Question about Ricoh Aficio 450 Copier
I have a Ricoh Aficio 2018 PhotoCopier. Recently it ran out of toner. I reinserted the old cartridge which I had re-filled with toner (ricoh). However the off-side (non-copy side) of the sheets are dirty - have some dirty lines. What do I need to clean in order to remedy this.
  • 58 Answers
Did you have this problem before you refilled the non-refillable cartridge? If not, you may have damaged the toner cartridge and like the above mentioned post you have a toner spill.
You could also have infected the machine with inferior toner. Ricoh machines are dual componet, meaning the developer and toner are matched to make consistant good quality copies.
Clean, clean and keep cleaning till you remove all of the toner from the unit and if that does not work, call an authorized dealer for professional repair. Was it worth saving $10 on refilling the cartridge?
Posted on Jul 28, 2008
  • 14 Answers
You probably have a toner spill which has gone under the transfer roller. Open the right side of the machine and you will see a dark colored roller on the inside of the open part. Stydy it very carefully and you will see how to remove the roller including it's holder. be carefull of the springs, they love to escape. also watch as to how the bushings and gears are assembled so you get them back on properly. Clean any toner out from underneath the roller, replace the assembly and run 10 copies of a white piece of paper. this roller runs on the backside of the paper and can cause your problem. Hope this works for you. Check your paper tray as well as toner can migrate down into them.
Dave T
HOW DO I RESET WHEN adding a new toner cartridge
There is nothing to reset the toner will load itself unless there is another problem. Make sure the insert plug from the old bottle came out before you placed the new bottle in.
Jun 11, 2015 | Ricoh Aficio Mp161 Copier Photocopier Copy...
Err 553 Ricoh aficio 2018D
SC 553 is a fuser error code, could be thermistor or thermal fuse or fuser lamp
Sep 27, 2013 | Ricoh Digital Copier Toner for Aficio...
Price of print cartridge
Depending on the vendor, you can get the Ricoh 406464 toner for the Aficio SP 3410SF (regular cartridge, not the high yield one) for between $65 and $90 . Some sites to look at http://www.bluedogink.com/ricoh-406464.html and http://www.staples.com/Ricoh-406464-Black-Toner-Cartridge/product_332848 .
I hope this helps.
Sep 15, 2011 | Ricoh Aficio SP 3410SF Laser Multifunction...
Ricoh Aficio 2018 ink rubs off paper too easily
Your corona wire is not function properly ... dirty or broken ... and/or the heater is not up to par.
Replace the corona and the heater roll to fix this problem.
Jun 22, 2010 | Ricoh Aficio 2018 Copier
Installed new black toner but it still indicates it is empty and nothing will print!
Did you install a brand new cartridge? Or did you refill the old cartridge?
Ricoh has "smart chips" in the toner cartridges, and those tell the printer how much toner is used. If you refill the toner,the smart chip must BE REPLACED, the old chip will remain stuck at "empty".
Sucks, that Ricoh for you. That why that printer was $160 on Woot. LOL.
(Yea, I got suckered in too...)
Oct 13, 2009 | Ricoh SP C220N Aficio Laser Printer
Replacing toner
Check the developer.
Jun 17, 2008 | Ricoh Aficio 250 Copier
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Mar 19, 2008 | Ricoh Aficio CL2000 Laser Printer
Ricoh Aficio 450 Copier Logo
280 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
