Question about Linksys Wireless-G WRT54G Router
Linksys Wireless G Range Expander does not work
I purchased the Linksys Wireless G Range Expander from BestBuy and it quit working. BB's computer was down but its more than 30 days old. Where do I get this repaired. I consider it expensive to quit working.
    Scholar:
  • 162 Answers
When you say "quit working", do you mean the power is out on it or you can't access the internet?
Posted on Jul 27, 2008
  • 928 Answers
If youve had it for less than 3 years you should still be able to have it replaced with Linksys..... The number is 8003267114
What range expander should I use with a Linksys Dual Band Wireless-N Router Model WRT 320N?
For this router you can use the Linksys range expander model WRE54G v3 take not of the version number that is important since the older range expander don;t work on all routers.
Feb 13, 2011 | Linksys WRT320N Wireless Kit
Cant find a strong enough connection
You need to buy a Linksys Wireless-G Range Expander to boost the signal
  • Move your wireless router to a central location in your network, keeping in mind that the router should be at waist level at the very least, not on the ground.
  • Plug in the Linksys Wireless-G Range Expander in the room where your wireless router is. You'll move the range expander later, but for setup purposes, it should be in the same location as your wireless router.
  • Press the Linksys Wireless-G Range Expander's "Auto Configuration" button for five seconds, which will allow the range expander to detect your wireless network and configure itself with the appropriate settings.
  • Unplug the Linksys Wireless-G Range Expander and relocate it to a location closer to the Xbox 360.
  • Ensure that the antenna for the Linksys Wireless-G Range Expander is pointing upward, and keep in mind that the higher the range expander is placed, the better performance you will get out of it.
  • Plug the Linksys Wireless-G Range Expander back in, and your wireless network should have a much greater range, ensuring that your Xbox 360 is able to maintain a good connection to the network.
  • Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
    Hi, I just got Linksys WRE54G V.3 and was trying to install the CD. But I keep getting "Site Survey fail" message. My house is using a router made by Apple, and does not have extra space to...
    The range expander helps to extend the range of wireless network...
    Anyhow the range expander has to be placed withing the range of your Apple "wireless" router (Make sure your apple router is wireless router, if it is a wired router, then there is no use of range expander...! U need to buy an Access Point instead)...
    your range expander must be connected to the computer(using an ethernet cable) from which you are trying to configure...
    Site survey searches for the available wireless networks in range...
    It should show your existing wireless network...
    You need to select your appropriate network and you need to configure the Range expander wireless settings according to the Apple router's wireless settings...
    exactly the same SSID(Network name), Security type and encryption technique, password PSK (security key) has to be selected on your range expander as in the APPLE wireless router...
    Thats it...
    You are done...
    Your wireless network range would have extended now....
    Dec 09, 2010 | Linksys Wireless-G Range Expander (WRE54G)
    Link light on (blue), activity light off (neither blue nor red)
    Press the RESET button on the back of the unit and reconfigure the settings.
    Sep 11, 2009 | Linksys Wireless-G Range Expander (WRE54G)
    Intermittent/non-existant connection with LinkSys WRT54G router
    I would get a Range Expander... it sounds like you are having problems recieving a constant signal. When you do get the range expander plug the Range Expander halfway between you upstairs computers and your downstairs where your router is at. I hope this helps!!
    Sincerely,
    cdixon18
    The ManInsideTheMachine
    May 19, 2009 | Linksys Wireless-G WRT54G Router
    Linksys WRE54G WIRELESS 802.11G RANGE EXPANDER Range
    The actual max distance of the range expander is about 50 feet, and sorry to say but it cannot bounce the wireless signal from it on a wall....
    Jan 25, 2009 | Linksys Wireless-G Range Expander (WRE54G)
    Wireless g range extender
    Hi there ....
    before anything else, can you please what is the version of range expander is is wre54g v1,v2,v3?
    1) either which, please do verify your wireless settings of your DLINK router
    -- the network name or ssid
    -- security if you enabled any on your router
    -- wireless channel
    -- please check the default gateway of your router if it is 192.168.1.1
    ** please take note also that the best location for your expander would be inbetween your router and your computers
    2) once you have gathered the wireless settings
    -- you would need to manually configure your expander coz it didnt work .. Please remember that the LINKsys expander is designed to work with linksys routers, so it may or may not work.. I just need to set your expectations on this ...
    3) once you have verfied the default gateway of your DLink router ... please reply to this thread and let us proceed in configuring your wre...
    Thanks and good luck!
    Oct 31, 2008 | Linksys : WRE54G Wireless Range Extender...
    Linksys wireless G range expander
    Hi David,
    I need to know that what type of router u r using.
    If it is Linksys router just follow these steps,
    with the help of the Ethernet cable connect the range expander to any one of the 4 ports in the router...
    ur computer shuld be directly hook up to the router..
    open internet explorer in ur computer..in the address bar type in 192.168.1.240(ip address of the range expander)
    it will prompt for a username and password...leave the user name blank and the password will be admin.
    u can see the linksys range expander set up page...
    u can find SSID at the bottom of the page...
    ur router's SSID and the range expander's SSID should be same..and also the password should be same..
    If the ssid or password mismatch between the router and range expander u can find these kind of Error messages...
    Good Luck....try it and revert back
    Jul 03, 2008 | Linksys Wireless-G Broadband Router
    No Power
    Before you plug it in the wall, insert the installation disc and go through their tutorial. When you do that you'll plug in your range expander, press the auto configuration button on the side and wait for both lights to turn up blue. Then you can unplug the range expander and put it else where.
    Aug 08, 2007 | Linksys Wireless-G Range Expander (WRE54G)
    Linksys Wireless-G WRT54G Router Logo
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
