Question about Protron PD-DVR100 DVD Recorder
Connecting for surround on the PD-DVR100
The output I have has something called S/PDIF for digital audio output. What kind of a cable do I need to connect to the PD-DVR100 to record surround sound? I see on the back of the PD-DVR100 has a digital audio output, but not an input that looks the same. Is there a cable that goes from the S/PDIF to an audio l/r in?
Thanks, Bob
    Problem Solver:
  • 4 Answers
HOWDY-ARE YOU FAMILIAR WITH "HDMI"--DESCRIBE THE CONNECTOR YOU REFER TO--YOU ARE STILL TALKING ABOUT THE PD-DVR100--RIGHt? / RSVP------SARGE
Posted on Jul 27, 2008
When I connect Unisar TV920 to the digital (S/PDIF)audio output jack on my Philips 26PFL4507 no sound comes through. I've searched for a "simple" resolution. Is it something to do with the S/PDIF?
If the cable you use to send the S/PDIF signal is a fiberoptic toslink cable, inspect the ends very closely. The clear plastic nubs that protect the laser output can look an awful lot like part of the connection itself. If you haven't done so, remove them and try again.
Nov 19, 2014 | Unisar Extra Headset For the Tv Listener...
I have a Sony bluray surround sound and lg smart tv, I can't play my Apple TV sound through my hts, all my connections are hdmi and both systems have arc, please help?
Is your Apple TV connected to the Sony or directly to your TV? If directly connected to the Sony HTS ARC shouldn't be needed and you should have audio. If that's the case check the Apple TV settings to be sure it isn't set for s/pdif output. If connected to the TV then the TV should be able to put a s/pdif signal on the HDMI ARC pin but perhaps there's no way to assign it to the HDMI input coming from the HTS? It may be going to the ARC pin on the Apple TV HDMI input which won't give you any sound. Normally ARC is intended to put the s/pdif signal from the TV's internal tuner on the HDMI cable from the HTS so the HTS can play TV sound without having to tun a separate Toslink cable from the TV s/pdif output to the HTS. One other thing: Early HDMI cables do not include the ARC wire so be sure you have ARC capable cables. Look in your TV documentation to see if there is a way to assign the ARC output to a different incoming HDMI input if the Apple TV is connected directly to the TV. If not you may need to resort to a Toslink optical cable from your TV to an optical input on your HTS. Or actually running that cable from Apple TV to the HTS would be better since it's possible it could carry surround sound. Most TV's optical outputs are limited to the 2 channel sound the TV can accept.
Oct 22, 2014 | Audio Players & Recorders
What s-video cables do i need and what size and what kind of component video cable and what kind of coaxial cable do i need
If your TV has component, then get one component video cable (green/red/blue) and a set of RCA for audio (red/white).
S-Video/Coax is obsolete for dvd players unless you have an old TV.
Oct 29, 2011 | Protron PD-DVR100 DVD Recorder
How do I get my Samsung TV audio to output though my onkyo tx-sr608?
If it is a relatively new TV you should use an optical digital audio cable. These are often called "toslink" cables. Plug one end into the "digital audio out" port of your TV, and the other into a free toslink port on the receiver (there are two on the back and a third on the front of the 608).
You should then change the settings on your samsung tv to: - turn the digital audio (s/pdif) output on - allow bitstream output over s/pdif - turn the tv speaker off I am not sure which model Samsung you have, so I can't go into great detail, but I'm sure you will be able to find the relevant settings, most likely under "sound" in your system menu.
lastly, you will probably want to use the input assign page of the onkyo on-screen menu to assign whichever input you use to your TV, and change its name accordingly.
Jan 09, 2011 | Onkyo TX-SR608 Receiver
Would like help with hook up wiring
i can not find the sound driver of my notebook NT-R45 can you help me pls
Jun 03, 2009 | Sabrent SBT-USB51 External Sound System
Having trouble connecting Protron Model PD-007 to cable tv
are all your connections correct, (is tv on ch 3) dvd output to tv (coaxial or digital in) using tv remote make sure the source is air (or cable/sat ).. put dvd into player press play let load a picture should show (unless you are connecting with RCA wires then the tv would be on ch "video" this would be below ch 2
Jan 26, 2009 | Protron PD-DVR100 DVD Recorder
Connecting my wii to my home theater
  1. Connect your set-top box HDMI output to the Xbox One HDMI input.
  2. Connect the Xbox One HDMI output to your A/V HDMI input.
  3. Connect your A/V HDMI output to the HDMI input on your TV.
  4. Notes
  5. This option requires that all devices support audio over HDMI.
  6. Surround sound from your set-top box will not be passed through the Xbox One.
  7. When you perform this kind of basic setup with an A/V receiver, you're passing both audio and video through another device. Depending on your equipment, there's a small risk of audio or video lag.
  8. Connect your set-top box HDMI output to the Xbox One HDMI input.
  9. Connect the Xbox One HDMI output to the HDMI input on your TV.
  10. Connect the audio output from the TV to the audio input on the sound bar using either HDMI or optical S/PDIF cables.
Nov 09, 2017 | Electronics - Others
Hookup for recording in Dolby digital 5.1 surround sound
DVDR WILL NOT RECORD SURROUND SOUND IF NO SURROUND SOUND IS INPUT-THE MACHINE WILL RE-PRODUCE FAITHFULLY ANY SIGNAL INPUT TO IT--SARGE
Jul 17, 2008 | Protron PD-DVR100 DVD Recorder
Dont kno how to record
Connect your cable from the wall to the RF IN on the back of pd-dvr100
Connect your RF OUT on the back of your pd-dvr100 with a coaxial cable not included to the RF IN on your cable box
Connect the red, yellow, and white RCA Cable to the front or back of your TV
and to the audio out and video out on your pd-dvr100
Press the SETup button on your remote use the up and down buttons to select the channel scan sub menu
select IRC for your tuner input source
select scan and press Enter
The recorder can now record all scanned channels onto your dvd+r when you press the record button
I only got it to record the scanned channels.
The good thing is you can record on another station while you are watching a show on your cable box.
Aug 19, 2007 | Protron PD-DVR100 DVD Recorder
Surround cuts out???
Are you useing a digital audio cable when its cutting on & off? How long between the on & off? I have the same problem when I use a digital audio cable or a coaxial audio cable from my DVD player. To use the surround (6 CH) feature you need to use the 6 channel RCA jacks and if what ever your hooking up dosent have the RCA outputs your out of luck. My DVD player does have the 6 channel outputs and they work but the digital cables won't work. What are you connecting to it? I think something is wrong with the digital circuit board in mine, I would like to replace it and see. Reading your manual will help understand the 6 channel RCA and fiber optic digital cables. I hope any of this helped.
Mar 05, 2007 | RCA RT2280 System
Protron PD-DVR100 DVD Recorder Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
