Question about Cameras
Hi, thanks for responding
It makes 4 "beeps", they are more of a pling pling like tone and there is no error message
    Genius:
  • 3,422 Answers
Please remove your battery and polish the terminals with a dry cloth and make sure the terminals are clean. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and power may not be fully supplied to the camera.
Also, polish the battery charger terminals with a dry cloth before charging the battery. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and the battery may not be fully charged.
Next please remove your memory card and format in your pc using card reader and then use it on your cam.If you have another mem card then use it in your cam and see if you face the same problem.
Also try removing your mem card and battery from your camera and allow it to reset for 20min,then just insert the battery without the mem card and see if you face the same problem.
If you need any more help let me know..
Please don''t forget to rate or accept the solution no. 2 in the premium problem.
Posted on Jul 28, 2008
Why does my computer make a long beep sound when booting up?
When a PC Boots up, it goes through a series of tests called
"power-on self-test " or POST.
If an error is found, the O/S will produce a specific tone or tones.
For example, It may be 1 Short and 1 Long. This tells the user what is wrong and why the PC won't Boot properly.
Take particular notice of the exact series of beeps.
To decipher the message, you should know what BIOS your PC has.
Otherwise, Google "POST beeps" and you should be able to figure it out.
Apr 20, 2014 | Computers & Internet
No display problem for intel D865GSA board
What are you formatting ? Have you changed the RAM. Does tour system work in its original configuration ? You do not say what the pattern of the beeps is. Before the display disappears, is there a message sent to the screen ?
From the manual
http://download.intel.com/support/motherboards/desktop/d865gsa/sb/d5600601us.pdf
Whenever a recoverable error occurs during POST, the BIOS displays an error message
describing the problem (see Table 53). The BIOS also issues a beep code (one long
tone followed by two short tones) during POST if the video configuration fails (a faulty
video card or no card installed) or if an external ROM module does not properly
checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors,
usually consisting of one long tone followed by a series of short tones. For more
information on the beep codes issued, check the documentation for that external
device.
There are several POST routines that issue a POST terminal error and shut down the
system if they fail. Before shutting down the system, the terminal-error handler issues
a beep code signifying the test point error, writes the error to I/O port 80h, attempts
to initialize the video and writes the error in the upper left corner of the screen (using
both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to
the operating system.
18.April.2014
18.April.2014
Apr 18, 2014 | Intel 865G Motherboard
4 beeps on start up but no screen
four beeps is ram I believe. Take everything off and see if it starts and then put stuff back one at a time and see what is causing the problem
Oct 01, 2013 | Dell XPS 200 PC Desktop
INSTEAD OF RINGTONE, I GET A SINGLE BEEP
your phones alert tone was set to beep once, to change this go to profile settings then open the activated profile such as general>personalize>message alert tone then now choose the ring tone you want to use as message alert tone..
Jan 30, 2010 | Nokia 6101 Cellular Phone
How do I make a voicemail tone on the lg xenon?
okay call your voicemail which you can do automatically by holding down the one.Then you need to do option 4 which will get you into personal options and then option 3 which you can select before the voice says, and then next option 1 and then 3 and then record your personal greeting. After you are done press pound if you like how it sounds if not press star to make it better. Hope this helped
Aug 20, 2009 | LG Xenon GR500 Cell Phone
Error Beeps On Start Up
Hi!
It could be a problem with the keyboard that it might have a sticky key. Try to check the keyboard for some sticky keys and check if you can still clean them or else replace it. :)
Hope this helps!
Thanks,
Karlox™ :)
Jul 10, 2008 | Computers & Internet
Samsung E900
Sound settings Use this menu to customise various sound settings.
Incoming call
Use this menu to select a volume level and alert type
for incoming calls.
Alert type: specify how you are to be informed of
incoming calls.
Ring tone: select a ringtone for the call ringer.
Volume: select a ringer volume.
Keypad tone
Use this menu to select the tone that the phone
sounds when you press a key.
Message tone
Use this menu to set up the ringtone for incoming
messages.
Menu functions
Tone: select one of several message tones.
Alert type: specify how you are informed when a
message comes in.
Repetition: specify how often the phone informs
you of a new message.
Power-on/off tone
Use this menu to select the melody that the phone
sounds when it is switched on or off.
Slide tone
sounds when you open or close the phone.
Silent mode
Use this menu to set how the phone acts to alert you
to a specific event in Silent mode.
Extra tones
Use this menu to customise additional tones for the
phone.
Minute minder: set the phone to beep every
minute during an outgoing call to keep you
informed of the length of your call.
Connection tone: set the phone to beep when an
outgoing call is connected to the system.
Alerts on call: set the phone to beep when you
receive a new message or when the time for an
alarm comes during a call.
Indicative tone: set the phone to beep when a
pop-up window displays.
Apr 28, 2008 | Samsung SGH-E900 Cellular Phone
Tone Pulse
yea.. this happeneded to me aswell.. here's what you do: (this is in the manual btw) TONE/PULSE SETTING 1. Make sure the phone is OFF (not in TALK mode). 2. Press the program button. 3. Press * tone button for tone or # pause for pulse selection. 4. Press the program button again. You will hear a confirmation tone.
Feb 28, 2007 | GE 27990GE3 Cordless Phone
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Cameras Logo
62 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
