I have a 300 gb Seagate HD/back up. Ihave all of the connections as previously set up but the HD is not showing up and I am unable to access it
  • Booxanth Jul 27, 2008
    Old hard drive that already has about 200 gb used up, just have not hooked it up in a while. restarts and replugging does not work. Note: Cat did chew into the power cord but It appears to be fully powered.
  • 21 Answers
If it a fresh new hard drive, then you will need to partition it and format it before you can access it. Does it show up in bios? If it does then you know that it is hooked up correctly. Might just need to partition it and format it. If this dont help, then let me know what kinda of OS you are using.
Posted on Jul 27, 2008
Seagate FreeAgent, 500 GB p/n 9nk2al-510 stopped working
There's not much troubelshooting you can do with a failed external disk. power off PC and hd and then disconnect all cables, wait 30 secs, power the PC on, let it boot to the OS, power the hard drive on and then connect. If the drive shows up but you still cannot access it or get weird property readings, it generally means the hd controller has failed. If the data's worth more than $1000, you can take it to a data recovery group like Ontrak or Cherry Systems, but otherwise, just get a new hd and restore whatever backups you have.
Oct 07, 2009 | Seagate Free Agent Go Small 12 GB USB...
Seagate 500 GB external hd that suddenly changed from NtFS to RAW
You can use a utilities like partition recovery to try to recover the previous partition.
Sep 17, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 750GB usb HDD asks to format,when opening by double click
The disk is either damaged or the USB interface is damaged.
1) You could try opening the external case and connect the disk to your computer directly (Using IDE/S-ATA cables)
2) Format the HD and use data recovery software/service.
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Disk management does not see working hard drive
Are the Hard drives setup as master & slave ? (plastic jumper on Hard drive at cable)..... is the Hard drives connected on separate ide cables... if they are ide drives ?
Mar 30, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
Seagate Barracuda 7200.8 300 Gb - power problem
it really all depends on how far the damage is. I have swapped the controller board on a hard drive that had failed with one from an identical drive and was able to retrive the data. This is not a very common thing that works. Your data is most likly still entact on the platters. However, if the motor is damaged it would require expert and very expensive help to recover the data.
If you have access to being able to swap controllers then try it. This may get your data back.
Jan 13, 2009 | Seagate (ST380011A) 80 GB IDE Hard Drive
SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Nov 11, 2008 | Seagate 250GB Barracuda 7200.10 ATA-100...
Seagate 300GB USB 2.0, read write error
Hook it to another computer do see if the drive is the issue.
Oct 04, 2008 | Seagate 300GB USB 2.0/FireWire Hard Drive...
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Need Help
Usually the beeping sound when powering up the drive is an indication that the drive is damaged.
Nov 22, 2007 | Seagate Barracuda 7200.9 300 GB SATA Hard...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
