Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Making new folder and copy folder from harddrive to flash
When I try to add a new folder I get a message saying cannot create file or folder. When I try to copy folders, it copies some folder, then I get the above message, though the flash has more than enough space for the file or folder.
  • John Taylor Sep 02, 2008
    I have a "home made" tower PC where I have the same prob. I can see the write protect swich on the flas drive(s), but cannot utilise anything small enough to throw it without the fear of damage.
    The message I get reads " Cannot copy ("filename") - The directory or file cannot be created.
    ANY help would be greatly appreciated.
  • 928 Answers
On most flash drives there are locks that are called write protect locks. Its a switch on the drive itself that prevets you from saving on it.
Posted on Jul 27, 2008
Can't copy large files onto my external harddrive
What format is the external drive ?
you might need to split the file with rar
I recently downloaded win 8 5gb had it split with rar into 2 files downloaded with IDM trial
The FAT32 format does not support single files larger than 5GB, so if you have a file larger than 5GB you cannot put it on your FAT32 thumb drive. Most thumb drives and other portable media devices use FAT32 format, so this setback makes large files less portable, and that just won't do. Get around this problem by compressing the of the file or by splitting the file up into multiple pieces.
Create a folder for your RAR file and insert a copy of the original file into this folder. RARing a file separates it into multiple pieces, so creating a file specifically for your RAR file will keep the files together allowing you to move one folder to your FAT32 device instead of having to locate and move multiple files. Right click the large file that you want to put on a FAT32 device. Select "Add to archive" from the menu that appears to the side. Select "RAR" from the "Archive Format" located to the left of the menu. Click the arrow next to "Split by volume, bytes," and select "CD 700: 700mb." This will create a new file for every 700mbs, meaning your your one large file will be separated into many 700mb files that can be put back together as a single file later. Click "OK." Put the folder, containing your newly separated files, onto your FAT32 device after WinRAR has finished separating the file. b> Zip File b> Right click the large file you want to put on a FAT32 device. Select "Add to archive" from the menu that appears to the side of the file. Click "OK" on the next menu. This menu allows you to customize the compression settings. The only option you need to change is the "RAR" selection to "ZIP" in the "Archive Format." The rest of the default settings will work fine, so there's no need to change anything else. The zipped file will appear in the same folder as the original. Delete the copy of the original large file from the folder and put your newly compressed file on your FAT32 device after the file has completely compressed. The time it takes for the file to finish compressing depends on the of the file. Hope this helps. http://www.all-freeware.com/getfreeware.html?pid=109090&mirror=1
b>
Jan 08, 2013 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
Tip
MultiBoot USB Flash - Survival Guide
Grub4DOS is a boot manager
that can be easily installed to a USB flash.
It allows booting multiple operating systems
from a simple graphical user interface.
1.) Format the USB flash drive in the FAT32 or NTFS filesystem. (Windows)
Download and start HPUSBFW.EXE )http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
-REMINDER!!! all data will be deleted on the USB flash-
1.a) Download necessary files
Grub4Doshttp://dl.dropbox.com/u/4040651/grub4dos-0.4.4.zip
Grub4Dos gui Installer 1.1
http://dl.dropbox.com/u/4040651/Grub4Dos%20gui%20Installer%201.1.rar
1.b) Extract the downloaded zip files into separate folders.
For example:
Grub4DOS to C:Grub4DOS
Grub4Dos gui Installer 1.1 to C:
2.)
If your flashdrive is not already plugged into the computer, plug it in now.
2.a) The next step is to run the Grub4DOS Installer.
Browse to the Installer's unzipped folder using Windows Explorer.
2.b) Run the grubinst_gui.exe program (Windows XP)
Right-click on grubinst_gui.exe Run as administrator (Windows 7)
2.c) Once the program is started, select the Disk option,
then click the Disk Refresh button and then select
your flashdrive from the dropdown box.
IMPORTANT:If you accidentally select the wrong drive,
you may not be able to boot your system without doing a boot repair.
2.d) Now click the Part List Refresh button,
then the dropdown box and finally select the Whole disk (MBR) option
2.e) Click the Install button to install Grub4DOS to the MBR
of the flashdrive.
Hopefully, you'll get the message that the installation was successful.
3.) The next step is to copy the grldr file to the flashdrive's
root folder.Using Windows Explorer, browse to the folder
where you unzipped
the Grub4DOS program and copy the file to the flashdrive.
3.a) Grub4DOS is now installed on the flashdrive.
4.)Download file
menu.lsthttp://dl.dropbox.com/u/4040651/menu.lst
4.a)You need to copy the menu.lst file to USB Flash
4.b)Create a folder Boot on a USB flash drive.
in this folder create new folders
Splash
menus
4.c) Download file
Snaiyahttp://dl.dropbox.com/u/4040651/Snaiya
4.d) On USB flash-open the folder Boot
Within-we see Splash folder. Copy the file Snaiya into it.
5.) Add Puppy Linux on a multiboot USB flash
5.a) Download the Puppy ISO imagehttp://www.puppylinux.org/
5.b) Create a folder Puppy on a USB flash drive.
5.c) Take from the downloaded ISO, file
PUP_420.SFS (from the folder Puppy)
Rename it to pup_420.sfs
and copy it to
USB flash.
5.d) Copy all other files from the downloaded ISO (from the folder Puppy)
to the folder /Boot/Puppy/ (Create a folder on a USB flash)
5.e) In the menu.lst add a:
title Puppy
kernel (hd0,0)/boot/Puppy/vmlinuz ramdisk_size=100000
initrd /boot/Puppy/initrd.gz
5.f) Preserve the changes and now menu.lst looks like this:
gfxmenu (hd0,0)/boot/Splash/Snaiya
timeout 30
default 0
title Puppy
title Boot from CD-rom
cdrom --init
map --hook
chainloader (cd0)
title ShutDown PC
halt
title Reboot PC
reboot
5.g) Puppy on our MultibootUSB flash-is ready for operation.
(Now we can restart our computer and see how it looks and works)
Depending on the options your motherboard, it is necessary when starting
your computer keyboard press: F8 or F12 or Esc, etc..
Thus you will appear a menu where you choose your USB flash drive.
on Feb 07, 2011 | Computers & Internet
I'm running windows 7 on a Toshiba L455 and I keep getting a prompt that says; can not find "flash.ocx"
Flash is a programming language that many publishers use to create animations, games, and interactive programs for the web. Flash is also used for programs run locally on a users computer. To use these Flash based programs and web applets, the end-user must have Flash Player installed. One component of Flash Player is a file called "flash.ocx." If this file is missing or damaged, you may get an error message.
There seems to be two root causes of this error. A description and solution for each follows:
  • You receive the error message "Cannot find the file flash.ocx" every time you start your computer or each time you open your web browser (such as Internet Explorer). This is usually the result of a missing "flash.ocx" file caused by an incomplete installation of Flash. Here's how to remedy the problem:
    1. Download the Flash Player uninstallrom Macromedia. Save it somewhere convenient.
    2. Run the downloaded program and allow it to finish.
    3. Once the uninstall completes, restart your computer.
    4. Visit the Flash Player website and download/install the latest Flash Player version.
    5. That's it!
  • You receive the error message "Cannot find the file flash.ocx" at seemingly random intervals or when starting a specific program (other than your web browser). First, perform steps 1-4 of the previous solution. This will insure you have the latest version of Flash Player installed. If you still receive the error message, continue with the steps below:
    1. Navigate to the folder "C:\WINDOWS\system32\Macromed\Flash\". In this folder you will see a file named "Flash9f.ocx".
    2. Make copy of the "Flash9f.ocx" file in the same folder as the original (copy the original, then paste the copied file into the same folder).
    3. Rename the newly made copy to "Flash.ocx".
    4. If the previous steps don't eradicate the error messages, change your screen saver to one of the defaults that are included with Windows (such as "3D Text").
if the problem still persist please let me know.
Apr 15, 2011 | Computers & Internet
I can't get the new version of Flash Player to install so I can watch live racing on Twinspires. It says I must close Mozilla which I do - it installs and then when you go into the system again, the...
There are several possibilities and in most cases, incompatibility issues, but actually this problem is fixed by inserting some data in the Mozilla folder after creating a plugin folder. First of all, download and extract the files of this zipped file through Winrar or Winzip to a specific folder (Click Here to download), copy flashplayer.xpt and NPSWF32.dll, click "Start" > "Run" and type in %APPDATA% and press Enter, a new folder will open up, locate Mozilla folder, open it and create a new folder and name it "Plugins" and paste the two files you've copied i.e. flashplayer.xpt and NPSWF32.dll, in the folder "Plugins" and close the firefox, restart and it should work fine with the flash media content pages.
If the problem persists, backup all the bookmarks and uninstall the Firefox. Before you reinstall, download and install the Adobe Flash player via Internet Explorer and install the Firefox again. Let me know if you have problem doing these.
Good luck.
Thanks for using FixYa.
Nov 20, 2010 | Adobe Photoshop 7.0 for PC
Copied files to a folder on portable harddrive
1. Try creating another folder and coping the content from the original to the new folder on the USB drive.
You may have stopped the coping process inadvertently during the copy process.
Apr 07, 2010 | Toshiba 120GB USB 2.0 Portable External...
I tried to add music to my micro sd. it says i have 1.83 gb available and i tried to add 342 items which is 1.55 gb but i get a 0x80070052 error message as soon as I hit 114 items. how do i fix it and...
The "root" directory has been filled.
Delete one or two items and create a folder on the microSD. You will be able to add more files, but into the folder, not the root area.
You should move all files to folders.
Oct 10, 2009 | SanDisk 2GB microSD Memory Card
False write protect on an EMPREX 8GB Flash Drive
hiii martin....
dis type of problem comes when sm files inside d folder which iu want to copy restricted allowing files to copied...
u can copy it by fallowing procedure....
first open urs folder and select some of urs files not all of them and copy it to flash drive by makin a new folder....and similarly copy other files in that new folder..
if u do like that u can copy all files eaisly......
if it creates ore problems ask me.......
also available for live chat....
thankss
Jun 20, 2008 | Electronics - Others
Verbatim flash drive
try copying the files to a subfolder. The FAT file system has a limit of how many files & file name characters you can store in the root folder.
Oct 31, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sonic dvd writer for photo story
if you are using xp, you can save your files to all users shared documents folder ,here you can create a folder that everybody can open it.
Oct 30, 2007 | Computers & Internet
Error copying file or folder
You can always reformat it. If you plug the mp3 player into your computer and right click on the icon in the MY COMPUTER window, and click on FORMAT. It should come to a new window and click on start format. Your fixer, Wild2DMaxx
Jan 17, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
142 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
