Question about EliteGroup PT800CE-A Motherboard
Restart problem I have a ASUS G1 and whenever i restart or turn on it resets everything I changed back. How do I keep the changes I've made?
  • 781 Answers
Do you mean BIOS changes if you change anything inBIOS when you come out from it you should be asked do you want to save changes sometimes on the popup you have to enterthe letter Y and enter or it could come up with a box with yes or no in it you must highlight the yes tab
Posted on Jul 27, 2008
  • 928 Answers
I would assume you mean the CMOS. Try to check if the reset jumper is set. Check the board manual for the right jumper setting for it. Also Try changing the CMOS better as this is the one storing the information. You can purchase a batter from any electrical or hardware supply.
My g1x zoom pedal turns on but no sound will come out ? HELLLP ASAP.
did you check the instrument cables? could be one or more of them is shorting
Oct 19, 2012 | Zoom G1x Guitar Multi Effects Pedal with...
Asus A53SV-XE1 bios password reset
Have you try to reset asus password in safe mode?
The steps as following:
Step1: You should restart your computer, andkeep pressing asus/F8/F2 to enter the Safe mode.
Step2: After enter the safe mode, you can see the default administratoraccount, just click it to enter the system.
Step3: Open User Account in control panel, pick the account you have forgottenthe password to change the password.
Step4: Restart the computer, you will log on with the newly created password orwithout password
If the above method can not help you, you can google search for Smartkey Window Password Reocvery to reset windows password.
Hope it help you well.
May 08, 2012 | ASUS A53SVXE1 Versatile Entertainment...
Need to reset a VeriFone 3750 v501 to its original default state. The program password has been changed and I cannot access to update
Turn off and unplug the Verifone 3750. Wait for five seconds or so and then plug it back in. This will automatically reset the Verifone 3750 and it will reboot and restart.
Reset the shift. Resetting the shift is another reset option available for Omni. Press "Shift," then "#," followed by "1" to reset and change the shift.
Press "Shift," then "#," then "2" to stop a change and keep the shift on the current settings.
Below is your user/install manuals, it's all in there so download each copy for any time later.
www.verifone.com/PDF/guides/omni3700_installguide.pdf
https://www.shellaviationcards.com/ShellEuropeOMNI3750ManualA4.pdf -
prolificbusinesssolutions.com/products/pdf/terminals-omni3750dual.pdf
Mar 30, 2011 | VeriFone Omni 3700
Whenever i turn on my htc g1 it starts up and shows the sing G1. Then when it goes to the ANDROID loading section it takes 1-2 minutes and then stops?? why
Take out your SD card and try booting it up. If that does not work then power off your phone and hold the end and call button at the same time for about 15-20 sec, press Alt-W at the same time, to do a factory restore (this will delete all your data). Then restart your phone and it should work.
Sep 01, 2010 | HTC G1
G1 is frozen after new system update its been 30mins and i already took the battery out to restart it
This was copied from a site on the web. I personally have used the instructions below and it worked for restoring my G1. Once it is restored, you may want to try to run the update again.
1. Turn the G1 off. If it’s frozen on, take the battery out and put it back in the unit.
2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
Now to wipe the device clean:
3. Press Alt+L.
4. Press Alt+W for a factory reset.
5. Press the Home and Back keys again for about 25 seconds.
The phone should reset again and the hard reset is complete.
Mar 09, 2010 | HTC G1
BLACK SCREEN · I TRIED TO RESTART MY PHONE AND NOW THE SCREEN IS ON BUT STAYS BLACK
I feel your pain. My g1 droped, the screen cracked, now 3 weeks later my screen turns black. Not even turning it off or removing the battery for hours changes this. However, i found if you wiggle the screen just right sometimes you can get your screen back... for a little bit.
Oct 17, 2009 | HTC G1
I hit the reset button on the router and now I can't connect to my wireless network. How do I fix this?
Try turning everything off- pc, modem, router, other pcs and periferals on the network, wait 10 minutes, then start turning everything on gradually- pc, modem router, etc. Hopefully everything will reset ok.
Jul 30, 2009 | Linksys Wireless-G Broadband Router
Windows error recovery
Hello!!
enter the repair the console by inserting the Xp cd.. and try the command FIXBOOT .. and then restart!!:)
Cheers!!
May 31, 2009 | ASUS G1 Notebook
I recently got new g1 phones for me and me girlfriend she took her sim card out to use a different on and when she put her other one back in it has her signed out of her google im and everything she can't...
restart it turn it off then press the little house button and the end button then a triangle will pop up press it and it will restart if it didnt work press the alt button and the house one of those should work
May 04, 2009 | HTC Google G1/Dream Cell Phone Black...
Bios gets reset whenever i turn on my pc
The battery on the mother board need to be replaced.
Dec 29, 2008 | ASUS Intel 845 Chipset P4B (P4B WOA)...
EliteGroup PT800CE-A Motherboard Logo
61 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
