Question about HP Office Equipment & Supplies
I have a Photosmart D7360. Recently when printing straight from the memory card, the images are too dark. I have to adjust the brightness to maximum for an acceptable print. Why should this have suddenly happened? Is there anything that can be done to remedy the problem? Brian Bath I am interested in subscribing, but am not sure whet I am signing up for? Is it a one off payment for this problem? An annual subscription? Or a monthly subscription? Your details do not make this clear. Please advise.
  • 3 more comments
  • brianebath Jul 28, 2008
    I did state that this is a problem when printing straight from the memory card inserted directly into the printer. For me this is the quickest method for basic printing.
  • brianebath Jul 29, 2008
    Thank you for the suggestion, it makes sense, but how do I do this?
    You suggested resetting printer to factory settings which was a good suggestion. I asked how to do this. You came back with a totally unconnected response.
    The printer is switched off and unplugged after every use. The problem is ongoing. Is there any other way to reset the machine?
  • brianebath Jul 30, 2008
    That was total nonesence. I explained that the problem was images printed when using the card slot direct into the printer were too dark. You suggested resetting the printer to factory settings. A good idea. You asked if problem happens when printing via a print program, no as I can easily check the brightness before printing. I want to be able to use the card slot for speed and convenience. How do you reset the printer?
    Genius:
  • 1,665 Answers
    Guru:
  • 859 Answers
Seems like no one is really addressing your main problem.
What is needed is to setup your printer station with brightness and contrast as well as saturation. The is will remedy the problem when printing off a memory card as opposed to printing from an application.
I'll be glad to help you. Just ask, and in your reply would you address it to the expert who made the suggestion, right or wrong, by using this approach:
Worldvet: Regarding your suggestion, I'd like your assistance;
OR
Worldvet: That doesn't make any sense can you clarify?
OK?
As to your first few sentences, when you come here to seek advice, you are offered a few options, one is to use he Free Forum, a good place to go if you have plenty of time to wait for an expert to get to you.
OR
Premium Questions: this is where you are now and this service is a one off purchase, however, you need not accept any answers until you are satisfied, then upon exit you'll be asked to rate the expert who gave you the Best Answer or, you'll receive an email from FixYa asking you to Rate your purchased assistance.
Hope this helps you understand what you purchased and how to handle the flood of replies. This flood of replies is called crowd sourcing and is rather new in the support field.
Lastly, there is no subscription, but many who have used the pay service and do not need help NOW, use the Free Forum and find it quite helpful. When you absolutely have to have it fixed RIGHT NOW, (happens to college students doing homework) we have Live Chats for $14.95 and gives you a personal chat window with an expert you can accept or refuse.
Further to help you understand who is who, a Guru is the highest ranking an expert can attain. You will notice that there is a number next to the ranking expressed in Votes. the more the votes the harder it is for us to keep a high ranking. So, anyone with less than 100 votes is still pretty new, much like I was once. Anyone with 100 votes or more and has a high ranking is going to be pretty good and has proven themselves. That said, I still find ways to improve myself.
If you want more aid from me just ask away and I can get you the pointers you need to get this solved and if I can't I'll tell you so... straight up.
Regards,
Worldvet
Posted on Jul 30, 2008
  • 4,472 Answers
First thing you may want to try and do is adjust the settings on your camera otherwise your will just want put them on the computer and adjust them with photo editing software.
Thanks,
Lee
Posted on Jul 29, 2008
  • 2,071 Answers
Introduction
The purpose of this document is to provide background information on the cause of photo cropping or the cutting off of images when they are printed. Photo cropping occurs as a result of disproportional horizontal and vertical dimensions, or Aspect Ratio.
Understanding Aspect Ratio
Each image size has a different Aspect Ratio that is determined by the digital camera or other device used to capture the image. If the Aspect Ratio of the print size is equal to the Aspect Ratio of the image, no cropping of the image occurs. However, if the Aspect Ratio of the print size is not equal to the Aspect Ratio of the image, the image will be cropped until the Aspect Ratios are equal.
Examples of photo cropping caused by disproportionate Aspect Ratios
A digital image of 1280 x 960 DPI (resolution - dots per inch) has an Aspect Ratio of 4:3, which, unless cropped, will result in two sides having white borders on the printed 4 x 6-inch picture. Instead of leaving the white border, the printer will increase the size the the image, center it on the paper, and finally crop the image so that the image ratio is 3:2, the Aspect Ration of a 4 x 6-inch photos (see Figures 1-4).
Adjusting Aspect Ratio
When using a digital imaging program to eliminate unwanted sections of images, the Aspect Ratio will change. Many newer digital cameras offer a 3:2 resolution setting that creates a borderless 4 x 6-inch picture. Check the digital camera user's manual to see if this feature is supported. When using a digital imaging program such as Adobe Photoshop Elements software, images can be cropped to the desired size as long as the Aspect Ratio is correct. The software should provide pixel size information to better determine the appearance of the printed picture.
To convert an image to a 3:2 ratio, divide the smallest pixel number by two, multiply that number by three, and replace the larger pixel number, the width of the image, with this new number. This will determine the correct Aspect Ratio for a 4 x 6-inch picture.
Example
For an image with a ratio of 100:50, divide 50 by 2. The resulting number is 25. Multiply 25 by 3. The resulting number is 75. Replace 100 with the 75. The new desired Aspect Ratio for an uncropped 4 x 6-inch picture is 75:50. The image settings can now be modified to a ratio of 75:50 with a digital imaging program.
hope this may help,
regards,
VOTIT
  • 84 Answers
If any normal clear image is not coming out clear replace ink cartridges
    Genius:
  • 1,689 Answers
A work-around is that you may power off the device, completely unpluged and leave it off for at least 30 minutes to an hour. that should also reset the settings to factory default.
i will still go further with your issue and will keep you posted if in case
hope this works...
  • marlon john madrid
    marlon john madrid Jul 29, 2008
    Reset the All-in-One to the factory default settings by using these instructions:
    1. Unplug the power cable from printer when the printer is powered on.
    2. Press and hold OK and HELP buttons while plugging in the power cord.
    I believe the above information helps you. If the issue persists, please get back to us with the results. We will be glad to assist you.
    We appreciate you giving us the opportunity to provide you with superior customer service. I wish to take this opportunity to thank you for being one of our most valuable customers.
    follow my last post on holding the OK and help button.
    i got this from an e-mail
    Sergeant:
  • 260 Answers
How does the printer peform with other jobs? If you are experiencing the same thing with other jobs then you may have an ink-cartridge problem. Also, make sure you are using the recommended paper for best picture quality.
  • Ken Jones
    Ken Jones Jul 29, 2008
    returning the printer to factory settings is usually done by the print driver. In windows you can usually find your print drivers at start/printers and faxes.
    What I hear you saying is that you never tried printing in a different way and therefore, all of your print jobs are printing poorly. If that is the case there most likely a problem with the ink-cartridges. They will need to be cleaned, refilled, or replaced.
  • HP Master
  • 13,433 Answers
Try restoreing the printer to factory defaults, this has worked to solve similiar problems before.
Posted on Jul 28, 2008
  • HP Master
  • 19,396 Answers
It can be the priinter settings or the software used to process picture before printing.
What software do you use?
If you process the pictures with photoshop or similar software you will not get this problem anymore
How do i get my scanner to work?
well did you go to my computer and put the disk of your printer and install it??
May 23, 2010 | HP PhotoSmart C4280 Laser Printer
Trutech Digital Photo Frame
Image quality using default factory settings is awful. Colors are over-blown, faces are washed-out, and highlights are cropped. People on the internet compained that there is no brightness control -- there is..but its hidden in a menu. Press the Setup button on the remote and move to the "System" settings. I've found these settings produce a fairly correct balance of color, detail, and brightness:
* Brightness=5
* Contrast=1
* Saturation=2
Mar 31, 2008 | Electronics - Others
Dark, horizontal lines after text and dark images.
This implies that your monitor had gone bad. you need to take it to a computer repair shop.
Apr 10, 2010 | HP w1907 LCD Monitor
Cannot print 5x7 photo on Photosmart D7360,
if you dont hvae 5x7 option you can creat your won setting open printer adn faxes ...>goto file ..>server properties there you can creat it......
Oct 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Printing is blobby rather than sharp
That my friend is your cartriges,i had the same problem.
Sep 28, 2009 | HP Photosmart D7360 All-In-One InkJet...
How to take apart HP photosmart D7360
My HP D7360 won't print. Its says the "ink system has failed. Unable to print. Refer to printer Doc. Error: 0xc05d1281" Now, I lifted the printer up and it sounds like a screw bouncing around on the inside. How do I take this thing apart to find the screw and put it back in it's place???
Aug 27, 2009 | HP Photosmart D7360 All-In-One InkJet...
Pictures appear to be darker than original in print outs.
You can make several adjustments to improve your images such as lightening dark areas, changing the exposure, sharpening blurred edges, and changing the brightness and contrast.
  • Exposure adjusts the overall intensity of light in an image.
  • Adaptive Lighting improves only the dark areas in an image without affecting the bright areas.
  • Brightness adjusts the amount of light in colors ranging from light to dark.
  • Contrast adjusts the difference in brightness between light and dark areas of an image.
  • Sharpness helps define edges and the smoothness of texture in an image. Use this tool to make a blurred image appear more focused.
Adjusting the image Follow the steps below to make adjustments:
  1. Click the View tab and select the image you want to edit by either clicking the image, or by clicking the small box at the bottom left corner of the image. Figure 1: Select the image c00603524.gif
  2. Click the Edit tab and then click the Advanced tab.
  3. On the Advanced tools tab, click Adjust Image .
  4. Select an adjustment from the list on the left. Figure 2: Adjusting the brightness c00603525.gif
    • The Exposure adjustment is automatically applied when the Adjust Image tool opens. Eight variations of the image are displayed on the left. The current image is displayed in the center. Each image represents a different level of adjustment. When you move the pointer over any of the images on the left, a large version of the image is displayed. Use Preferences to turn this large image preview on or off and to set the timing for the display.
    • If you want to use a different adjustment tool, select Adaptive Lighting , Brightness , Contrast , or Sharpness from the list.
  5. Select one of the images on the left.
  6. Do one of the following:
    • Click Accept to accept all changes and exit from the Color Toolkit.
    • Click Cancel to discard all changes and exit from the Color Toolkit.
  7. If you have finished modifying the image, do one of the following to save your changes:
    • Click Save to overwrite the original image.
    • Click Save As to save the modified image with a different name.
Aug 25, 2008 | HP Photosmart D7160 InkJet Printer
HP Photosmart D7360
HP support decided it could not be repaired on line, agreed to replace it but found it was a few days out of waranty...so it is dead in the water. Probably not cost effective to repair it.
Aug 03, 2008 | HP Photosmart D7360 All-In-One InkJet...
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
218 people viewed this question
Seeker5211
Seeker5211
