Question about Electrical Supplies
Poulan pro pp4620 avx chain saw won't start
Chain saw ran fine for over 35 hours of use, then abruptly at half tank chain saw seemed sluggish at which point only 10 minutes later it chugged then died. Attempted restart three times, first time it caught, ran 15 seconds, and died, second time it just caught without starting. now it doesnt even catch. cleaned air filter but has no effect. Gas/oil ratio am pretty sure is correct. other than that i have no idea whats going on. do you have any ideas?
Thanks!
Soundless_1@yahoo.com
Dunno if it was castletowery's suggestion or the action I took additionally. However, after adjusting the carburation AND changing the spark plug it runs just fine. Spark plug however, was definitely part of the problem as it was a bit dirty so would have had to be changed anyway. Thanks to Castletowery for his input.
Posted on Sep 23, 2008
    New Friend:
  • 182 Answers
Put a new spark plug in
Posted on Sep 21, 2008
Poulan PP4218 avx; tube (line) inside gas tank connecting filter has rotted and need to replace. Is there a tool used to push line onto "nipple" inside tank.
cheapest way is a new fuel tank from e-bay that has it all installed
you can remove the rubber grommet around the lines to get it out then get a new filter to push on the line BUT will it be cost effective against what can be obtained from e-bay
Aug 01, 2013 | Poulan Pro Chain Saw 46cc 20"
I have a Poulan Pro PP4620 AVX 46cc Gas Chainsaw w/20
If this is the tooless adjustment, it sounds like the small gears in the cover have stripped, remove the side cover, turn it over and remove the cover over the tentioning mechanism, replace parts as required.
Apr 18, 2012 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
My Poulan Pro chain saw (model # PP4620 AVHD) doesot move B&C oil from the oil reservoir to the chain. How can I repair this?
If the ports where the oil comes out aren't clogged, you will have to order a oil pump and then take apart the saw from right underneath the bar. The oil pump is run by a worm gear that strips easily.
Aug 22, 2011 | Poulan Pro Chain Saw 46cc 20"
is the area where you tighten up the chain clean there are a few holes in the bar that allow the oil to drip on to the chain if its been used for a while the holes could be clogged take off the bar and chain and clean with a small flat head screwdriver the groove that the chain rides in there should be a hole that goes all the way through make sure you wipe away any wood chipsthen run it and see if it throws out any oil
Aug 21, 2011 | Poulan Pro Chain Saw 46cc 20"
I have Poulan Pro 42 CC 18" Chain Saw. When I
Check to see if you have the chain oriented correctly - it is east to put them on backward without realizing it. Th3e teeth should point forward, with the anti - kickback lug in front of the tooth. Let me know if this helps!!
Nov 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Bar oil leaks into storage case when chainsaw not in use???? Poulan Prow, PP4620 AVX 46 cc
The easy fix is to drain the oil tank when not in use. Many saws will leak some oil initially, but should not continue to do so. If it is making a large puddle, oil is getting past the oil pump which may be worn from long use. Make sure the tank vent is not plugged as heat from the engine can increase pressure in the tank thus forcing oil out. Hope this helps!
Mar 27, 2010 | Poulan Pro Chain Saw 46cc 20"
The throttle trigger and trigger lock are both jammed in and I can't get the saw started. it's a Poulan 16 inch chain saw. Does anyone know if there is something I can do to release them short of taking it...
Clarification Request
Posted by dontbother10 on Sep 16, 2009
We need the make, model, and serial numbers from the manufacturer’s tag to help you farther.
I think your rivits are roll pins but without clarification cannot verify that.
No response to clarification request. Close
May 11, 2009 | Poulan Garden
I would like the fuel mixture for my poulan chain saw. %oil,%fuel
If you don't know the model, then go with a 35:1 or 40:1 ratio. 40:1 seems common on most smaller saws from Ryobi and Poulan is a relation to those. The 35:1 suggestion is just for a little buffer in case. Generally it is ok to run a richer oil mix. It just means you may have to change spark plugs more often, however, your combustion chambers will be better lubricated and probably last longer!
Sometimes there is a little sticker or marking on the fuel tank cap or somewhere near it that indicates advisable oil:fuel ratio... Have a close look, it may be indicated somewhere on the saw itself.
Mar 13, 2009 | Poulan Pro Chain Saw 46cc 20"
2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
Nov 13, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Electrical Supplies Logo
302 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
