Re: Hi I have great computer speakers from Haman Kardon...
Yes, you can splice the wire, and buy a new plug, and just connect ground to ground, and + to + of the plug, you can pick up a plug at a local radioshack
count the number of pins of your connector so that you will know what to buy, better yet just bring the actual connector to your nearest electronic shop
If the mentioned cable is the one that is connected to the motherboard of the sub woofer and has two connectors for the speakers on the other side - please contact the Harman/Kardon support of your country, as they may be able to replace this part (actually this is a very rare part) it also may occur that the company will not be able to replace the part with a genuine one, but with a modified one. You can also try to contact some companies that would be able to replace this cable with a custom-made one.
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
Hi sheawm. You can use your speakers as long they have the mini-plug connector such as ipods, blackberrys, laptops, desktops, etc. so it won´t matter. I hope this helps.
i believe that plug is special because it feeds not only audio signal but also voltage to power the speakers. so unless u know that the speakers will get power from the plug, it will probably not work
Hi, Kazim
Firts things First:
1) check connector for 2 way sound. you can use a headphone for this.
2) you also buy Ipod dock sound speakers, there is Ihome speakers, great ones, for less than 25.00 dollars.
3) you have to see balance on those speakers.
good luck
Hi, I came across a similar problem with an old Altec and the the solution was to only replace the defective side. Actually, what was replaced was only the speaker itself inside the enclosure which was cheaper rather than replacing the entire assembly. An electronics technician (not necessarily a computer tech) can do the job since some soldering might be involved.
