Computers & Internet Logo
A
Anonymous Posted on Feb 23, 2011
When i try to play FIFA 2011 it keeps showing e0001
Anonymous
Level 3:
President:
  • Master 2,340 Answers
  • Posted on Feb 23, 2011
Anonymous
Master
Level 3:
President:
Answers
2340
Questions
0
Helped
716464
Points
6960
FIFA 2011 it keeps showing e0001???
Your Graphic card does not support the FIFA 2011 game.
Get a better graphic card which support at least "Shader Model 3". Most of the intergrated ie onboard graphic cards do not support the game.
Hope it helps.
Giselle
Level 3:
Genius:
  • Master 1,015 Answers
  • Posted on Mar 05, 2019
Giselle
Master
Level 3:
Genius:
Answers
1015
Questions
6
Helped
286342
Points
2407
If you want to play your FIFA game better, you may need more FIFA Coins to make your team stronger, for cheap and safe FUT Coins, you can have a view on htpps://www.fifacoin.com, FIFA 19 Coins are available there, good luck to you
E0001 fifa2011
Your graphic card does not support the graphics for the PC game FIFA 2011 and it generate the error E0001.
You need to upgrade the graphic card, which at least support the "shader mode 3" to play higher graphics PC games.
Hope it helps.
Sir, I am having trouble with E0001 when i click on play in the fifa 2011 open window.Please help me.
This error means that you PC doesn't support Fifa 11. You will have to upgrade your computer to get this game to work.
3helpful
2answers
I cant start my fifa 2011, shows me E001
Fifa 11 Demo PC E0001 Error Issue
Fifa 11 E0001 error happened to a PC with this or a similar Specs: Pentium dual core, integrated Intel graphic card, 1GB of RAM, 128 of vid RAM, 2.0 pixel shaders.
Fifa 11 Demo PC E0001 Error Issue Fix:
1. Fifa 11 requires a shader model 3 or better card. That is error E0001 will be fixed and you can play this game again.
So if you get an error message as E0001 while playing Fifa 11 on Windows 7 or other systems, you should first set to the shader model 3 of your card.
2. This E0001 error issue may also be related to the graphic card that you are using. Check the drivers you are using for the video card. Update and reinstall it if necessary.
3. Get the latest driver pack for the same and then process out for the implementation. You can download the current new AMD catalyst 10.9 graphics card driver here. Or NVIDIA ForceWare 260.63 driver if you are using a Nvidia card.
4. Change the resolution to have a try. Some users get the E0001 error fixed for Fifa 11 by trying the 1280x1024 resolution on his computer.
Hope this solution was helpful? Please comment for more information and thank you for using fixya
3helpful
My fifa 11 no working e001 problem
1helpful
I installed FIFA 11 on my PC and when I run it it comes up with a box say 'E001'.
4helpful
2answers
When i run fifa 11 after opening fifa config it shows "e0001 error" please help me !
E0001 ERROR -> Fifa 11 requires a "Shader Mode 3" or better card. That is error E0001 will be fixed and you can play this game again
You can try updating your graphic cards to the latest drivers from Manufacture Site, update your DirectX to the lastest too. If the problems is not solved, then you have to get a better card in order to play the game.
FYI
Chipsets used in models:-
NVIDIA GeForce 7300, 8100, 8200, 8300 und 9300,
ATI Radeon HD3200, HD4350, etc.. and
Intel/S3 do not satisfy the hardware requirements.
Hope it helps
4helpful
2answers
When i start my fifa 11 then it can't start its writting E0001,what shoul i do?
Lol just change your resolution and then change back....worked for me
6helpful
I INSTALLED FIFA 11....BUT WHEN ISTART THE GAME IT SHOWS E0001 ERROR..........PLS HELP ME........
FYI
Hope it helps.
Grand Canyon Tech
Grand Canyon Tech
