Wired fax to wireless? (HP CM1312nfi MFP)
My phone line is not located near this machine. Can I turn my fax on this machine wireless?
    Genius:
  • 1,056 Answers
There are wireless phone line adapters.
Actually they use your household power lines to transmit the signal
http://www.gizmag.com/go/6001/
You can find adapters like this at places like Best Buy, Amazon, Buy.com, Newegg etc.
Posted on Jul 29, 2008
HP 1217 M1217 nfw MFP won't receive fax
Having the TAM set to four rings seems a bit high to me. Decrease the ring count on the Tam. the fax ring count does not really matter.
Keep your outgoing message to a minimum . if too long the calling machine will time out and drop off the line.
see how that goes. Also are you using the genuine adaptor lead. Does the tam actually ring? I suspect not. there are literally loads of adaptor leads that will fit and look the same but they are wired internally for that make only.
Jan 25, 2014 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
Is there a way to hook up my hp lazer jet pro m1212 nf mfp to be able to send a fax utiling my laptop which is by wifi. In other words no land line available.
Without a dial-up line available for your fax machine, the only other way to fax is via the internet if it's supported by your MFP. Google online faxing or fax via internet for solutions you may be able to use in your situation.
HISTORY
Fax or facsimile was invented as a way to take a printed document, scan it into digital form and transmit it to it's destination in a matter of seconds -vs- sending it via an expensive courier taking hours or days. This is before the internet, Adobe and other players made a way to create and send documents via the internet without the need for a fax machine and dedicated phone line. While faxes may still be sent that way when the printed document is the only media available, faxing has died off considerably. Most large companies now have ways implemented to move documents digitally without the need to fax. I predict the fax portion of a MFP to disappear in the not too distant future. Earlier MFP's didn't include a fax feature and one had to but the next model up to get it, now it's included in nearly every MFP. Adobe's PDF format with the ability to fill in the forms fields electronically (as in your US taxes) without having to have expensive office software made printing and faxing a thing of the past. Don't be surprised if the business or other entity requests you, and all of us, to submit a PDF document to their business email address rather than a fax.
Good luck with your quest!
Oct 15, 2013 | HP LaserJet Pro M1212nf MFP -...
Printer "off line"
Check the cable that connects the printer with your computer, also check that printer drivers are installed correctly
Jan 29, 2010 | HP Office Equipment & Supplies
We have a HP colour laser jet CM2320nf MFP and when we try and send a fax it comes up with error report Comm Error 345. Please explain
Check phone line. use a normal phone and plug into the same phone wall socket that the MFP is using, do we have a dial tone? Do we have a noisy line, any buzz or crackel will cause issues
If there is no dial tone ring line supplier, If it is noisy line do the same
Also check phone line is plug into "line" socket in the back of machine not "ext'
Also check no prefix is required to dial out, unit needs its own phone line..
Also try using resolution of fax as standard not fine, this requires less info to go threw the line
In Australia we have a thing called folds (fax online diag service), basicly it is a fax number you ring and the phone company who own the line send back a report, most times the issue is noisy line or no line available
hope this helps
Cheers
Soulvisitor
Nov 27, 2009 | HP Laserjet CM2320nf All-In-One Color...
My HP 6310 printer / fax is too far away from the phone line. Is there a way to fax wirelessly using this printer?
Only if you have fax software on your computer and scan an image to the computer to fax, otherwise you need a really long phone cable you can buy at Radio Shack or Best Buy.
Oct 29, 2009 | HP OfficeJet 6310 All-in-One Printer...
Modem fail errors between hp 4345 and savin mfp device
On fax settings set ECM to ON, JBIG to OFF, MAX BAUD RATE to 14.4, V34 to OFF then upgrade to latest firmware and make sure phone line is a 2-line phone line (look plug end of line and there should only be 2 metal strips on connector)
Mar 26, 2009 | HP LaserJet 4345mfp Printer
HP LaserJet M1522nf MFP No Fax detected
The book says
No fax detected
The product answered the incoming call but
did not detect that a fax machine was calling.
This could be really tricky. The missed faxes could be just random wrong number or recorded sales calls that are dialing you machine.
If you are sure they are fax machines calling then we get into phone line issues and that sort of thing. If you get static or noise on the line it can affect your machines ability to hear the other machine. I saw somewhere tha replceing the cord form the wall to the fax helped some people with a similar problem.
You can always try turning the machine off and unplugging it for awhile this is a common suggetion from HP for almost any product with a problem.
Hope this helps
Mar 12, 2009 | HP Office Equipment & Supplies
Hp laserjet m2727nf mfp - fax errors - sending and receiving. comm error 350, and comm error 232. Dedicated fax line. Any advice?
Check if you have the latest firmware for this multifunctional on www.hp.com, installing newer firmware fixed communication problem for us.
Apr 17, 2008 | Office Equipment & Supplies
175 people viewed this question
k24674
jasbo
jasbo
