Question about Toshiba 32A33 32" TV
Television I have a Toshiba television that when turned on there is nothing but a thin straight bar. I hope there is someone out there that can help me out. Many thanks for your attention. Kenny At : arch3ken @aol.com
  • arch3ken Jul 27, 2008
    Much appreciated advice. I will replace the tv and hope for the best. Many thanks
    Master:
  • 726 Answers
Yes i can help you a thin straight bar means you blew it ,the tubes inside with all the colors have gone its cheaper to by a new tv then to fix
Posted on Jul 27, 2008
  • chris07551 Jul 27, 2008
    ok thank you
There is a vertical black bar along the left side of my TV. It started as a thin yellow/white bar and has grown to be about 2 or 3 inches wide, blocking that portion of the screen.
The LCD wafer has gone bad, and more lines will begin to appear over time. It can be replaced but the cost may be comparable to replacing the entire television.
May 22, 2015 | Televison & Video
Got a toshiba ct-90042 tv and someones put the timer on and now i cant even get the tv to turn on so i can take it off
try disconnect the tv from the outlet power and reconnect that suppose to reset the clock and
by the way timer to
hope that will help you
Mar 17, 2010 | Toshiba 50H82 50" Rear Projection...
Replaced lamp on my toshiba 50hm66 and still wont turn on
hello i'm not sure if i'm right but when you install these lamps you rght have reset the lamp counter
shaun
Mar 21, 2009 | Toshiba 50HM66 52" Television
Black, Red and yellow triangle in upper right corner of the scrn.
YOU HAVE A CONVERGENCE PROBLEM IC'S WILL NEED TO BE REPLACED. THE FACT THAT THE LINES DID NOT MOVE WHEN YOU TRIED TO ADJUST THEM CONFIRMS IT.
Jan 19, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 27df46
i have the exact same problem. i used to be able to turn it on and off but that does not work any more. hope someone has an answer for this.
Aug 18, 2008 | Toshiba 27DF46 27" TV
JVC AV-27870 TV Image Problem
Hi Bruce,
Sounds like you have shorted or open Vertical Filter Capacitors. ( you may also have a bad vertical drive chip now since you've waited to replace the capacitors). You'll need to replace the bad capacitor/s and if the problem doesn't go away, replace the chip also. And as always, check for any cold solder joints ( bad lead connections to the printed circuit board ) as you replace the bad components.
I Hope this has helped.
Ed
NC Electronics
Mills, Wyoming
Have a Great Presidents Day
Feb 17, 2008 | Televison & Video
Toshiba 27"
Short answer, nope, very reasonable and quick repair.
To be a bit more specific, chances are that the vertical output IC is dead. It's a relatively easy job and even someone with basic electronics knowhow and a little soldering should be able to do it. In some instances, it just might be a case of cold solder.
If your concern has not been corrected after completion of the above procedures, you may need to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 15, 2008 | Toshiba 27A33 27" TV
Toshiba Television
it could be a loose or bad solder joint
Oct 31, 2007 | Televison & Video
Toshiba 32A33 32" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
