Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Ref. leaking. ref.leakes inside ref out of air flow duct
  • 481 Answers
Unless the water is constantly flowing then the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 27, 2008
2001 bmw 530i heat only comes out defroster all others blow cold , vents are working redirecting air flow , any thoughts
sounds like a trap door is stuck not allowing the heat to flow through your air duct properly ..check for any bad vacuum leaks around your intake or around your air flow leading to intake vacuum
Oct 26, 2013 | 2001 BMW 325
P0101
The simplest thing to do is to reset the code and see if it comes back. Any loss of vacuum to the MAP sensor can cause this DTC to set. A number of problems can cause this code, for example, a bad mass air flow sensor, a vacuum leak, a leak in the air duct between the air flow sensor and the engine, a sensor wiring problem, etc. Even a plugged catalytic converter can cause this code. good-day !
Jan 08, 2012 | 2006 Volkswagen Jetta
I HAVE A 94 ford escort that is leaking antifreeze on the drivers side floor
there is only so many things that can cause this and are you sure its anti-freeze and not washer fluid.just something else.a damaged heater core is usually what causes a leak inside the car.when the heater cores were replaced did the shop say there were signs of them leaking or couldn`t see anything.the other is coolant from a previous leak could have spray aroung the air ducting in the dash and has finally found a way out.but this should have been gone shortly afterwards and usually there is only a mist that is sprayed into the air ducts which usually shows up on the inside of the windows,so i don`t think this is the problem.if the hose clamps are loose were the hoses are fastened to the heater core spigots/tubes it could be leaking inside the cars air duct.and yes its unusall for anti-freeze to leak onto the drivers floor but stranger things have happened.
Oct 26, 2011 | 1994 Ford Escort
I am a girl with a 1985 cad fleetwood brougham and the air flow for defost is not working and i get steam coming out .Is it a heater core? karen
if it is sweet smelling steam, it is a leaking heater core. They are hard to get to. If a small leak, add a can or bottle of stop leak to the radiator or coolant reservoir.
The no air flow to the defrost ducts is confusing since, by law, the system is desgined to fail to defrost if there is a system problem, like a vacuum leak to the heater controls.
Sounds like you have 2 issues. Is the coolant low in the radiator and overflow bottle?
report back.
Nov 17, 2010 | 1985 Cadillac Fleetwood
No heat heater core leaking there was little to no air flow
if the heater core is leaking,it could have built up sediment inside and has the flap inside stuck,sounds like you need to replace the heater core and check the duct work
Jan 01, 2010 | 2001 Dodge Ram 2500 Truck
Where is mass air flow senser on a 1989 buick regal
Hi
Thanks for using FixYa. The BUICK Regal Mass Air Flow sensor is usually installed in the intake air duct between the air filter and the throttle body mounted on the intake manifold. Also check the throttle body for mass air flow sensors location.
On mass air flow sensors with a sense wire, this wire can become contaminated with dust particles. These particles can be removed with automotive solvents that are safe for the use on mass air flow sensors. Before replacing the mass air flow sensor check for air leaks in the connecting air ducts and intake manifold. These leaks can cause similar symptoms as a malfunctioning mass air flow sensor.
Bad or contaminated BUICK Regal Mass Air Flow sensor can possibly cause a wide range of various vehicle drivability problems such as stalling, especially when the engine is cold, misfiring, poor acceleration, etc. In addition, a problem with the Mass Air Flow sensor often causes the "check engine" or "service engine soon" light in the vehicle instrument panel to illuminate.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | 1989 Buick Regal
SMALL OUTDOOR BEER REFRIGERATOR DOOR LEFT OPEN OVERNIGHT IT STARTED DEFROSOTNG AND THEN ACTED LIKE IT BULIT UP PRESSURE AND BLEW OUT AIR OR REFRIGERANT AND DOES NOT COOL ANYMORE
Hi, absolutely there's refrigerant (freon) leak check your condenser and evap. for rupture (broken lines) also check for oil, presence of oil means, refrigerant (freon) leak, plug ref, and listen, for hissing sound inside and outside of ref. try to locate leak, or call mechanic, repair leak, change filter drier and recharge, if your evap punctured, you should immediately disconnect ref, and dry all water from evap, prevent water from entering system, could damage compressor, or if water get into compressor, you will have to change compressor oil. yes, you surely have a refrigerant (freon) leak.good luck.
Aug 12, 2009 | Refrigerators
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
Whirlpool fridge getting water from upper freezer compartment
well if you hat the freezer on top normaly air leaks inside freezer through the drain tube, that air turns into condensation and creates a ice and cloges your drain. now water can drain down to pan everytime ref goes into defrost , and water leaks to bottom section to air ducts and air returns. there are several ways to solve this problem the cheapeste way is to unplug refrigerator for 2 days then plug back up and it should go back to normal another way is to install a heat probe on your drain attached to your defrost heater , and add a grommet on drain tube that will let water drain but it will keep air out and that will solve your problem.
Oct 12, 2008 | Whirlpool Refrigerators
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
46 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
