Question about Sony PlayStation Portable (PSP) Console
Memory stick music problem
When i drag and drop an mp3 music file to the music folder on psp, it does not show up in the folder. sometimes it still plays on the psp, but i get bits of different songs joined together that i did not transfer.
  • Sony Master
  • 6,487 Answers
How about if transfer music using Copy and Paste option have you tried that and check if the music is playing fine?
Hope that helps.......
Posted on Jul 27, 2008
I what to dowuload game form pc to my pspgame so how can i do it pls
Here are the steps to follow:
1) Insert a Memory Stick into the Memory Stick slot in the left side of the PSP. Depending on how many files you want it to hold, you may need to get a larger one than the stick that came with your system.
2) Turn on the PSP.
3) Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
4) Scroll to the "Settings" icon on the home menu of your PSP.
5) Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
6) Create a folder called "PSP" on the PSP Memory Stick (if there isn't one already) -- it shows up as "Portable Storage Device" or something similar -- (you can use Windows Explorer on a PC, or Finder on a Mac). There should also be a folder called "MP_ROOT" (not inside the "PSP" folder).
7) If they aren't there already, create folders called "PHOTO" and "MUSIC" inside the "PSP" folder. There also should be a folder called "100MNV01" inside the "MP_ROOT" folder.
8) Drag and drop files into the folders just as you would save files in another folder on your computer. Image files go in the "PHOTO" folder, audio files go in the "MUSIC" folder, and video files go in the "100MNV01" folder.
9) Disconnect your PSP by first clicking on "Safely Remove Hardware" on the bottom menu bar of a PC, or by "ejecting" the drive on the Mac (drag the icon into the trash). Then unplug the USB cable and press the circle button to return to the home menu.
This should help you to move those files.
Mar 10, 2011 | Sony PlayStation Portable (PSP) Console
How to use the usb to down load music from my computer
  1. Insert a Memory Stick into the Memory Stick slot in the left side of the PSP. Depending on how much music you want it to hold, you may need to get a larger one than the stick that came with your system.
  2. Turn on the PSP.
  3. Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
  4. Scroll to the "Settings" icon on the home menu of your PSP.
  5. Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
  6. If there isn't one already, create a folder called "PSP" on the PSP Memory Stick -- it shows up as "Portable Storage Device" or something similar -- (you can use Windows Explorer on a PC, or Finder on a Mac).
  7. If there isn't one already, create a folder called "MUSIC" inside the "PSP" folder.
  8. Drag and drop image files into the "MUSIC" folder just as you would save files in another folder on your computer.
  9. Disconnect your PSP by first clicking on "Safely Remove Hardware" on the bottom menu bar of a PC, or by "ejecting" the drive on the Mac (drag the icon into the trash). Then unplug the USB cable and press the circle button to return to the home menu.
Nov 28, 2010 | Sony PlayStation Portable (PSP) Slim...
How can i put music on my PSP
1 connect your PSP to your pc
2 a window will open with what is on your PSP's memory card.
3 if you dont have a folder labeled music make one and label it MUSIC
4 add your music to that folder... just drag and drop the mp3 files into it.
5 disconnect your psp go to the icon music on your psp and your music will be there
6*** the only limitation will be if you dont have room on your memory stick.... I would suggest using at least a 2gb stick to store music/movies on
hope this helps
Jun 02, 2010 | Sony PlayStation Portable (PSP) Console
I up load it music 0n my psp,but ti says no tracks
You need to make sure the music your putting onto the PSP is in MP3 format. Other then that here is the steps to make sure your uploading the music properly:
To get everything working, plug the Sony PSP into the Windows PC via USB cable, plug the PSP into the wall, then turn both units on. On the PSP, click the "USB Connection" button (on the Settings menu) and, hopefully, your PC will beep and tell you that it's found a new "removable disk": your PSP.
Using Windows Explorer, find the new PSP device and if there isn't already a folder named MUSIC then create it and drop in MP3 format music files
Then at this point you should be able to access the music on your psp.
Dec 02, 2009 | Sony PlayStation Portable (PSP) Slim...
I can't seem to view my copied files on my psp
in that memory stick the capacity min only is their due to that it shows fat means high memory capacity is dragged in ur system.
Apr 17, 2009 | Sony PlayStation Portable (PSP) Console
I cannot put music in my psp no matter how much i try
Connect to a computer with a usb cable and go to usb connection on the psp xmb then drop your music in the MUSIC folder on your memory stick.
Feb 02, 2009 | Sony PlayStation Portable (PSP) Console
Psp
Follow this steps to transfer music on PSP:
  2. Turn on the PSP.
  6. Create a folder called "PSP" on the PSP Memory Stick (if there isn't one already) -- it shows up as "Portable Storage Device" or something similar -- (you can use Windows Explorer on a PC, or Finder on a Mac).
  7. Create a folder called "MUSIC" inside the "PSP" folder.
Hope that helps........
Aug 23, 2008 | Sony PlayStation Portable (PSP) Console
The music I put in my psp doesnt work
Make sure you have it in the "MUSIC"(all in caps) folder within the PSP folder of your Memory Stick.
Inside the Memory Stick's PSP's MUSIC folder, you should either have the song file itself(mp3 or wma) or no more than one folder.
I.E:
Memory Stick>PSP>MUSIC>Gwen Stefani>Don't Speak.mp3
or simply
Memory Stick>PSP>MUSIC>Don't Speak.mp3
Aug 08, 2008 | Sony PlayStation Portable (PSP) Console
Can't download pictures
The first step is to make sure that you have a Memory Stick Duo in your PSP and, if necessary, format the Memory Stick with the PSP itself (go to Home, then Settings, then scroll down to System Settings and use the 'X' button to select this option, then scroll down to Format Memory Stick and select the option). You'll only have to do that once.
Next, take the USB cable and hook one end into the PSP on the top middle edge and the other end into your PC.
Now, using the Settings menu, choose USB Connect and your PC should shortly see your PSP as a removable drive.
The very first time I did this on my Windows XP system, the OS installed some new drivers, then promptly told me it had to reboot for the device to be mounted on the system:
f2a3054.jpg So, logically, I did just that, and when it rebooted the device showed up as Removable Disk G:, as shown here on My Computer:
84b8747.jpg Double click the new drive and you'll find that there's only one folder therein, called PSP. Double click in that and you'll find that you have four folders that the format has created:
82df731.jpg Looking good! Now if you have MP3 music files, you can drag and drop them into the MUSIC folder (and if they're in the wrong audio file format, please see How to convert WMA audio files into MP3 audio files), and JPEG (or, sometimes, JPG) photographs or graphics, you can download them into the PHOTO folder. Once you've done that, perusing the PHOTO folder, for example, will reveal that your pictures are loaded and ready to use:
ebed3a5.jpg That's about all you need to do, believe it or not. Copy any music or graphic files you want into the appropriate folders, then when you're done move back up to the list of "Devices with Removable Storage", click on the PSP removable disk and choose Eject.
(Actually, sometimes when I do this step Windows XP refuses to eject the disk, complaining that "An error was encountered trying to eject 'Removable Disk (G:)' but I've found if I ignore the error and just unplug the PSP, all is well)
Now, to view downloaded pictures on your PSP, move to the Photo area. You'll see one item shown: "Memory Stick" and an indication of how much free space you still have on your Memory Stick Duo. Click on that by pressing the 'x' button and... poof! You'll see all your photos listed. Click on any and you'll get a nice full-screen view.
To listen to the songs you've downloaded, go to Music, click through the "Memory Stick" information, and you'll see a list of MP3 files. Click on any of them to have them play.
Jan 14, 2008 | Sony PlayStation Portable (PSP) Console
Usb cable
Just like sorta of add-on to szwaan's answer:
You must have a memory stick to put music into your psp such as mp3 files, the psp itself does not have any internal memory for you to store any music files whatsoever.
if you got a memory stick already, connect your psp to your computer via usb cable, select usb under the setting section of your psp, and the memory stick drive will appear in your "my computer", so you can drag your music into the Music folder of your memory stick and play them from your psp.
Dec 21, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
Jonathon summesfield
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
