Question about Timex Expedition 84601 Wristwatch
No sound replaced battery. LCD works fine, reset watch. Turned on beep but watch is silent. No beep. Is there anything I can do to restore the sound for the alarms? Thanks
  • skippermun Aug 05, 2008
    THANK-YOU, THANK-YOU, THANK-YOU.
    The beep is back. I didn't realize how much I used it till it was gone. Thank-you so much.
    Skippermun
This solution worked for me but I also had to bend the little copper tab upward so that it made good contact with the plastic pad stuck to the inside of the back of the watch
Posted on Nov 26, 2008
I have a similar Expedition watch, and I had the same problem today. I found that the watch back was installed 180-degrees off. I rotated the back 180-degrees and the beep is back now. (The piezo-whatever beeper is located in the watch back, and the little copper "tab" needs to touch it for the beeper to work).
Posted on Aug 05, 2008
Beeps all the time and the screen keeps on blinking. i cannot reset it. i tried presing all the buttons but it doesnt work.
I had the exact same problem with my watch, it wouldn't stop beeping or flashing and the reset would not work. I fixed the problem an hour ago by replacing the battery in the watch.
hope this helps!!
Mar 27, 2011 | Nooka Unisex ZUB Polyurethane Watch...
I have turned my sound off on my watch and the alarm sound but when I am working out my watch beeps at every heart rate, its annoying I know there is a way to have no sound, I had it that way before but...
Assuming that your limits are set correctly, this is a job for a Polar Authorized service center.
There is most likely a problem with the computer, depending on the age of the watch this will be taken care of under warranty. The link above explains the process.
If you replaced the battery yourself (never recommended) some contaminant could have gotten into the electronics, or the seal is no longer working allowing moisture into the unit. These are highly sensitive electronics and should only be handled through the service centers. The work they do is covered with a warranty and they replace seals and vaccuum pressure the watch to make water tight again, as well as run a diagnostic on the computer.
In the mean time if you don't want to send in you can set the Heart Rate limits - both low and high well above your actual limits and that will stop the beeping, as the beeping while you are working out is an out of limit/ zone alarm.
Nov 19, 2010 | Polar F6 Watch for Women
Lost the beep on my timex watch alarm
Try taking the back off and orientating it the other way (i.e. turn top for bottom). You don't have to screw it down to see if this will work. As soon as the back clicks in you will be able to hear beeps as you press the buttons
Mar 18, 2010 | Timex Expedition C45981 watch
No alarm, chime, or beep battery is hew, all displays are working, just no sound.
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 22, 2010 | Timex T5E231 Ironman Triathlon 100 Lap...
Help with battery problem on Timex Ironman Data Link Wrist Watch and after installing a new battery the alarm is silent.
Help with battery problem on Timex Ironman Triathlon after installing a new battery and reset, displays the message 846010 1.0 P1and the alarm is silent.
Jul 08, 2009 | Timex Ironman Triathlon 50 Lap Digital...
Replaced battery in lorus digital watch, now the alarm won't work
The alarm spring proabably was lost. If it was, it will not alarm again.
Jul 01, 2009 | Timex Advanced Data Link 53722 Wrist Watch
My diesel watch gets reset everyday dz-7044110703
I have the exact same problem. The watch was working fine up until I had the battery replaced. I went to another watch repair shop (couldn't go to the same one as I had moved to another town) and the chap there explained that with Diesel watches, when the batteries are replaced a small button inside the mechanism must be pressed to reset the settings, if this isn't done then the annoying problem, inflicting our watches, will occur.
My watch worked fine after, for a few days, then it began to reset again; casting doubt on the watch repair man's explanation. I'll go back to see the chap when I have the time, prob next week and keep you chaps posted on anything new.
Feb 22, 2009 | Diesel DZ7044 Watch
Timex IndiGlo Ironman Triathlon - bell stopped working
You have lost the coilspring wich connects the watch mechanics with the speaker integrated in watch caseback. This is why you do not hear any sound but still can see the icon.
Check the area where you made the battery replacement very carefully- you may find that tiny spring. Use the magnet if necessary.
If you can not find it, go to the nearest watchmakers shop and ask to supply the new coilspring.
Do not forget to rate, please.
Feb 02, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
Alarm Malfunction.
remove the band and the back of the watch, rotate the back 180 degrees and replace. The alarm should sound again.
Dec 10, 2008 | Timex Sports Ironman Triathlon 100-Lap...
Resetting sound
Could the jeweler have inadvertently damaged the beeper in the watch when he changed the battery? I'd tell hime the problem, ask him to restore the sound and see what he says ("oops" is a bad sign).
Lenny
Feb 15, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Timex Expedition 84601 Wristwatch Logo
480 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
David Ellis Rhea
Are you a Timex Watch Expert? Answer questions, earn points and help others
