Question about Norelco 3601 X Electric Shaver
Charging 3605X There is a charging light but it does not begin to flicker when the correct amount of time has passed. How long (in hours) should this razor be charged? Thank you, charlesalley@peoplepc.com
    Problem Solver:
  • 20 Answers
1HOUR
Posted on Jul 27, 2008
Bought a new alternator due my old one FAILED the test. But, I still have the problem with my head lights flickering & stereo going off then on when I accelerate to go.
Diagnosing Common Automotive Charging System Problems
www.onallcylinders.com/.../diagnosing-some-common-charging-system-...
Sep 18, 2013 - Flickering gauges. ... Problem: The charge indicator light flickers while driving. .... My alternator has been replaced for the third time in 5 months. ... I bought a new regulator but it is still doing the same thing... .... my headlights wont turn on, car runs fine when jumped, battery last for maybe 3 hours, any ideas ...
All lights Flickering/Pulsating only when motor is running ...
www.cadillacforums.com/forums/cadillac-forum/t-221843.html
Feb 11, 2011 - So i have noticed for a while now that all my interior lighting (radio, tach, even ... Installed the battery and have not had issues starting since then. ... So now ipurchased a new alternator "just in case" figuring i would eliminate the .... Interior lights and headlights still seem to pulse/flicker while idling the most, ...
Lights Flickered. Replaced Alternator. Now more flicker? - Camaro ...
www.camarozone.com/.../lights-flickered-replaced-alternator-now-more-...
Apr 22, 2013 - 20 posts - ‎4 authors
Jan 19, 2016 | Cars & Trucks
Brand new first charge The green light on the charger plug goes off after a short time. Is the unit still charging?
Once the green light goes off, it's done charging. Since it was first charge I know they say to charge it 8? hours (or 4? don't recall right offhand) but it does come charged (that's part of how they make the batteries). What you do want to do is remember not to always recharge it when your done using it. Use it till the battery goes flat, then recharge it; it will give you a longer battery life that way.
Jan 09, 2015 | Dyson DC34 Bagless Cordless Hand Vac -...
Can I put higher Ah batteries in my Shoprider Streamer?
Absolutely. Let me explain what "Ah" means. "Ah" stands for Amp Hours. A 32ah battery will run a 1 amp motor for 32 hours...or a 32 amp motor for one hour...a 16 amp motor for two hours etc.. As long as the battery voltage is the same it's absolutely fine. As long as your chargers are the correct voltage, they'll be fine as well. So basically, the higher the "Ah", the longer the battery will last. This is why higher "Ah" batteries are more expensive. Hope this helps : )
Jun 09, 2014 | Shoprider Streamer Sport Power Chair
Canon powershot a3300
If nothing is wrong with the camera, the battery is placed correctly, the battery cover is closed correctly then only one thing can be wrong. Even when you don't believe it is possible, the battery can be flat again.
So to make sure everything is as you think. Charge the battery again, and look if the charger acts as usually. The charging lamp turns orange and charging begins. When the charging is finished, the lamp turns green. Last time you charged, it could have taken 4 hours, before the lamp went green. If the battery is recently charged, it only will take a fraction of that time. If it still takes a long time, your battery was empty. It is recommended, to charge not longer than for 24 hours. After charging, please wait till the battery is cooled down. Then insert it again and close the battery cover. Check the cover closes correctly. And now switch on again.
If you charged with an USB cambs connected to the camera. Don't forget to remove the cable, because the camera won't start as long as an USB cable is connected.
Feb 25, 2014 | Cameras
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
I have new laptop how many hour battery charge first time
First Time Charging
  • The amount of time it takes for your battery to fully charge depends on many factors, like your battery type and operating system. Many newer laptops will charge in 15 to 20 minutes, while others can take a few hours.
    When you're charging your battery for the first time, charge it fully before using your laptop. You may have to go through a battery cycle a couple times before your battery begins performing at its maximum capability. To do this, charge your battery fully, let it discharge to about five percent, and then fully charge it again
  • Read more: For How Long Should One Charge a New Laptop Battery? ' eHow.com http://www.ehow.com/way_5261076_long-charge-new-laptop-battery.html#ixzz1GTAFQEz9
    Mar 13, 2011 | Acer Computers & Internet
    Charging for 30 hours so far...
    mine seemed to take ages on the first charge but after like 3 days or so the light started to blink.
    Aug 26, 2009 | Archos Internet Media Tablet MP3 Player
    Screen flickering
    You need to reprogram (flash) the phone. Go to a nearby shop, they can do it for your for a little amount of charge.
    May 18, 2008 | Nokia 1112 Cellular Phone
    Norelco Advantage red light meaning and source of manual
    the steady red light showing when in charger shows that
    it is charging. the blinking red light when taken out of
    charger or turned on and off means it is not fully charged.
    leave it in charger till red light turns green.
    Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
    Cannot get keychain to turn on when dissconnected from computer
    Sounds like your battery is dead.
    1. Please note that when charging from your USB cable to the computer, full charging time will take up to 7 hours. If you are charging using your own DC car charger or AC wall adaptor,
    charging time will be much less and will take up to 3 hours.
    2. Indicator light will turn green when charging is complete.
    Jan 06, 2008 | Baby Gear
    Norelco 3601 X Electric Shaver Logo
    141 people viewed this question
    Top Norelco Health & Beauty Experts
    shaveroutlet.com
    shaveroutlet.com
    Bruce Foote
    Level 1 Expert
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
