Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
Dewalt Drill Transmission is slipping. How hard is it to change and what does it cost?
    Champion:
  • 313 Answers
If the drill is slipping in speed 3 & drill mode. it needs new transmission assy. see www.toolpartsdirect.com , www.ereplacementparts.com for pricing for the the parts.
Posted on Jul 28, 2008
  • mr aicnelav Jul 28, 2008
    it is not hard to replace the parts. do not dis-assemble the new parts when putting in. first removed the 4 screw that holds the clutch assy,silver housing. genty pull the clutch assy/with the chuck together.then you can pull the trans. make note that there is a guide for the trans to go in parts fo the yellow housing. soon as you installed the trans assy you have to runs the drill slowly until the speed seletor will flush to the housing, hope this helps
    thanx
Dewalt 771 slips in all torque settings in low, but works in high setting
The clutch is defective , you can get replacement parts from dewalt. There are several dewalt service centers in the US
Nov 03, 2014 | Dewalt Tools & Hardware - Others
925 slipping clutch what do i replace
The transmission part # 613237-00sv $32.79 suggested list. The transmission has a rod running through it that activates the clutch.
Sep 18, 2011 | Dewalt 18 Volt Compact Drill Kit
Using a garden auger with the torque set to the highest setting the clutch broke and started to slip. Is this too much for the Dewalt 720 cordless drill? Dewalt is repairing it under warranty.
Yes, luckily Dewalt is taking care of you. You might want to look into a 1/2' drive electric model (sorry with a cord) Alot depends on how hard the ground is but in the long run the big electric will handle about anything you throw at it. Check Sears or Home Depot both good sources for good tools
Jan 04, 2011 | Dewalt 18 Volt Compact Drill Kit
Can I adjust the slip clutch on my Dewalt XRP?
Yes it is the black ring with the numbers on it, the lower the number, the easier it slips. Higher number, less slip.
Aug 01, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My dewalt slips bad in the drill mode whiile i am drilling in hard material the drill slips real bad and it also does it in the hammer mode. Is that normal
Check the speed selector switch. if it is not fully engaged (usually because of dirt) the gears will slip. cycle the switch a few times.
May 21, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I have 3 of these and all of them have a problem after a while that they slip the clutch even when it is selected to the drill position, can the clutch be adjusted?
I just took mine apart and it appears that you have to replace the entire transmission. It is an easy job and the part is about $34 much cheaper than a new drill. Really, it is one third the price of a battery. Just take the 4 screws out that hold the metal case to the plastic clamshells, slide the front of the drill off, pull the transmission out of the rear of the drill put the plastic piece with the gear indicator on the new trans, if needed, slide the new trans into place, spin the motor if needed to get the output to line up with the planetary gears, slide the front of the drill back into place, rotate the chuck to align the shaft  with the transmission output, put the 4 screws back in, enjoy.
Might want to replace the brushes while you are in there as well. I am going to consider this the dewalt version of an oil change
Dec 29, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
The chuck is slipping. It will not spin the chuck anymore, motor works fine.
the transmission uses a planetary gear system. the motor is a johnson gearmotor. change the transmissioon. go to the dewalt service center for parts.
Oct 15, 2009 | Dewalt 18 Volt Compact Drill Kit
I have a dewalt dc925 combi drill the chuck keep slipping and also the setting ring is hard to adjust . What can i do top solve this?
Probably needs a new transmission. They cost about $34 plus shipping. Easy to fix. Just remove the four torx screws from the metal (gray in color) part $of the drill. Then pull it apart. The transmission comes in a one piece cassette. Insert it, and put the front back on and tighten the screws.
Mar 10, 2009 | Dewalt 2 Dc925 18v ½ Hammer Drill /...
HAMMER MODE SLIPS OUT
i am guessing the transmission problem not enough tension to the clutch
Aug 11, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt 18V XRP Clutch Slipping
it very economical to repair the drill. replace the transmission.
Apr 27, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
411 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
