Question about Hotpoint RB757 Electric Kitchen Range
Stovetop burners are not heating up
I turn the knobs and the hot surface light lights up but the burners are not heating up.
I electic range go check you house breaker, for the range turn it off and then back on.. If that does not work pull range out if free stanging and be sure to unplug range. remove bottom cover where the power cable goes into the terminal block, you might have a bad wire at that connection....
Guest 2
Posted on Jul 31, 2008
Element light stays on after all power control knobs are in off position?
Good Afternoon Cindy,
I see that you are having trouble with the element light staying on after all power control knobs have been put into the off position on your Frigidaire range, model# FEF366EC. The Element ON indicator lights will glow when one or more of the surface elements are turned ON. A quick glance at these indicator lights when cooking is finished is an easy check to be sure all control knobs are turned OFF. The Hot Surface indicator light will continue to glow AFTER the control knob is turned to the OFF position and will glow until the heating surface area has cooled sufficiently. I suggest resetting your appliance by shutting the power off at your home's circuit breaker for 2-3 minutes. Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "clock" button, and then you will press and hold down either the up or down arrows until the correct time appears. Try turning the burner on that the indicator light stays on the most. When you turn it off if you are still having trouble with the element light staying on, I suggest contacting a local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 27, 2014 | Frigidaire FEF366EC 30" Freestanding...
My heil furnance comes on but no hot air or air at all
see this causes and fix it. God bless you
o light the pilot on a standing-pilot (always on) ignition system, follow the lighting instructions located near the control. Otherwise, try these steps: Light the pilot:
  1. gasfurnace1.jpg Press and hold the pilot control knob to start the pilot. Set the control knob to the pilot position. Hold a long match under the pilot gas port.
  2. Press the control knob; the pilot should light. Hold the control knob down until the flame is burning brightly (about 30 seconds). Release pressure on the knob, and turn it to the on position.
  3. If the pilot goes out when you release the control knob, try relighting, holding the control knob down longer. If the pilot again goes out, check the thermocouple (below).
Adjust the pilot:
  1. Remove any cap covering the pilot adjusting screw on a combination control.
  2. Turn the adjusting screw counterclockwise to increase the flame or clockwise to decrease it. It is correctly adjusted when the flame envelops the thermocouple bulb by 1/2 inch and appears dark blue with a small yellow tip.
Test and replace a thermocouple:
  1. Hold the control knob to pilot and light the pilot as above.
  2. Unscrew the thermocouple fitting with an open-ended wrench.
  3. Set a multimeter to the DVC (lowest voltage) scale.
  4. Clip one multimeter lead to the end of the thermocouple tube nearest the pilot and the other lead to the fitting on the other end of the tube.
  5. If the multimeter shows a reading besides zero, the thermocouple is functioning. Replace the thermocouple tube.
  6. If there is no reading, you will need to clean or replace the thermocouple following steps 7 through 11.
  7. Release the control knob and shut off the main gas valve on the gas-supply pipe that leads into the burner. Shut off power to the burner at the electrical service panel .
  8. Remove the thermocouple from its mounting bracket.
  9. Wipe the combination control clean and install a new thermocouple, tightening it by hand, then give it a one-quarter turn with a wrench.
  10. Insert the thermocouple into the pilot bracket, being careful to not crimp the tubing.
  11. Turn on power to the furnace and relight the pilot (above).
Adjust an adjustable burner air shutter:
  1. Set the thermostat to its highest setting to keep the burner running. Once the furnace has heated up, remove the burner access panel and loosen the locking screw.
  2. Open the shutter by turning it to the right until the blue base of the flame appears to lift slightly from the burner port surface. Then close the shutter until the flame reseats itself on the surface.
Clean removable burner tubes and ports:
  1. Shut off gas and power to the furnace.
  2. Unscrew or loosen and remove the tubes from the supporting bracket.
  3. Carefully clean the tubes with a brush or vacuum, making sure not to damage the burner ports.
  4. Use a stiff wire to clear any debris from clogged ports.
Oct 08, 2012 | Honeywell Icp Heil Tempstar Furnace Spark...
I have replacedsurface unti terminal block with kit supplied by whirlpool part dealer. Though all other burners work on stovetop, the large burner still won't heat up. I alsp bought brand new element from...
Good morning,if you've replaced the burner and block and it still isn't heating,you definitely have a bad burner switch. On an electric stove you have two lines of 115 volts going through the switch to the burner. If one of the lines through the switch has burnt out,you may still get the burner on light. Hope that helps.
Jun 05, 2017 | Whirlpool RF302 Electric Kitchen Range
GE gas stovetop burner doesn't light
there are sparker modules on each burner behind the button, it may be that yours is failed, if you turn on other knob and you see spark at problem burner and still isn't lighting you have to make sure the black or grey tops are paced on perfectly, just give them a little nudge and you have to make sure area is perfectly clean for spark to take effect, spark will go for cleanest area on metal. so ensure area is clean and check burner top
Feb 05, 2010 | GE 30 in. Profile JGP979 Gas Cooktop
This morning, I went to turn the oven on to preheat. The oven light came on, but when I passed 250 degrees, it went back off. I turned the knob around to broil, the light came on again. But the oven never...
Check the breaker pannel or fuse box. The elements work on 220 volts the lights on 120 volts. If this doesn't help repost and well try again
Hope This helps
Please leave feed back
Nov 29, 2009 | Kitchen Ranges
When I turn the surface control to lite sparks come from the other surface controls. The burner does come on but we are afraid to leave the burner because of the sparks coming from the other controls. Do...
When one burner knob is turned to the light position, all burners will spark. Once the burner lights, just move the knob slightly so it is no longer in the light position and all sparking will stop.
Nov 12, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Whirlpool Flat cooktop burner not heating up
Try cleaning the knobs. I did the same thing you did (turning the circuit breaker off but that did not solve the problem.
My wife just tried turning the knobs and that seemed to work. It appears that one of the knobs may have been so sticky that the though it's in the OFF position it thinks it's still ON.
Jan 12, 2009 | Whirlpool RCC3024 Electric Cooktop
Hot Surface Light stays on
Our success has been to heat the elements to hot for about 5 minutes. Then let cool to reset temp sensor.
Can cause the problem by turning a burner on for a short period of time
Dec 16, 2007 | Whirlpool GJC3034 Electric Cooktop
Surface unit indicator light is always on
Coffy, if you are talking about the hot surface indicator lights, they are controlled by the limiter on the burner itself. When the burner heats up the limiter closes and sends power to the light (hot surface). When the burner cools the limiter is supposed to open cutting power to the hot surface indicator light. They may be stuck closed. If you are talking about the lights on the back panel, that is controlled by the infinate switch itself. Catriver
Oct 09, 2007 | Kenmore 96012 / 96014 / 96019 Electric...
Hotpoint RB757 Electric Kitchen Range Logo
187 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
