Question about Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television
Blurryness We have a 42inch Mitsubishi HD1080 and the left side of the screen is blurry in the top left and bottom left corners, also the picture shows some blurryness especially with scores and words. Any suggestions.
  • Anonymous Mar 23, 2014
    can't see scores in top left corner
    can't see scores on top left corner
  • 3 Answers
This sound to me is a convergence problem may cost to you 350$ if you want to do it by your self need to buy 2 stk 392 110 but if you dont know nothing about electronics i recomend you ta`ke the tv to a service center
Posted on Jul 27, 2008
On my HD1080 Mitsubishi projection flat screen the picture is bowed on top and bottem and it look as if the projectors themselves are offset, but the picture is clearer as you come toward the center. If I...
You have poor contacts and or dry joints. Resoldering on the convergeance panel and powersupply/line timebase board will probably fix it.
It should take less than an hour in labour terms.
Feb 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Samsung plasma 42inch 1 month old has got 1 thin blue line 2 thin green lines from top to bottom on left side of screen
Most likely your control board: The board with the large processor that controls most of the picture formation is bad. Sounds like it is under warranty if it is only a month old.
Feb 23, 2010 | Televison & Video
SAME TV(mitsubishi HD1080 series)-- corners of screen are bent
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 21, 2009 | Mitsubishi WS-55805 55" Rear Projection...
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
One side of blurryness
now one thing at a time. the picture that is blurr does it have red or blue lines on the rt or lt side it sounds like the convergence is out on the unit and that will cause the picture to be blurry. and is the big screen in warranty please let me know marty
Oct 09, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Distorted picture
On the middle circuit board towards rear is a metal wavy plate.On the back side(actually towards screen when looking from rear of unit),the middle screw has a ground wire(light brown) that is loose.
Apr 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Pinching in at the sides and has blurry rainbow coloring on top and bottom.
Sounds like a pincushion problem. You can obtain the service manual and free diagnostic upport at the following link. Hope this helps.
http://servicemanuals.vstore.ca/
Jan 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsu HD1080
There is a possibility that the problem lies on the "Doubler" circuit board with this set, especially if the darkness looks like a smear in the picture during bright scenes like a hockey game.
Mar 13, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television Logo
88 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
