Question about HP Office Equipment & Supplies
I have a HP Officejet J5750 All-in-One printer and I forgot how to replace and install new ink cartridge. Please let me know how to replace new ink cartridge. Thanks
    Genius:
  • 1,056 Answers
Have a Costco refill (74XL) for my J5750, that was working fine. got "cartridge on right needs replacing" message. took it to Costco and told the cartridge is almost 75% full. Is there a way to reset/
It could be possibly defective cartridge or it is not filled correctly, try replacing the cartridge and if that does not work, it could possibly be defective printer and you may have to recycle it.
Jan 09, 2015 | HP OfficeJet Office Equipment & Supplies
Hp officejet j5750
go to the HP website, pick products enter model number/tag and see if you can order new CD software or download an image on cd/dvd on another pc(if your pc is not working)
if this is a printer not a pc, do the same thing but download the software from the HP site to your pc to install it from online
not sure what hp officejet is
Nov 22, 2013 | Dell Computers & Internet
How do I install my ink cartridge for a hp officejet 4215 all in one
Turn on the HP printer. Lift the printer cartridge door, which is the right side of the printer, revealing the black and color ink cartridges. Push down on the front of the cartridge you need to replace and pull it out slowly. Unwrap the new ink cartridge and peel off the tape. Insert it at an angle into the cartridge slot. Apply gentle pressure until it clicks into place. Close the cartridge door and press "OK" when prompted.
References:
HP User Manuals: HP Officejet 4215
Hope this helps you :)
Mar 07, 2012 | HP OfficeJet 4215 All-In-One InkJet...
Used refilled cartridges in HP All-in-One J5750. Even w/ a new, HP cartridge, it errors out too: "Cartridge on left (color) must be replaced." Now the printer doesn't work w/ any cartridges - new or...
Try cleaning with a wet towel the contacts in your printer
probably have ink on contacts and nan not read your cartridges
it is the metal pins ,the point that cartridges are getting in
Nov 02, 2009 | HP Officejet J5780 All-In-One InkJet...
Says that I need ink even though I just replaced it
Replace all the ink cartridges??????? If this is HP's idea of how to sell more ink my printer will be floating down the Ohio River very shortly.
May 21, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Missing printed lines form HP Officejet J5750 All in One printer
The cartridges may need to be cleaned by the printer. Check for this option on your user's manual, they will usually refer to it as a nozzle check/clean.
If the cartridge is clogged and does not unclog replace the ink cartridge. Contrary to what people might think these cartridges have a shell life and can be faulty out of the box.
Nov 17, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
65 people viewed this question
Ben Johnson
