Question about Maytag Refrigerators
The rubber seal is extremely hot - Maytag Refrigerators
  • 481 Answers
Clean the coils under the machine and make sure the airflow under the machine it not obstructed at all. also check to see if the fan is running under the machine.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 27, 2008
What would cause hose from pump to tank on a porter cable pancake comressor get extremely hot when running
It is normal for the line going from the compressor to the tank to get very hot in all air compressors. Compressing air creates allot of heat. It will get hot enough to cause burns if touched.
Nov 18, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I AM ALWAYS GETTING MOLD INSIDE THE LG FRONT LOADER. THE RUBBER SEAL IS ALWAYS MOLDY
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. If the growth is very high then try and leave the door open for 4-5 hours and let it dry and then spray the bleach+water (3:1) mixture on the seal. Let it dry for another 2-3 hours. You may need to change the seal in case of extreme growth of mold. Hope this helps...
Daniel
Aug 30, 2010 | LG WM-2077C Front Load Washer
Rubber casing of lens gummy;difficult to extend or shorten lens
did the lens get hot (closed in hot car)?- probably melted some of internal lubricant and /or adhesive on rubber rings or caused the rubber ring itself to start to deteriorate
Apr 23, 2010 | Sigma 70-300mm f/4-5.6 DG APO Macro Lens
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Mold on the rubber seal of bosch washing machine
RUN A LOAD OF HOT WATER WITH 1 QUART OF WHITE VINEGAR, THAT WILL KILL THE MOLD, THEN WIP IT OFF THE SEAL
Aug 24, 2009 | LG WM-2277HW Front Load Washer
Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
May 09, 2009 | LG LRFC25750 Refrigerator French Door
Possible fire hazard
we have same one ours gets warm but not hot enough to discolor you better call for service immediatly definate fire danger good luck
Mar 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Kenmore side by side model 106.55512400 inside frame hot to touch
There is an electric heater in the center which is called a mullion heater. If you have an energy saver switch on your model turn it to the saving position.
Jul 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Canon IXUS40, rubber(?) seal between lens rings & body keeps popping out
It can be replaced, but requires removing the front face of the camera. Here's an example disassembly. Proceed no further than removing the front face to install the seal:
http://www.smashedhat.com/sd300repair/
Not sure where you could find a replacement other than from another (broken) camera. The seal is mainly intended to minimize sand and grit from entering the camera, but is not necessary for operation of the camera.
Dec 18, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
