My Heward Packard desktop 932C will not connect to my Dell laptop
  • 446 Answers
What kind of connectivity you are trying to connect, most connectors comes as a USB cables, this comes as a easy connector that should be no problem at all, pls follow this info...
This document describes the hardware setup for a new printer. Unpack the printer
  1. Unpack the printer and its peripherals from the box. My Heward Packard desktop 932C - c00107974.gif
  2. Turn the knob on the rear access door of the printer counter-clockwise.
  4. Push the module back into the printer until it snaps firmly into place. (Do not press the buttons on the ends of the module while replacing it.)My Heward Packard desktop 932C - c00107976.gifttp://i.fixya.net/uploads/images/c00107976.gif" alt="c00107976.gif" class="h_mi" />
Insert paper
  1. Slide the paper adjuster out as far as it will go.
  2. Flip up the OUT tray so that youMy Heward Packard desktop 932C - c00107977.gifIN tray more easily. c00107977.gif
  3. Place up to 100 sheets of printer paper face down in the IN tray.
  4. Slide the paper adjusters to fit snugly againMy Heward Packard desktop 932C - c00107978.gifof the paper.
Turn on the power
  1. Locate the power module for the printer.
  2. Insert the rectangular end of the power supply cord into the power outlet on the back My Heward Packard desktop 932C - c00107979.gifr.
  3. Insert the two-prong end of the cord into an electrical outlet.
Insert cartridges
  1. Open the top cover of the printer. When you open the cover of the printer, the RESUME button will flash until you close the cover. The printer part that will hold the cartridges (called the cartrMy Heward Packard desktop 932C - c00107981.gifmoves to the center of the printer.
  2. Remove the ink cartridges from the box.
  3. Remove the tape from the cartridges. c00107981.gif CAUTION: Do not touch the copper contacts (on the back of the cartridges) or the ink nozzles (on the bottom of the cartridges).
  4. Lift the cradle latches inside the printer.
  5. My Heward Packard desktop 932C - c00107982.gifck ink cartridge vertical, with the copper electrical contacts toward the rear of the printer.
  6. Push the black ink cartridge firmly down into the cradle on the right. c00107982.gif
  7. Hold the color ink cartridge vertical, with the copper electrical contacts toward the rear of the printer.
  8. Push the color ink cartridge firmly down into the cradle on the left.
  9. Close both latches. When you push down the latches, you will hear a click and feel resistance.
  10. Close the lid of the printer. You will hear the sound of the cartridge cradles as they move to the right side of the printer.
Attach the printer Attach the printer to the computer with a parallel cable or a USB cable. Print a test page Turn the printer on and press the RESUME button to print a test page.
  1. If the RESUME light continues to flash, press it again.
  2. If the printer cable is firmly attached to the printer, then check to be sure that the printer cartridges are seated securely in their cradles.
  3. If the printer cartridges are seated firmly in their cradles, then check for any tape or packing material that you may have left inside the printer or on the cartridges.
  4. If you press the RESUME button for too long, you may print several test pages unnecessarily.
check it out.... goodluck
Posted on Jul 27, 2008
How to make copies off of iPad using Hewlett-Packard printer 4620 with Wi-Fi
you would have to install the Ipad on your network.. you should be able to got to hte printers section in your Ipad then add a printer from network. Assuming the printer is already on the wireless network.
Jun 28, 2013 | HP Office Equipment & Supplies
Tip
How to enter bios in dell laptop
Applicable To:
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
Related Topics
How to access bios in Acer
How to access bios in Dell
How to access bios in Compaq
How to access bios in Emachines
How to access bios in Fujitsu
How to access bios in Gateway
How to access bios in Hp
How to access bios in Ibm
How to access bios in Lenovo
How to access bios in Micron
How to access bios in Nec
How to access bios in Packard Bell
How to access bios in Sharp
How to access bios in Shuttle
How to access bios in Sony
How to access bios in Toshiba
on Mar 05, 2010 | Dell Inspiron 530s Desktop Computer
My packard bell mx 65 easynote laptop powers on with a grey screen
check the display settings in Control Panel.
  1. open Screen Resolution.
  2. make changes here
Mar 26, 2013 | HP Pavilion a305w (DM181AR) PC Desktop
Color cartridge runs out even though I'm only printing b&w typed scripts. Any way to shut it off? Only have use for color printing once in a blue moon Hewlett Packard HP DeskJet Printer #932C
Even though you print a b/w document... unless you say 'black cartridge only' in your printing preferences, all the colors get used.
Find 'black cartridge only' in your printing preferences, or 'print in greyscale' and then print your document. You must specify this for your printer to know that it must use the black only.
Jul 23, 2010 | HP DeskJet 932c InkJet Printer
No Picture
I have a 42 inch hd lcd Heward Packard televsion with no picture or sound, it is just two years old. When I plug the cable direct without my cable box I get sound but no picture, the cable came out and tested everything and we tried to rest the tv but still no picture.
Nov 21, 2009 | Televison & Video
Use 932c deskjet laptop - plug doesn't fit
There is an adapter but it not work qualitatively.Better buy new usb or LPT cable and change it.
Nov 12, 2009 | HP DeskJet 932c InkJet Printer
Can't install old printer on newer computer
The appropriate printer drivers are bundled with XP. With the printer connected to the computer and powered on, the system should automatically recognize the printer and install the correct drivers if it is connected via USB. If it is connected to the parallel port, go to Control Panel -> Printers, select Add New Printer and follow the on-screen prompts.
Mar 21, 2009 | HP DeskJet 932c InkJet Printer
I have a hewart packard deskjet 932c printer. The orange light just blinks continuously and it will not print.
removed the cartridge and clean the circuit surface with pencil eraser then try to install it again..
Apr 15, 2008 | Office Equipment & Supplies
322 people viewed this question
jasbo
jasbo
