | Vivitar ViviCam 3935 Digital Camera
Cannot see anything on the screen
Ensure that settings are OK, and check if the curtain is opening.
If everything else is OK, then all black picture means that lens assembly, wiring to CCD sensor, or main digital board is faulty. More likely one of the first two.
The fault must be fixed at a repair shop.
Regards
Jul 02, 2009 | Canon PowerShot A470 Digital Camera
Even with new batteries and they go dead before I take 3 pictures
Yes, there is definitely a fault with your camera.  You should be able to return it for a replacement.  I wouldn't experiment too much with batteries in this camera. batteries discharging this quickly are likely to overheat, causing unmentionable catastrophe.
Dec 11, 2008 | HP Photosmart M547 Digital Camera
CAMARA turns off when i press to take a photo
I have the same camera... and it was doing the same thing AFTER i changed my old batteries, because they were getting low. It was only after i put in the NEW batteries that i had this problem... I tried putting the old batteries back in and sure enough it worked again, so it probably all just depends on the brand of the battery you use.
Oct 09, 2007 | Fuji FinePix A500 Digital Camera
Canon EOS Rebel GII with 35-80 lens 35mm Film Camera Logo
87 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
