Remove carb from mower being careful to remember where all springs and rods are placed. Go to local auto parts and buy a can of spray carb cleaner and spray carb as thourogh as you can, spaying every hole you can see inside and out. Remove air screw from carb and spray through the hole and clean tip of screw. Screw in finger tight and back out one and a half turns. Put carb back on and prime it with just a small amount of clean fuel. May also want to check tank to be sure there is no dirt inside, if there is you should remove it and clean it out.
