Question about Refrigerators
Ge upright freezer, 4 years old, model # FUF 20DPDRWH. The sides are very hot to the touch.
Might be the condenser/compressor fan isn't running......
Posted on Jul 28, 2008
Freezer stopped after power outage
If the sides are hot, look at the defrost timer. Sounds like it has stopped running with the defrost elements on. The compressor has a safety switch on it that opens either if the compressor gets too hot or if it pulls too much current when starting. If your power flickered a lot before coming back on, that triggered the safety switch. Now that it's running normally, I wouldn't worry. The defrost timer is your problem now.
Jul 10, 2016 | Frigidaire 14.1 cu. ft. Upright Freezer...
How can i convert freezer to refrigerator
Usually this can be achieved by changing the REFRIGERANT GAS used AND vice-versa [ie fridge-freezer or freezer-fridge]. IF your unit has twin compressors [as most modern combo-units do] your local Refrigeration Engineer should be able to do this for you. With modern compressors and Environmental Regulations this is NOT a DIY job ... ok [as used refrigerant gas must be safely removed and disposed of as directed by local Environmental Laws].
Sep 21, 2014 | Refrigerators
I want to know how long the warranty is for GE Model FUF 17DPHRWH, Serial Number DL177038. Thanks. My phone number is 806.335.3745
The warranty offered by GE on the FUF17DPHRWH is one year for parts and labor from the date of purchase if the unit fails due to a defect in materials or workmanship. If you pay for the GE Service Protection Plus, you will get longer coverage. (However, I've found that for most appliances, you would be better off putting the annual fee for the service in a savings account. Then when the appliance fails, use the money in the savings account to repair or replace the applaince.)
The manual is available here: . If this direct link doesn't work, start at and enter the model number. Then click Submit.
I hope this helps.
(I have no way of looking up GE Service Protection plans.)
May 20, 2011 | GE FUF17SVRWW Upright Freezer
We've got a GE American Fridge Freezer. 12 years
time to get a new freezer. check the floor under the freezer for coolant leakage, if none the compressor is ready to deep 6...
Nov 07, 2009 | General Electric Chest Freezer FCM5SU
Walls of freezer are hot to touch
freezer is working overtime . these symptoms generally indicate excessive outside air coming into freezer. make sure doorgasket is completely sealed all the way around door.
Sep 08, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
A 10 year old model. the front of center panel is very hot
It can reach temperatures of 120 degrees. It is to prevent condensation between the freezer and fresh food compartments.
Aug 24, 2009 | GE Refrigerators
My wife called me home to a thawing freezer.The outside stuff was thawed and the temp was 40 inside.The sides were hot on the freezer and it is a 20 cubic foot upright that is 12 years old. have not had...
Check the fan down by the compressor to see if it's working . If not , it needs to be replaced .Also check the coils to make sure they are clean of dust , lint , etc... Is the fan inside the freezer working ? The hot sides are good . This means the compressor is working ( the " freon " attracts the heat inside the freezer , pulling it out , to make the freezer cold . The air flow over the sides , help dissapate the heat ) . Without the model number , I cant look up to see how the freezer is made .
Aug 20, 2009 | GE 203 cu. ft. General Electric Upright...
GE Upright Freezer is not freezing
It is very common for the "relays" to go out on the compressor. The relays are mounted on the left side of the compressor. You need to find an "Appliance Parts Store" and buy an "RO-41". (this is a relay) it cost no more than 10 bucks. Go home with your new bought relay and pull your refrigerator out from the wall. Don't forget to unplug it! Take off the rectangle card board cover off the bottom of the refrigerator "in back"... More than likely 1/4 nut driver. Now look for the compressor--"The Roundish black thing the size of a basketball". Next, you will see a box looking thing (black, white) mounted on the side of the compressor with 2 wires going to it. Next take it off the side of the compressor. It just pulls straight off! Sometime though it may be held in place by a little clip. Now read the instructions with the RO-41(inside cover). You will end up cutting the old relays off. Take the two wires that went to it and wire them into the relay(follow the instructions w/relay) then other wires on relay plug right into the compressor! AND THATS IT! It sounds hard but aint... goodluck!!!
Dec 17, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
159 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
